* sys/param.h: Removed as a simpler version of this file is
now part of the RTEMS newlib support.
* sys/Makefile.am: Modified to reflect above.
* machine/types.h: Removed as a simpler version of this file is
* machine/Makefile.am, machine/endian.h, nfs/bootp_subr.c,
rtems/rtems_bsdnet_internal.h, sys/Makefile.am, sys/systm.h:
Minor modifications to use the simpler machine/types.h. Mostly
more complete sets of #include's to account for machine/types.h
no longer doing this.
* include/sys/utime.h: Removed as file is now part of the RTEMS
newlib support.
* Makefile.am: Reflect above.
* include/rtems/termiostypes.h: Avoid use of __P.
newlib support.
* stackchk/check.c: Don't reference the RTEMS allocated interrupt
stack if the port doesn't configure using it.
* cpu.c, cpu_asm.S, rtems/score/arm.h, rtems/score/cpu.h,
rtems/score/cpu_asm.h, rtems/score/types.h: ARM port works
well enough to run all sptests, tmtests, and ttcp.
In addition to general cleanup, there has been considerable
optimization to interrupt disable/enable, endian swapping,
and context switching.
* netinet/in_cksum.c, netinet/in_cksum_arm.c: Added ARM in_cksum
support.
* src/rpc/Makefile.am: Merge src/rpc/PSD.doc/Makefile.am.
* include/Makefile.am: Merge include/rpc/Makefile.am.
Merge include/rpcsvc/Makefile.am.
* include/rpc/Makefile.am: Remove.
* include/rpcsvc/Makefile.am: Remove.
* src/rpc/PSD.doc/Makefile.am: Remove.
* configure.ac: Remove duplicate AC_PROG_RANLIB.
Remove include/rpc/Makefile.
Remove include/rpcsvc/Makefile.
Remove src/rpc/PSD.doc/Makefile.
2002-07-23 Joel Sherrill <joel@OARcorp.com>
* src/rpc/pmap_clnt.c (pmap_set): Changed prototype to match .h.
2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* src/xdr/Makefile.am: Use .$(OBJEXT) instead of .o.
* src/rpc/Makefile.am: Use .$(OBJEXT) instead of .o.
* src/xdr/Makefile.am: Eliminate LIBNAME.
* src/rpc/Makefile.am: Eliminate LIBNAME.
2002-07-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* configure.ac: RTEMS_TOP(../..).
2002-07-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2002-06-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* configure.ac: Use AC_CONFIG_AUX_DIR(../..).
Add AC_PROG_RANLIB.
2002-06-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
AC_CONFIG_AUX_DIR(../../../..).
Remove RTEMS_CANONICAL_HOST.
Use RTEMS_ENV_RTEMSCPU.
Add AC_PROG_RANLIB.
* include/rpc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* include/rpcsvc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
ACLOCAL_AMFLAGS = -I ../aclocal.
* src/rpc/PSD.doc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* src/rpc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* src/xdr/Makefile.am: Include $(top_srcdir)/../automake/*.am.
2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* include/rpc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/rpcsvc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/rpc/PSD.doc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/rpc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/xdr/Makefile.am: Remove AUTOMAKE_OPTIONS.
2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* configure.in: Remove.
2001-09-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* include/rpc/Makefile.am: Use 'PREINSTALL_FILES ='.
2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* include/rpc/Makefile.am: Apply include_*HEADERS instead of
H_FILES.
2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2000-10-30 Joel Sherrill <joel@OARcorp.com>
effects in RTEMS source code.
* src/rpc/Makefile.am, src/rpc/auth_time.c, src/rpc/clnt_simple.c,
src/rpc/clnt_tcp.c, src/rpc/clnt_udp.c, src/rpc/clnt_unix.c,
src/rpc/get_myaddress.c, src/rpc/pmap_clnt.c, src/rpc/pmap_getmaps.c,
src/rpc/pmap_getport.c, src/rpc/pmap_rmt.c, src/rpc/rtime.c,
src/rpc/svc_tcp.c, src/rpc/svc_udp.c, src/rpc/svc_unix.c:
Use of _read, _write, and _close as macros conflicted with
newlib's use of these as routine names. They were renamed to
include "_RPC_" prefix.
2000-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2000-09-22 Joel Sherrill <joel@OARcorp.com>
* src/xdr/xdr_float.c: Added A29K support.
2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* src/rpc/Makefile.am, src/xdr/Makefile.am: Include compile.am
2000-08-10 Joel Sherrill <joel@OARcorp.com>
* ChangeLog: New file.
* Makefile.am: Build libscorecpu.a instead of rtems-cpu.rel.
* configure.ac: Disable LIBRPC for the c4x.
Check for presence of score/cpu/${RTEMS_CPU}/cpu.c.
Let librtemscpu.a depend upon libscorecpu.a.
* automake/compile.am: Use .$(OBJEXT) instead of .o.
* pppd/chap.c, pppd/fsm.c, pppd/fsm.h, pppd/upap.c: Per PR255
fix prototype mismatches.
* wrapup/Makefile.am: Temporarily don't include serdbg since it
causes some BSPs to not link "main(){}" as required by autoconf.
