path: root/doc/ChangeLog (follow)
* 2004-02-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-171-0/+4
| | | | * develenv/Makefile.am: Put *.texi into the builddir.
* 2004-02-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-141-0/+4
| | | | * started/tversions.texi: Remove (Bogus).
* Reformat.Ralf Corsepius2004-02-051-311/+153
* 2004-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-051-0/+41
| | | | | * ChangeLog: Merge-in supplements/ChangeLog. * supplements/ChangeLog: Remove.
* 2004-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-051-0/+48
| | | | | | * ChangeLog: Merge-in ada_user/ChangeLog. * ChangeLog: Merge-in started_ada/ChangeLog. * ada_user/ChangeLog, started_ada/ChangeLog: Remove.
* 2004-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-051-0/+122
| | | | | | | | | * ChangeLog: Merge-in bsp_howto/ChangeLog. * ChangeLog: Merge-in porting/ChangeLog. * ChangeLog: Merge-in rgdb_specs/ChangeLog. * ChangeLog: Merge-in rtems_gdb/ChangeLog. * bsp_howto/ChangeLog, porting/ChangeLog, rgdb_specs/ChangeLog, rtems_gdb/ChangeLog: Remove.
* 2004-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-051-0/+55
| | | | | | * ChangeLog: Merge-in filesystem/ChangeLog. * ChangeLog: Merge-in networking/ChangeLog. * filesystem/ChangeLog, networking/ChangeLog: Remove.
* 2004-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-051-3/+79
| | | | | | | | * ChangeLog: Merge-in posix_users/ChangeLog. * ChangeLog: Merge-in posix1003.1/ChangeLog. * ChangeLog: Merge-in itron3.0/ChangeLog. * posix_users/ChangeLog, posix1003.1/ChangeLog, itron3.0/ChangeLog: Remove.
* 2004-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-051-0/+35
| | | | | * ChangeLog: Merge-in FAQ/ChangeLog. * FAQ/ChangeLog: Remove.
* 2004-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-051-10/+96
| | | | | * ChangeLog: Merge-in user/ChangeLog. * user/ChangeLog: Remove.
* 2004-02-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-02-041-0/+10
| | | | | | | | | | * HELP.html, index.html.in, rtems_footer.html.in, rtems_header.html.in, FAQ/basic.t, gnu_docs/gnu_footer.html, gnu_docs/index.html, gnu_docs/refcard.html, gnu_docs/rtems_tools_index.html, started/binaries.t, started/buildc.t, started/buildrt.t, started/intro.t, started/require.t, started/sample.t, started/tversions.texi.in: Incorporating changes from pre-4.6.0 review.
* 2004-02-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-011-0/+6
| | | | | | * configure.ac: Add RTEMSRPMGROUP. * common/rtems.texi.in: Add RTEMSRPMGROUP. * started/binaries.t: Add RTEMSRPMGROUP.
* 2004-02-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-011-0/+5
| | | | | * ChangeLog: Merge-in started/ChangeLog. * started/ChangeLog: Remove.
| | | | | | * configure.ac: Add RTEMS_ENABLE_RPMPREFIX. Add RTEMSRPMPREFIX. * common/rtems.texi.in: Add RTEMSRPMPREFIX.
* 2004-01-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-231-0/+56
| | | | | * ChangeLog: Reformat. Merge-in develenv/ChangeLog. * develenv/ChangeLog: Remove.
* Cleanup ChangeLog.Ralf Corsepius2004-01-231-79/+32
* 2004-01-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-171-0/+6
| | | | | | * Makefile.am: Remove AUTOMAKE_FILES. Add ../scripts/setup.def ../COPYING to EXTRA_DIST. Add rtems.html.in to EXTRA_DIST.
* 2004-01-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-01-071-0/+6
| | | | | | * configure.ac, index.html.in: mips64orion port removed as mips port more completely covers the MIPS family. * rtems_support.html.in: Removed.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-121-0/+4
| | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59.
* 2003-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-261-0/+5
| | | | | * project.am: Remove $(PROJECT).info* from CLEANFILES (Doesn't work with automake-1.7f/1.8 anymore).
* 2003-11-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-231-0/+4
| | | | * Makefile.am: Add missing '\'. Reformat.
