* | RTEMS: Delete ChangeLog files. | Gedare Bloom | 2013-03-08 | 19 | -31726/+0 |
| | | | | | | | | | This commit deletes all RTEMS ChangeLog files. These files have been abandoned since converting to git version control. The historical data may be recovered by checking out any commit before this one. Most of the contents of these ChangeLog files can also be found in the git log. Two external ChangeLog files, ChangeLog.slac and ChangeLog.zlib, remain. | ||||
* | cpukit moxie: Style corrections | Joel Sherrill | 2013-02-28 | 2 | -71/+7 |
* | Common file changes in support of Moxie port | Anthony Green | 2013-02-28 | 3 | -1/+3 |
| | | | | Signed-off-by: Anthony Green <green@moxielogic.com> | ||||
* | Add Moxie CPU support | Anthony Green | 2013-02-28 | 9 | -0/+1647 |
* | dosfs: PR2091: Fix warning | Andreas Heinig | 2013-02-27 | 1 | -2/+2 |
* | IMFS: PR2093: Fix warning | Sebastian Huber | 2013-02-27 | 1 | -3/+2 |
* | dosfs: PR2092: Delete unused function | Andreas Heinig | 2013-02-27 | 1 | -32/+0 |
* | PR2090: Fix warning in threadqdequeuepriority.c | Andreas Heinig | 2013-02-26 | 1 | -0/+1 |
* | add __ARM_ARCH_6ZK__ to cpukit/score/cpu/arm/rtems/score/arm.h | Cudmore, Alan P. (GSFC-5820) | 2013-02-25 | 1 | -0/+4 |
* | libblock: Do resource allocation in one place | Sebastian Huber | 2013-02-21 | 1 | -115/+153 |
| | | | | | | | All resource allocations take place in rtems_bdbuf_init() now. After rtems_bdbuf_init() no fatal errors can happen due to configuration errors or resource limits. This makes it easier to detect configuration errors for users. | ||||
* | dosfs: Fix file length update | Sebastian Huber | 2013-02-20 | 1 | -2/+3 |
* | dosfs: Start scan with a valid data cluster | Sebastian Huber | 2013-02-15 | 1 | -26/+16 |
| | | | | | Simpify the loop. Set last cluster to an undefined value in case no free cluster exists. | ||||
* | dosfs: Fix file extend | Sebastian Huber | 2013-02-15 | 1 | -23/+24 |
| | | | | | | Only append a valid cluster chain (cluster added > 0), otherwise we overwrite the root directory cluster (cluster 0) of a FAT12 or FAT16 with arbitrary data. | ||||
* | dosfs: Ensure valid data cluster count | Sebastian Huber | 2013-02-15 | 1 | -1/+6 |
* | Conditionally install atomic-headers. | Ralf Corsépius | 2013-02-14 | 4 | -2/+8 |
* | Add RTEMS_CHECK_ATOMIC, RTEMS_CPUOPT([RTEMS_ATOMIC]), AM_CONDITIONAL ATOMIC. | Ralf Corsépius | 2013-02-14 | 1 | -0/+7 |
* | New. | Ralf Corsépius | 2013-02-14 | 1 | -0/+13 |
* | Include <stdint.h> | Ralf Corsépius | 2013-02-14 | 1 | -0/+2 |
* | ftpd: Go back to the root directory | Sebastian Huber | 2013-02-13 | 1 | -0/+8 |
* | score: use new alignment routine in object extend information. | Gedare Bloom | 2013-02-12 | 1 | -12/+16 |
* | score: New routines to align addresses up or down. | Gedare Bloom | 2013-02-12 | 1 | -0/+44 |
* | sapi: PR1911: Add CONFIGURE_DISABLE_BSP_SETTINGS | Sebastian Huber | 2013-02-12 | 2 | -0/+16 |
* | score: Add and use rtems_assert_context | Sebastian Huber | 2013-02-12 | 3 | -2/+21 |
* | PR1560: _Objects_Extend_information improper alignment | Gedare Bloom | 2013-02-11 | 1 | -5/+18 |
| | | | | | | _Objects_Extend_information uses a sizeof(uint32_t) offset that leads to improper alignment in case the CPU (actually, heap) alignment is 8 or higher. The problem is solved by adding enough padding to align the sub-tables. | ||||
* | score: atomic support for RTEMS. Cleanup. | WeiY | 2013-02-07 | 3 | -226/+218 |
* | score: atomic support for RTEMS. Atomic operations for PowerPC. | WeiY | 2013-02-07 | 1 | -0/+537 |
* | score: atomic support for RTEMS. Atomic operations for i386. | WeiY | 2013-02-07 | 1 | -0/+341 |
* | score: atomic support for RTEMS. Generic atomic operations API definition. | WeiY | 2013-02-07 | 4 | -0/+876 |
* | score: atomic support for RTEMS automake and autoconf changes | WeiY | 2013-02-07 | 8 | -1/+30 |
* | rtems: Revert documentation changes | Sebastian Huber | 2013-02-06 | 1 | -5/+5 |
