path: root/cpukit (follow)
* 2003-12-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-024-4/+4
| | | | | | | | * pppd/Makefile.am: Remove all-local: $(ARCH). * rtems_servers/Makefile.am: Remove all-local: $(ARCH). * rtems_telnetd/Makefile.am: Remove all-local: $(ARCH). * rtems_webserver/Makefile.am: Remove all-local: $(ARCH). * wrapup/Makefile.am: Remove all-local: $(ARCH).
* 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-014-51/+114
| | | | | | | | | * Makefile.am: Reformat. Apply dirstamps to preinstallation. * pppd/Makefile.am: Ditto. * rtems_servers/Makefile.am: Ditto. * rtems_telnetd/Makefile.am: Ditto. * rtems_webserver/Makefile.am: Ditto. * wrapup/Makefile.am: Ditto.
* 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-0114-190/+272
| | | | * Makefile.am:Restore further parts having been lost.
* 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-0114-57/+763
| | | | * Makefile.am: Restore file having been broken in last commit.
* 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-0126-827/+78
| | | | * Makefile.am: Remove TMPINSTALL_FILES.
* 2003-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-012-2/+6
| | | | | * Makefile.am: Add $(dirstamp) to preinstallation rules. Remove MACROS.
* 2003-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-013-7/+15
| | | | | * automake/compile.am: Add $(ARCH)/$(dirstamp) rules. * wrapup/Makefile.am: Reflect $(dirstamp) changes.
* 2003-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-012-53/+71
| | | | | * Makefile.am: Add $(dirstamp) to compilation rules. Fix misc. typos.
* 2003-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-014-4/+12
* 2003-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-3010-34/+60
* 2003-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-304-4/+16
| | | | | * Makefile.am: Add $(dirstamp) to compilation rules. Add AM_CPPFLAGS += -I$(top_builddir).
* 2003-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-302-10/+15
* 2003-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-302-1/+5
| | | | * Makefile.am: Fix libc_OBJS.
* 2003-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-302-159/+163
* 2003-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-302-218/+236
| | | | | * Makefile.am: Add $(dirstamp) to preinstallation rules. Restore libc/$(ARCH)/lib.a.
* 2003-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-3010-158/+199
* 2003-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-302-10/+30
| | | | | * Makefile.am: Preinstall adainclude_HEADERS. Add $(dirstamp) to preinstallation rules.
* 2003-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-308-386/+409
* 2003-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-3028-190/+332
* 2003-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-303-0/+41
| | | | | | * aclocal/lead-dot.m4: New (from automake-1.7f). * aclocal/rtems-top.m4: Require AM_SET_LEADING_DOT. Add AC_SUBST(dirstamp).
* 2003-11-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-282-2/+5
| | | | | * configure.ac: Reflect having removed libnetworking/libc/Makefile.am, libnetworking/lib/Makefile.am.
* 2003-11-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-284-104/+100
| | | | | | * libc/Makefile.am: Remove. * lib/Makefile.am: Remove. * Makefile.am: Merge-in the Makefile.ams above.
* 2003-11-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-282-18/+113
* 2003-11-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-282-13/+4
| | | | * configure.ac: Reflect changes to libmisc/*.
* 2003-11-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-2815-561/+290
| | | | | | | | | | | | | | | | | * capture/Makefile.am: Remove. * cpuuse/Makefile.am: Remove. * devnull/Makefile.am: Remove. * dummy/Makefile.am: Remove. * dumpbuf/Makefile.am: Remove. * fsmount/Makefile.am: Remove. * monitor/Makefile.am: Remove. * mw-fb/Makefile.am: Remove. * rtmonuse/Makefile.am: Remove. * serdbg/Makefile.am: Remove. * shell/Makefile.am: Remove. * stackchk/Makefile.am: Remove. * untar/Makefile.am: Remove. * Makefile.am: Merge-in the Makefile.ams above.
* 2003-11-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-282-1/+26
| | | | * wrapup/Makefile.am: Merge-in former libmisc/wrapup/Makefile.am
* 2003-11-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-284-50/+7
| | | | | | * wrapup/Makefile.am: Remove. * wrapup/.cvsignore: Remove. * Makefile.am: Reflect changes above.
* 2003-11-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-281-0/+1
| | | | * configure.ac: Remove libmisc/wrapup/Makefile.
* 2003-11-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-281-4/+0
| | | | * configure.ac: Reflect changes to libfs Makefile.ams.
* 2003-11-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-271-0/+4
* 2003-11-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-275-125/+107
| | | | | | | * Makefile.am: Merge-in src/Makefile.am, src/imfs/Makefile.am, src/dosfs/Makefile.am. * src/Makefile.am, src/imfs/Makefile.am, src/dosfs/Makefile.am: Removed.