* 2003-10-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-10-221-0/+7
| | | | | | | PR 513/doc * Makefile.am, index.html.in: Rename Getting Started to be non-language specific and remove link to Ada Getting Started. Also install missing graphic.
* 2003-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-221-0/+10
| | | | | * images/ChangeLog: Removed. * ChangeLog: Merge images/ChangeLog.
* 2003-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-221-0/+18
| | | | | * common/ChangeLog: Removed. * ChangeLog: Merge common/ChangeLog.
* 2003-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-221-0/+4
| | | | * common/.cvsignore: Add rtems.texi, rtems.sed.
* 2003-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-221-0/+9
| | | | | | | | | * Makefile.am: Merger from rtems-4-6-branch. * configure.ac: Merger from rtems-4-6-branch. Purge hppa1.1. * index.html.in: Purge hppa1.1. * project.am: Merger from rtems-4-6-branch. * rtems_support.html.in: Purge hppa1.1.
* 2003-09-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-191-0/+7
| | | | | | | * HELP.html, index.html.in, rtems_footer.html.in, rtems_header.html.in, rtems_support.html.in, ada_user/ada_user.texi: Merge from branch. * acinclude.m4, images/rtems_logo.jpg: New files. * SUPPORT, tools/texi2www/archive/texi2www-960103.tgz: Removed.
* 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-111-0/+4
| | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address.
* Merger from rtems-4-6-branchRalf Corsepius2003-08-071-4/+0
* 2003-04-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-04-171-0/+4
| | | | * index.html.in: Development Environment Guide should be updated now.
* 2003-04-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-04-111-0/+4
* 2003-02-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-02-181-0/+6
| | | | | | * Makefile.am, configure.ac: Remove src2html references. * index.html.in: Update to reflect partial update of Development Environment Guide.
* 2003-02-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-02-141-0/+4
| | | | * index.html.in: Removed a29k reference.
* 2003-01-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-271-0/+4
| | | | * index.html.in: Fix duplicate c4x entry.
* 2003-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-251-0/+4
| | | | * index.html.in: Add c4x.
* 2003-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-251-0/+5
| | | | | * configure.ac: Add c4x. * project.am: Add version.texi hack.
* 2003-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-241-0/+7
| | | | | | | * main.am: Remove AM_MAKEINFOFLAGS, TEXI2DVI, TEXI2PDF. Append -I $(top_builddir) to TEXI2WWW_ARGS. * project.am: Add AM_MAKEINFOFLAGS, TEXI2DVI, TEXI2PDF. Override automake's .dvi.ps:-rule.
* 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-231-0/+5
| | | | | * project.am, main.am: Use automake rules to build ps, pdf, info. Various minor changes.
* 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-221-0/+5
| | | | | * project.am: Append $($(PROJECT)_TEXINFOS) to html-dependencies.
* 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-221-0/+8
| | | | | | | | * configure.ac: Require autoconf-2.57. Require automake-1.7.2. Remove started/pictures/Makefile. * started/Makefile.am: Merge-in pictures/Makefile.am * started/pictures/Makefile.am: Remove.
* 2002-12-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-081-0/+8
| | | | | | | | * Makefile.am: Merge-in images/Makefile.am, common/Makefile.am. * images/Makefile.am: Remove. * common/Makefile.am: Remove. * configure.ac: Reflect changes above. * main.am: Append -I $(topsrc_dir) to AM_MAKEINFOFLAGS.
* 2002-11-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-11-131-0/+5
| | | | | * index.html.in: Note that the Getting Started with GNAT/RTEMS manual is largely obsolete now that GNAT is in GCC.
* 2002-10-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-10-241-0/+4
| | | | * index.html.in: Add links to multiple missing CPU supplements.
* 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-211-0/+6
| | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache.
* 2002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-311-0/+4
| | | | * configure.ac: Added supplements/arm/Makefile.
* 2002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-301-0/+4
| | | | * README: Updated.
* 2002-06-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-141-0/+4
| | | | * project.am: Use PATH_SEPARATOR to setup TEXINPUTS.
* 2002-04-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-111-0/+4
| | | | * VERSION, bootstrap: Removed as unneeded.
* 2002-04-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-081-0/+9
| | | | | | | | | * bootstrap: Remove. * VERSION: Remove. * Makefile.am: Remove bootstrap. Add ACLOCAL_AMFLAGS. * configure.ac: Add RTEMS_TOP.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-281-0/+7
