* src/imfs/Makefile.am: Cleanup.
* arpa/Makefile.am: Remove stray lines.
* support/new_exception_processing/configure.ac,
support/new_exception_processing/rtems/score/c_isr.inl,
support/new_exception_processing/rtems/score/cpu.h,
support/old_exception_processing/configure.ac,
support/old_exception_processing/rtems/score/c_isr.inl,
support/old_exception_processing/rtems/score/cpu.h,
support/old_exception_processing/rtems/score/ppc_offs.h: New files
missed in previous commit.
* src/threadhandler.c: When __USE__MAIN__ is defined by the toolset,
invoke the global constructors via __main. Reported as tested by
Alexandra Kossovsky <sasha@oktet.ru> and Victor V. Vengerov
<vvv@oktet.ru> in conjunction with a new set of tool RPMs
(gcc2.95.3newlib1.9.0-3). This was tracked as GNATS PR tools/84.
* shared/ppc.h: The mpc8260 uses the new exception processing model
and thus does not need to define PPC_USE_SPRG.
* shared/ppc.h: mpc8260 has double FPU not single FPU.
process was captured as PR50.
* shared/asm.h, shared/ppc.h: Added PPC405 support.
Reported by Ibragimov Ilya <ibr@oktet.ru> and tracked as PR49.
* src/imfs/imfs_directory.c: Do not calculate the offset twice.
Reported by Ibragimov Ilya <ibr@oktet.ru> and tracked as PR63.
* libc/chdir.c: Check for search/execute permissions on chdir.
This requires passing RTEMS_LIBIO_PERMS_SEARCH to
rtems_filesystem_evaluate_path().
Discovered while fixing PR36 reported by Todor.Todorov@barco.com.
* include/rtems/itron/object.h: Corrected _ITRON_Objects_Get()
to use _Objects_Get_by_index().
Reported by Todor.Todorov@barco.com and tracked as PR36.
* include/rtems/score/object.h: Added prototype for
* src/objectget.c, src/objectgetisr.c: Corrected procedure for
getting index from Id so it is correct and optimal for both single
and multiprocessor configurations.
* src/imfs/imfs_load_tar.c: Minor modification so this will
compile with gcc-2.95.3 with the arguments "-m5200 -O4".
* libc/libio.c: Cleanup of initialization per suggestion from
Eric Norum.
* libc/unmount.c: Primarily restructuring and clean up to address
procedures which did not do what their name implied. Also addressed
problem situation where unmount fails and the filesystem was
inconsistent. The mounted filesystem could have been left hanging.
* libc/libio.c: Initialize more fields to NULL/0 during initialiation.
* include/rtems/libio_.h: Fix freenode macro so it works for sockets
which do not have the full set of filesystem operations and are
initialized via something other than open().
* macros/rtems/rtems/asr.nil: Fixed typo.
* macros/Makefile.am: Replace INLINES w/ MACROS (Fix stupid typo in
previous patch).
* shared/ppc.h: Added mpc8260 support.
* src/threadhandler.c: Use __USE_INIT_FINI__ since USE_INIT_FINI
pollutes the application namespace.
* libc/open.c, libc/close.c: Moved freenode from open to
close.
* lib/tftpDriver.c: Properly handles ../ components in chdir() and
open() operations within the TFTP file system.
* These changes were discussed and reviewed by many people but the
primary people were Jennifer Averett <jennifer@OARcorp.com>
and Eugeny Mints <jack@oktet.ru>.
* libc/utime.c: Add missing call to rtems_filesystem_freenode()
at verification that utime is supported by the filesystem.
* libc/link.c: Remove calls to freenode when the node was
not successfully allocated.
* libc/unmount.c: In the method file_systems_below_this_mountpoint()
added calls to correctly free fs_root_loc when a failure occurs.
* libc/open.c: Add freenode calls upon failure.
* libc/open.c, lib/libc/close.c: (PENDING -- NOT INCLUDED THIS TIMER)
Modifications the move the freenode from open() to close() (also part
of this patch) are pending further discussion.