* sys/select.h: Add a prototype of select() to avoid warnings.
In particular a C++ application using select() required a prototype.
* Makefile.am, libc/res_send.c: Do not install or use <poll.h>
since RTEMS does not support it.
* include/rtems/score/apimutex.h (_API_Mutex_Lock): Per PR253
add the missing _ISR_Disable. This fix was already applied to
the old location (c/src/exec/score/...).
* src/Makefile.am: Use .$(OBJEXT) instead of .o.
* Makefile.am: Use .$(OBJEXT) instead of .o.
* kern/Makefile.am: Use .$(OBJEXT) instead of .o.
* lib/Makefile.am: Ditto.
* libc/Makefile.am: Ditto.
* net/Makefile.am: Ditto.
* netinet/Makefile.am: Ditto.
* nfs/Makefile.am: Ditto.
* rtems/Makefile.am: Ditto.
* wrapup/Makefile.am: Ditto.
* src/dosfs/Makefile.am: Use .$(OBJEXT) instead of .o.
* src/src/imfs/Makefile.am: Ditto.
* wrapup/Makefile.am: Use project_libdir instead of
$(PROJECT_RELEASE)/lib. Eliminate LIBNAME. Pickup *.o's instead of
*.rels for CPU_OBJS. Manually create $(project_libdir)$(MULTISUBDIR).
* src/Makefile.am: Use AM_CPPFLAGS instead of INCLUDES.
* automake/lib.am: Use project_libdir instead of
* src/Makefile.am: Eliminate LIBNAME. Cosmetical cleanups.
* aclocal/env-rtemsbsp.m4: Remove RTEMS_BSP_SPECS, PROJECT_RELEASE.
Add project_libdir, libdir. New GCC_SPECS. Various cleanups.
* aclocal/env-rtemscpu.m4: Remove RTEMS_BSP_SPECS, PROJECT_RELEASE.
* aclocal/rtems-top.m4: New PROJECT_ROOT handling.
* automake/compile.am: Remove RTEMS_BSP_SPECS, LD* flags, LINK,
references to bsp_specs. Use project_libdir instead of
* kern/Makefile.am: Eliminate LIBNAME.
* src/dosfs/Makefile.am: Use AM_CPPFLAGS instead of INCLUDES and
AM_CFLAGS. Eliminate LIBNAME.
* src/imfs/Makefile.am: Use AM_CPPFLAGS instead of INCLUDES and
* wrapup/Makefile.am: Eliminate LIBNAME.
* Makefile.am: Eliminate LIBNAME. Use AM_CPPFLAGS instead of
INCLUDES (Upcoming automake standard).
* Makefile.am: Eliminate LIBNAME. Cosmetical cleanups.
* capture/capture.c: include <string.h> for memset.
* aclocal/rtems-top.m4: Reflect relocation of c/src/exec to cpukit.
* aclocal/check-cpu.m4: Ditto.
* aclocal/check-bsps.m4: Ditto.
* rtems/score/cpu_asm.h: Enhanced to include register offsets.
* Makefile.am: Install rtems/score/cpu_asm.h.
* cpu.c: Significantly enhanced including the implementation of
_CPU_ISR_Get_level.
* cpu_asm.S: Improved behavior of context switch and interrupt
dispatching.
* rtems/score/arm.h: Improved the CPU model name determination.
* rtems/score/cpu.h: Improved interrupt disable/enable functions.
* netinet/in.h, netinet/ip.h, netinet/ip_var.h, netinet/tcp.h:
Modified to added packed attribute.o
* cpu_asm.S: Added SR_IEO to context restore to fix isr disabled
deadlock caused by interrupt arriving while dispatching.
* macros/rtems/score/object.inl: Corrected typos in
_Objects_Open, _Objects_Close, and _Objects_Namespace_remove.
* macros/rtems/score/object.inl: Corrected implementation of
to be consistent with the inline implementation.
* src/dpmemident.c, src/msgqident.c, src/partident.c,
src/ratemonident.c, src/regionident.c, src/semident.c,
src/timerident.c: Corrected use of name parameter to
be consistent with fixes implemented to string name processing
which were committed with the POSIX Message Queue update.
* include/rtems/posix/cancel.h, src/cancel.c, src/cancelrun.c,
src/mqueue.c, src/pthread.c, src/semaphore.c, src/setcancelstate.c,
src/setcanceltype.c, src/testcancel.c: Per PR164, corrected the
behavior of thread cancellation and did some cleanup as a side-effect.
* cpu.c, irq.c, rtems/score/cpu.h: Filled in something that was
marked XXX.
* rtems/score/cpu.h: Filled in something that was marked XXX.
* automake/multilib.am: Add install-multi.
* aclocal/rtems-top.m4: Reflect new RTEMS_TOPdir to detecting
version.m4.
Add --with-project-root.
Reflect --with-project-root to setting up PROJECT_ROOT.
* aclocal/env-rtemscpu.m4: Reflect new RTEMS_TOPdir (HACK).
* aclocal/check-cpu.m4: Reflect new RTEMS_TOPdir.
* aclocal/check-bsps.m4: Reflect new RTEMS_TOPdir.
* configure.ac: RTEMS_TOP(..).
