path: root/doc/ChangeLog (follow)
* 2002-01-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-201-0/+9
| | | | | | | | | * .cvsignore: Add autom4te.cache, install-sh, mdate-sh, missing, mkinstalldirs, texinfo.tex. * Makefile.am: Add main.am to AUTOMAKE_FILES. * configure.ac: Add AC_CONFIG_AUX_DIR([.]). * project.am: Remove custom .texi and stamp-vti rules. * main.am: Replace TEXI_COMMON with AM_MAKEINFOFLAGS.
* 2002-01-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-181-0/+9
| | | | | | | | | * Makefile.am: Require automake-1.5. * project.am: Reworked. * main.am: New. * configure.ac: New. * configure.in: Removed. * bootstrap: Sync with RTEMS's toplevel bootstrap.sh.
* 2002-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-171-0/+4
| | | | * VERSION: Updated to rtems-doc-ss-20010117.
| | | | * VERSION: Updated to rtems-doc-eng-20010816b-d1.
* 2001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-171-0/+4
| | | | * configure.in: Changed the version to eng-20010816b.
* 2001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-171-0/+7
* 2001-10-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-301-0/+4
| | | | * VERSION: New file.
* 2000-09-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-221-0/+4
| | | | * Makefile.am: Removed GENERATED_FILES from list of TEXINFOS.
* Adding ChangeLogs.Joel Sherrill2000-08-251-0/+3