* configure.ac: Use RTEMS_CPU_SUBDIRS to make autoconf-2.52 happy.
* .cvsignore: Add stamp-h.in.
* include/Makefile.am: Fixed path to cpuopts-tmp.h.
* imfs/imfs_load_tar.c: Changed the code around to remove an
internal compiler error on the Coldfire target.
* include/confdefs.h, include/rtems/config.h, include/rtems/io.h,
optman/no-io.c, src/exinit.c, src/io.c: Added a device driver
register/unregister interface to allow device drivers to be
installed and removed at runtime. This means you do not need devices
present in the device table when you build.
* include/zilog/Makefile.am: Remove.
* include/motorola/Makefile.am: Remove.
* include/sys/Makefile.am: Remove.
* include/Makefile.am: Handle subdirs, require automake-1.5
* configure.ac: Use AC_CONFIG_SUBDIRS for posix and itron.
Reflect changes to configuration of rtems, score and sapi subdirs.
* include/rtems/rtems/Makefile.am: Remove.
* inline/rtems/rtems/Makefile.am: Remove.
* macros/rtems/rtems/Makefile.am: Remove.
* macros: Handle subdirs, require automake-1.5.
* macros/rtems/score/Makefile.am: Remove.
* macros/Makefile.am: Handle subdirs, require automake-1.5.
* inline/rtems/score/Makefile.am: Remove.
* include/rtems/posix/Makefile.am: Remove.
* include/Makefile.am: Handle subdirs.
* inline/rtems/posix/Makefile.am: Remove.
* inline/Makefile.am: Handle subdirs.
* macros/rtems/posix/Makefile.am: Remove.
* macros/Makefile.am: Handle subdirs.
* include/itronsys/Makefile.am: Remove.
* include/rtems/itron/Makefile.am: Remove.
* inline/rtems/itron/Makefile.am: Remove.
* macros/rtems/itron/Makefile.am: Remove.
* include/Makefile.am: handle subdirs.
* inline/Makefile.am: handle subdirs.
* macros/Makefile.am: handle subdirs.
* cpu.c: Fix #ifdefs, add missing #endif.
* include/chain.h: Fixed typo.
* rootfs/mkrootfs.c, rootfs/mkrootfs.h: Fixed typo.
* shared/ppctypes.h: Fixed typo.
* include/rtems/directives.h: Fixed typo.
* configure.in: Remove.
* asm.h, cpu.c, rtems.c, rtems/score/cpu.h, rtems/score/sh.h,
rtems/score/sh_io.h, rtems/score/shtypes.h: Consistency changes
and made sure there were no includes from the libcpu tree.
* cpu.c, rtems/score/cpu.h, rtems/score/sh.h: Modified to
support SH4. Reviewed by Ralf Corsepius <corsepiu@faw.uni-ulm.de>
who did the original SH port.
* cpu_asm.S: _CPU_Context_save_fp in was incorrectly in conditional
compilation block with (CPU_HARDWARE_FP == FALSE). Reported by
Wayne Bullaughey <wayne@wmi.com>.
* Update to stable working state. Congratulations Mike! :)
* modem_example: Directory removed.
* modem_example/16550.h, modem_example/README, modem_example/modem.c,
modem_example/modem.h, modem_example/ppp.c, modem_example/ppp.h,
modem_example/pppcompress.c: Files removed.
* pppd/example/pppd.options: New file.
* pppd/README, pppd/STATUS, pppd/cbcp.c, pppd/cbcp.h, pppd/chat.c,
pppd/pppd.h, pppd/rtemsmain.c: Updated.
* libc/termios.c: Fixed a memory leak in the termios
software. Basically the tty open function was allocating an input
raw buffer, an output raw buffer, and a cooked buffer that were
not getting released. I have attached a patch for the latest
snapshot. The patch also has a fix to ensure the tty link list
is updated correctly when a tty is closed.
* src/imfs/imfs_getchild.c: Correct length of static string
as reported by Ibragimov Ilya <ibr@oktet.ru>.
