Change the chain order relation to use a directly specified left hand
side value. This is similar to _RBTree_Insert_inline() and helps the
compiler to better optimize the code.
Update #3059.
Update #3170.
Update #3199.
The previous vprintk() implementation had a questionable licence header,
lacks support for the 'z' and 'j' format specifiers, is not robust
against invalid format specifiers, uses a global variable for output.
Replace it with a stripped down version of the FreeBSD kernel kvprintf()
function.
The new implementation allows a low overhead rtems_snprintf() if
necessary.
Update #3199.
Close #3216.
Close #3205.
* Use #ifdefs for 32/64 bit code
* Use unsigned long which is 32-bit on riscv32 and 64-bit on riscv64 (register size)
* Move the code to a new shared riscv folder to be shared between riscv32 and riscv64
* Rename RTEMS_CPU extracted from command line to shared riscv target s/riscv*/riscv
Update #3109
Update #3170.
Update #3199.
Statically initialize it to use printk().
Update #3170.
Update #3199.
Update #3109.
In case the user provides a stack with address and size, then do not
alter the stack size.
Close #3211.
There is no need to pass in the order relation since the scheduled
threads reside on an already ordered chain. The caller will decide what
to do with the lowest scheduled thread.
Limitations:
* NO FPU support [TODO]
Update #3109
Reject non-positive CONFIGURE_MICROSECONDS_PER_TICK values.
Add macro implementation for rtems_clock_get_ticks_per_second() for
C/C++ to avoid the function call overhead. A
rtems_clock_get_ticks_per_second() is still provided for language
bindings (e.g. Ada).
Update #3117.
Update #3182.
Rename _Thread_queue_Context_set_do_nothing_enqueue_callout() into
_Thread_queue_Context_set_enqueue_do_nothing_extra(). More
_Thread_queue_Context_set_enqueue_*() functions will follow.
Update #3117.
Update #3182.
Update #3117.
Update #3182.
Update #3117.
Update #3182.
Update #3117.
Update #3182.
Move it from the configuration to a separate variable.
Update #3117.
Update #3182.
Update #3117.
Update #3182.
Update #3117.
Update #3182.
Update #3117.
Update #3182.
Rename _Watchdog_Ticks_from_*() to _Watchdog_Realtime_from_*().
This highlights that these routines are used for the CLOCK_REALTIME
watchdogs (in contrast to CLOCK_MONOTONIC).
Update #3117.
Update #3182.
A non-integer clock ticks per second value may lead to inaccurate time
format conversions.
Update #3117.
Update #3182.
Remove the cast so that it can be used in C pre-processor directives.
Update #3117.
Update #3182.
This value is frequently used. Avoid the function call overhead and the
integer division at run-time.
Update #3117.
Update #3182.
Replace _Thread_Timer_insert_monotonic() with
_Thread_Add_timeout_ticks().
Update #3117.
Update #3182.
Update #2514.
Update #2514.
Move unblocked signals initialization to pthread_create().
Update #2514.
Move sporadic server scheduler parameters to
POSIX_API_Control::Sporadic. Remove redundant scheduler priority
parameter.
Update #2514.
This member is only used by the sporadic server support.
Update #2514.
The thread POSIX API control must be fully initialized in
_POSIX_Threads_Create_extension(), otherwise a pthread_setschedparam()
is broken for all threads not created with pthread_create().
Rename _Watchdog_Per_CPU_insert_monotonic() in
_Watchdog_Per_CPU_insert_ticks().
Update #3117.
Update #3182.
Rename PER_CPU_WATCHDOG_RELATIVE in PER_CPU_WATCHDOG_MONOTONIC to
highlight the corresponding POSIX CLOCK_MONOTONIC.
Rename PER_CPU_WATCHDOG_ABSOLUTE in PER_CPU_WATCHDOG_REALTIME to
highlight the corresponding POSIX CLOCK_REALTIME.
Update #3117.
Update #3182.
Closes #3130.
Update #2740.
Close #3179.
Update #2514.
Update #3179.
Update #2674.
Close #3112.
Close #3113.
Close #3114.
Close #3115.
Close #3116.
Update #3175.
