* | | 2005-11-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-11-08 | 3 | -2/+14 | |
| | | | | | | | | | | | | | | | | * libnetworking/net/if.h: Add forward reference declaration to struct mbuf so ifru_tap callback is properly typed. * libnetworking/rtems/rtems_bsdnet.h: Add definition of _BSD_VISIBLE which needs to be defined so various pieces of the .h files are visible to device drives. | |||||
* | | 2005-11-08 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-08 | 1 | -0/+6 | |
| | | | | | | | | | | | | * libnetworking/Makefile.am: Comment out using rtems/rtems_mii_ioctl.h, rtems/rtems_mii_ioctl.c, rtems/rtems_mii_ioctl_kern.c. | |||||
* | | Fixed formatting. | Joel Sherrill | 2005-11-07 | 1 | -6/+6 | |
* | | 2005-11-07 Michael Siers <mikes@poliac.com> | Joel Sherrill | 2005-11-07 | 3 | -0/+27 | |
| | | | | | | | | | | * pppd/rtemspppd.c, pppd/rtemspppd.h: Per confirmation from Michael add missing copyright notice. | |||||
* | | 2005-11-06 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-06 | 1 | -2/+10 | |
| | | | | | | | | | | | | | | | | * libi2c/libi2c.c: Include config.h. * libi2c/libi2c.c, libi2c/libi2c.h, libnetworking/rtems/rtems_mii_ioctl.h, libnetworking/rtems/rtems_mii_ioctl_kern.c, score/src/heap.c: Eliminate obsolete types. | |||||
* | | Eliminate obsolete types. | Ralf Corsepius | 2005-11-06 | 5 | -16/+20 | |
* | | 2005-11-03 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-03 | 2 | -1/+4 | |
| | | | | | | | | * httpd/Makefile.am: Remove bogus noinst_LIBRARIES. | |||||
* | | 2005-11-02 straumanatslacdotstanford.edu | Till Straumann | 2005-11-03 | 4 | -0/+430 | |
| | | | | | | | | | | | | | | | | | | * libnetworking/Makefile.am, libnetworking/preinstall.am: Added simple implementation of ethernet media ioctl SIOCSIFMEDIA/SIOCGIFMEDIA for mii compliant phys. * libnetworking/rtems/rtems_mii_ioctl.c, libnetworking/rtems/rtems_mii_ioctl.h, libnetworking/rtems/rtems_mii_ioctl_kern.c: New files. | |||||
* | | 2005-11-02 straumanatslacdotstanford.edu | Till Straumann | 2005-11-03 | 9 | -0/+1338 | |
| | | | | | | | | | | | | | | | | * libi2c/Makefile.am, libi2c/Makefile.in, libi2c/libi2c.c, libi2c/libi2c.h: New files. * Makefile.am, configure.ac, preinstall.am, wrapup/Makefile.am: added a simple API/library for i2c devices and drivers for i2c 2-byte eeproms and a ds1621 temperature sensor; API is documented in libi2c.h | |||||
* | | 2005-11-02 straumanatslacdotstanford.edu | Till Straumann | 2005-11-02 | 2 | -0/+41 | |
| | | | | | | | | | | * rtems/powerpc/registers.h: recognize mpc7457 CPU; added definitions for high bats (#4..7) on 7450 CPUs | |||||
* | | 2005-11-02 Fredic Praca <freebsd-fr.org> | Joel Sherrill | 2005-11-02 | 2 | -7/+13 | |
| | | | | | | | | | | | | PR 842/networking * libnetworking/libc/gethostbydns.c: Avoid use of dprintf(). Rename dprintf to debugprintf(). | |||||
* | | 2005-11-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-02 | 3 | -6405/+6 | |
| | | | | | | | | | | | | * libnetworking/net/zlib.c: Remove. * libnetworking/net/zlib.h: Remove. * libnetworking/Makefile.am: Reflect changes above. | |||||
* | | 2005-11-01 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-01 | 2 | -1/+5 | |
| | | | | | | | | * pppd/Makefile.am: Fix typo. | |||||
* | | 2005-10-31 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-31 | 2 | -4/+8 | |
| | | | | | | | | | | PR 840/rtems: * include/rtems/irq.h: Fix several typos. | |||||
* | | 2005-10-30 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-30 | 1 | -0/+5 | |
| | | | | | | | | | | * configure.ac: Add zlib. * Makefile.am: Add zlib. | |||||
* | | Add zlib. | Ralf Corsepius | 2005-10-30 | 2 | -0/+3 | |
* | | 2005-10-30 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-30 | 2 | -1/+8 | |