* 2003-11-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-276-63/+36
| | | | | | | | | | * configure.ac: Use here-documents to generate cpuopts.tmp. Various fixes and changes to argument processing. Reflect changes to librpc Makefile.ams. * acinclude.m4: Use here-documents to generate cpuopts.tmp. * aclocal/check-itron.m4: Remove HAS_IRON_API. * aclocal/check-multiprocessing.m4: Remove HAS_MP. * aclocal/check-posix.m4: Remove HAS_POSIX_API.
* 2003-11-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-275-117/+164
| | | | | | | | * src/rpc/Makefile.am, src/xdr/Makefile.am, src/Makefile.am: Removed. * Makefile.am: Merge-in src/rpc/Makefile.am, src/xdr/Makefile.am, src/Makefile.am. Various fixes. Reformat.
* 2003-11-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-2711-22/+34
| | | | | | | | | | | | * include/rpc/rpc.hinclude/rpc/rpc.h: Rename struct rtems_rpc_task_variables into struct _rtems_rpc_task_variables (Avoid symbol conflict between struct and variable). struct _rtems_rpc_task_variables *rtems_rpc_task_variables; Reflect changes above. * src/rpc/clnt_perror.c, src/rpc/clnt_raw.c, src/rpc/clnt_simple.c, src/rpc/rpcdname.c, src/rpc/rtems_rpc.c, src/rpc/svc.c, src/rpc/svc_auth.c, src/rpc/svc_raw.c, src/rpc/svc_simple.c: Reflect changes above.
* 2003-11-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-11-262-0/+34
| | | | | | PR 524/filesystem * src/newlibc.c: Address 1K buffer leak from incomplete cleanup of newlib reentrancy handler.
* 2003-11-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-11-262-11/+24
| | | | | | | PR 523/filesystem * src/malloc.c: Make malloc family safer for use from ISRs and dispatching critical sections. If in a critical section while doing a free(), then the free is deferred until the next malloc() attempt.
* 2003-11-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-261-16/+24
| | | | | | | | * acinclude.m4: New. * configure.ac: Don't use AUTOHEADER to generate cpuopts.h. Add local autoheader config.h. * aclocal/canonical-target-name.m4: Require AC_CANONICAL_HOST. * aclocal/enable-inlines.m4: Remove USE_MACROS (Unused).
* 2003-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-2623-28/+43
| | | | | | | | | | | | | | | * aclocal/canonicalize-tools.m4, aclocal/check-itron.m4, aclocal/check-multiprocessing.m4, aclocal/check-newlib.m4, aclocal/check-posix.m4, aclocal/check-rtems-debug.m4, aclocal/check-tool.m4, aclocal/enable-bare.m4, aclocal/enable-inlines.m4, aclocal/enable-itron.m4, aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4, aclocal/enable-posix.m4, aclocal/enable-rtems-debug.m4, aclocal/env-rtemscpu.m4, aclocal/gcc-isystem.m4, aclocal/gcc-pipe.m4, aclocal/multi.m4, aclocal/multilib.m4, aclocal/prog-cc.m4, aclocal/rtems-top.m4, aclocal/sysv-ipc.m4: Fix underquoting to silence automake-1.8.
* 2003-11-25 Jennifer Averett <jennifer@OARcorp.com>Jennifer Averett2003-11-255-0/+48
| | | | | | PR 519/filesystem * include/rtems/libio_.h, src/eval.c, src/rmdir.c, src/unlink.c: Check write permissions in parent directory for file or directory delete
* 2003-11-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-11-252-3/+8
| | | | | | PR 526/rtems * src/threadcreateidle.c: Idle task name should be a string and PR484 broke this.
* 2003-11-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-11-252-0/+29
| | | | | PR 528/rtems_misc * rtems.ads: Add task variables to Ada binding.
* 2003-11-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-244-20/+16
| | | | | | | * configure.ac: Use RTEMS_INLINES instead of USE_INLINES. Elimimate INLINESdir. * aclocal/enable-inlines.m4: Ditto. Remove RTEMS_USE_MACROS. * .cvsignore: Add config.h.in.
* 2003-11-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-237-7/+17
| | | | | | | | | | PR 525/rtems * include/rtems/system.h: Use RTEMS_INLINES instead of USE_INLINES. * include/rtems/score/chain.h: Ditto. * include/rtems/score/thread.h: Ditto. * src/chain.c: Ditto. * src/coremutexseize.c: Ditto. * src/threadget.c: Ditto.
* 2003-11-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-232-0/+9
| | | | * configure.ac: Make RTEMS_DEBUG an RTEMS_CPUOPT.
* 2003-11-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-232-11/+5
| | | | * Makefile.am: Remove all LIB-related rules.
* 2003-11-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-232-100/+406
| | | | * Makefile.am: Don't use gmake to preinstall.
* 2003-11-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-2328-288/+486
| | | | * Makefile.am: Don't use gmake rules for preinstallation.
* 2003-11-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-232-32/+60
| | | | * Makefile.am: Reworked.
* 2003-11-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-222-82/+342
* 2003-11-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-222-13/+33