* | dosfs: Always release the buffers | Sebastian Huber | 2013-01-30 | 1 | -22/+23 |
| | | | | | Release the buffers also if this is not the last reference to the file object since otherwise we may hold modified data indefinitely. | ||||
* | ftpd: Check the root and current directory change | Sebastian Huber | 2013-01-30 | 1 | -20/+28 |
| | | | | | | Only continue the session if the root and current directory change was successful, otherwise the FTP server may access restricted file system areas. | ||||
* | ftpfs: Fix SIZE command handling | Sebastian Huber | 2013-01-28 | 1 | -76/+98 |
| | | | | | | | It is invalid to issue a SIZE command once a data transfer is in progress. For reads we issue the SIZE command before the RETR command and get a snapshot of the file size. For writes the file size is initialized to zero and incremented for each write chunk. | ||||
* | Move <memory.h> and <sys/uio.h> to non-networking directory | Joel Sherrill | 2013-01-23 | 7 | -28/+120 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | These two header files were installed from libnetworking even when networking was disabled. This patch moves them to a non-networking location and updates uio.h to match the FreeBSD 8.x source being used for the USB stack and TCP/IP stack upgrade. - cpukit/include/memory.h Move from cpukit/libnetworking/memory.h. No changes - cpukit/include/sys/uio.h Move from cpukit/libnetworking/sys/uio.h. Replace with FreeBSD 8.x version. - cpukit/include/sys/_iovec.h New. FreeBSD 8.x file supporting <sys/uio.h>. - cpukit/Makefile.am Reflect movement of <memory.h> and <sys/uio.h>. - cpukit/preinstall.am Regenerate - cpukit/libnetworking/nfs/bootp_subr.c Eliminate use of uio_procp field no longer in FreeBSD structure. This field was set and never read so eliminating the set has no impact. | ||||
* | NIOS2: Fix register restore sequence in epilogue | Sebastian Huber | 2013-01-14 | 1 | -3/+3 |
| | | | | | This fix is critical. The previous implementation leads to system corruption. | ||||
* | cpukit: Fix many Doxygen warnings | Joel Sherrill | 2013-01-10 | 18 | -59/+66 |
* | devfs: Doxygen Warning Removal and Cleanup | Joel Sherrill | 2013-01-10 | 1 | -41/+56 |
* | cpukit: Use Consistent Beginning of Doxygen Group Notation | Joel Sherrill | 2013-01-10 | 164 | -405/+290 |
| | | | | | This is the result of a sed script which converts all uses of @{ into a consistent form. | ||||
* | cpukit: Add EOL on files missing EOL at EOF | Joel Sherrill | 2013-01-10 | 139 | -139/+139 |
* | rfs: Doxygen group cannot have a dash in it | Joel Sherrill | 2013-01-10 | 21 | -21/+21 |
| | | | | Change rtems-rfs to rtems_rfs | ||||
* | cpukit/posix: Doxygen group is POSIXAPI | Joel Sherrill | 2013-01-10 | 179 | -184/+180 |
* | cpukit: Doxygen group fixes and many warnings addressed | Joel Sherrill | 2013-01-10 | 67 | -223/+210 |
| | | | | | | | The output of the modules.html is much improved. Most filesystem and POSIX API related groups are properly nested. Some formatting issues were addressed as were multiple inconsistencies. | ||||
* | score: Doxygen Clean Up Task #14 | Alex Ivanov | 2013-01-10 | 20 | -30/+290 |
* | score: Doxygen Clean Up Task #12 | Alex Ivanov | 2013-01-10 | 20 | -134/+446 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/8110207 | ||||
* | rtems: Avoid NULL pointer access | Sebastian Huber | 2013-01-10 | 1 | -5/+7 |
| | | | | | The _MPCI_table may be NULL in case multiprocessing is disabled in the application configuration. | ||||
* | IMFS: Documentation | Sebastian Huber | 2013-01-09 | 1 | -23/+36 |
* | libcsupport: Documentation | Sebastian Huber | 2013-01-09 | 1 | -6/+9 |
* | libcsupport: Documentation | Sebastian Huber | 2013-01-09 | 1 | -35/+22 |
* | sapi: Documentation | Sebastian Huber | 2013-01-09 | 1 | -15/+16 |
* | nfsclient: Return an error status in nfsInit() | Sebastian Huber | 2013-01-09 | 2 | -50/+84 |
| | | | | | Avoid assert() and use proper cleanup if nfsInit() fails to allocate a resource. |