| | | | | | | | | | | * zconf.h: Hard-code using unistd.h. Hard-code Z_PREFIX. | |||||
* | | 2005-10-28 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-28 | 1 | -0/+1 | |
| | | | | | | | | * zconf.in.h: Remove (Unused). | |||||
* | | Remove (Unused) | Ralf Corsepius | 2005-10-28 | 1 | -330/+0 | |
* | | 2005-10-28 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-28 | 1 | -0/+5 | |
| | | | | | | | | | | * zconf.h: Use uint_least*_t types. * crc32.c, zutil.c, zutil.h: Misc. type fixes. | |||||
* | | Misc. type fixes | Ralf Corsepius | 2005-10-28 | 3 | -9/+9 | |
* | | Use uint_least*_t types. | Ralf Corsepius | 2005-10-28 | 1 | -0/+9 | |
| | | | | | | | | | | * Makefile.am: New. * preinstall.am: New. | |||||
* | | New. | Ralf Corsepius | 2005-10-28 | 2 | -0/+72 | |
* | | * adler32.c, compress.c, crc32.c, deflate.c, deflate.h, gzio.c, | Ralf Corsepius | 2005-10-28 | 1 | -0/+6 | |
| | | | | | | | | | | trees.c, uncompr.c, zconf.h, zconf.in.h, zutil.c, zutil.h: Reformat CVS Ids. | |||||
* | | Reformat CVS Ids | Ralf Corsepius | 2005-10-28 | 12 | -12/+12 | |
* | | 2005-10-28 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-28 | 1 | -0/+9 | |
| | | | | | | | | | | | | | | | | | | * ChangeLog.zlib: Renamed version of zlib's ChangeLog. * FAQ, INDEX, README, adler32.c, algorithm.txt, compress.c, crc32.c, crc32.h, deflate.c, deflate.h, gzio.c, infback.c, inffast.c, inffast.h, inffixed.h, inflate.c, inflate.h, trees.c, trees.h, uncompr.c, zconf.h, zconf.in.h, zlib.3, zlib.h, zutil.c, zutil.h, inftrees.h, inftrees.c, ChangeLog: Import from zlib-1.2.2.2.tar.gz. | |||||
* | | Remove. | Ralf Corsepius | 2005-10-28 | 5 | -1639/+0 | |
* | | Rename the original ChangeLog to ChangeLog.zlib | Ralf Corsepius | 2005-10-28 | 1 | -0/+0 | |
* | | Apply FC4's zlib-1.2.2.2-can-2005-2096.patch | Ralf Corsepius | 2005-10-28 | 1 | -1/+1 | |
* | | Apply FC4's zlib-1.2.2.2-can-2005-1849.patch | Ralf Corsepius | 2005-10-28 | 1 | -4/+4 | |
* | | Post-import cleanup | Ralf Corsepius | 2005-10-28 | 147 | -32362/+0 | |
* | | This commit was generated by cvs2svn to compensate for changes in r12486, | Ralf Corsepius | 2005-10-28 | 1 | -9/+9 | |
|\| | | | | | which included commits to RCS files with non-trunk default branches. | |||||
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2005-10-28 | 1 | -9/+9 | |
* | | This commit was generated by cvs2svn to compensate for changes in r12484, | Ralf Corsepius | 2005-10-28 | 3 | -7/+7 | |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2005-10-28 | 3 | -7/+7 | |
* | | This commit was generated by cvs2svn to compensate for changes in r12482, | Ralf Corsepius | 2005-10-28 | 1 | -5/+5 | |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2005-10-28 | 1 | -5/+5 | |
* | | This commit was generated by cvs2svn to compensate for changes in r12480, | Ralf Corsepius | 2005-10-28 | 1 | -2/+2 | |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2005-10-28 | 1 | -2/+2 | |
* | | This commit was generated by cvs2svn to compensate for changes in r12478, | Ralf Corsepius | 2005-10-28 | 1 | -10/+10 | |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2005-10-28 | 1 | -10/+10 | |
* | | This commit was generated by cvs2svn to compensate for changes in r12476, | Ralf Corsepius | 2005-10-28 | 1 | -9/+9 | |
* | | This commit was generated by cvs2svn to compensate for changes in r12474, | Ralf Corsepius | 2005-10-28 | 2 | -13/+13 | |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2005-10-28 | 2 | -13/+13 | |
* | | This commit was generated by cvs2svn to compensate for changes in r12472, | Ralf Corsepius | 2005-10-28 | 1 | -2/+2 | |
* | | This commit was generated by cvs2svn to compensate for changes in r12470, | Ralf Corsepius | 2005-10-28 | 181 | -0/+46633 | |
| * | Import of zlib-1.2.2.2.tar.gz | Ralf Corsepius | 2005-10-28 | 181 | -0/+46633 | |
