* | Added prototype for console_reserve_resources. | Joel Sherrill | 1997-10-23 | 1 | -0/+4 |
* | fixed comment | Joel Sherrill | 1997-10-23 | 1 | -2/+1 |
* | New termios.c from Eric Norum. | Joel Sherrill | 1997-10-23 | 2 | -601/+646 |
| | | | | Added new entry point to add in per physical port resource requirements. | ||||
* | Fixed a number of warnings regarding comparisons between signed and | Joel Sherrill | 1997-10-21 | 4 | -9/+9 |
| | | | | unsigned numbers. | ||||
* | Fixed endian problem in printing object names. | Joel Sherrill | 1997-10-21 | 1 | -0/+5 |
* | Added check that return argument pointer for old_isr_handler was valid. | Joel Sherrill | 1997-10-21 | 1 | -0/+3 |
* | Converted from using a message queue for the raw input queue to using a | Joel Sherrill | 1997-10-21 | 1 | -49/+35 |
| | | | | ring buffer in conjunction with a counting semaphore. | ||||
* | Added termios submission from Eric Norum and Katsutoshi Shibuya. | Joel Sherrill | 1997-10-21 | 1 | -0/+760 |
* | Added termios submission from Eric Norum and Katsutoshi Shibuya. | Joel Sherrill | 1997-10-21 | 1 | -2/+22 |
* | Added casts and fixed line break. | Joel Sherrill | 1997-10-21 | 1 | -2/+3 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 250 | -500/+500 |
* | Fixed comment. | Joel Sherrill | 1997-10-06 | 1 | -1/+1 |
* | Make Post an atomic operation. | Joel Sherrill | 1997-10-06 | 2 | -2/+12 |
* | Added _Thread_Enable_dispatch to already_timedout path on Wait_support. | Joel Sherrill | 1997-10-06 | 1 | -2/+3 |
* | If the specified time period is less than a clock tick, then | Joel Sherrill | 1997-10-05 | 1 | -1/+4 |
| | | | | it is arbitrarily assumed to be 1 clock tick. | ||||
* | fixed typo | Joel Sherrill | 1997-09-30 | 1 | -1/+1 |
* | Fixed typos. | Joel Sherrill | 1997-09-30 | 1 | -1/+1 |
* | Uncommented gettimeofday_r to resolve missing symbol. | Joel Sherrill | 1997-09-21 | 1 | -2/+0 |
* | Cleaned up as part of adding the Monitor test. | Joel Sherrill | 1997-09-21 | 17 | -27/+21 |
* | Bug fix from Eric Norum: | Joel Sherrill | 1997-09-19 | 1 | -1/+0 |
| | | | | | | | | | | | After weeks of trying to figure why my RTEMS/KASQ server crashes now and then I found a nasty bug I introduced in adding multiple-driver support to libio. The bug only affects `add-on' driver classes (like the networking code). Old-style file descriptors were not affected. The bug cleared 32 bytes of memory (unspecified location) whenever a `close' of a socket was performed! I was clearing an IOP I hadn't allocated -- and the pointer wasn't initiallized, either! | ||||
* | updated | Joel Sherrill | 1997-09-16 | 1 | -4/+11 |
* | Fixed IO Manager calls to remove an argument which was used in 3.2.1 | Joel Sherrill | 1997-08-28 | 2 | -64/+9 |
| | | | | but not in newer RTEMS. | ||||
* | Added RTEMS_IO_ERROR status code. | Joel Sherrill | 1997-08-28 | 2 | -1/+3 |
* | Added IO_Error status code and fixed No_Memory error number. | Joel Sherrill | 1997-08-28 | 1 | -3/+5 |
* | Added error numbers and changed default error code from 0 to -1 for | Joel Sherrill | 1997-08-27 | 1 | -7/+9 |
| | | | | error number mapping. | ||||
* | Corrected bug per Katsutoshi Shibuya's report: | Joel Sherrill | 1997-08-22 | 2 | -4/+4 |
| | | | | | | | The definition of "BEGIN_DATA" should not be null; should be ".data". Also, the definition of "BEGIN_BSS" should be ".bss". For this error, the compiled object has codes that write on the text segment area. It is fatal when the code runs on ROM. | ||||
* | Removed assert condition when not initialized or there are 0 periods. | Joel Sherrill | 1997-08-22 | 1 | -0/+5 |
* | Moved reentrant wrappers into their own file. | Joel Sherrill | 1997-08-22 | 1 | -4/+2 |
* | Fixed iop/memory leak bug reported by Dan Dickey. | Joel Sherrill | 1997-08-22 | 1 | -1/+6 |
* | Fixed infinite recursion bug in PTHREAD_MUTEX_INITIALIZER. | Joel Sherrill | 1997-08-22 | 1 | -10/+15 |
* | Added commit about missing support for condition initializer. | Joel Sherrill | 1997-08-22 | 1 | -0/+1 |
* | new implementation of mc68681.h | Joel Sherrill | 1997-08-04 | 1 | -72/+291 |
* | Added GNAT configuration parameters. | Joel Sherrill | 1997-08-04 | 1 | -4/+19 |
* | moved from main include directory | Joel Sherrill | 1997-08-04 | 5 | -0/+478 |
* | Added these files to contain bodies for routines included in the API | Joel Sherrill | 1997-08-02 | 2 | -0/+101 |
| | | | | | but which did not have real bodies. This is necessary for languages like Ada95 which must have real entries in a library for bindings. | ||||
* | Katsutoshi Shibuya (shibuya@mxb.meshnet.or.jp)of BU-Denken Co., Ltd. | Joel Sherrill | 1997-08-01 | 2 | -0/+191 |
| | | | | | | | (Sapporo, Japan) submitted the extended console driver for the MVME162LX BSP and the POSIX tcsetattr() and tcgetattr() routines. This device driver supports four serial ports, cooked IO, and provides a portable base for Zilog 8530 based console drivers. | ||||
* | Merged very large and much appreciated patch from Chris Johns | Joel Sherrill | 1997-07-31 | 2 | -4/+110 |
| | | | | | <cjohns@plessey.com.au>. This patch includes the ods68302 bsp, the RTEMS++ class library, and the rtems++ test. | ||||
* | Added rtems_message_queue_get_number_pending directive. | Joel Sherrill | 1997-07-31 | 4 | -17/+107 |
* | fixed typo | Joel Sherrill | 1997-07-18 | 1 | -4/+4 |
* | Reordered specs. | Joel Sherrill | 1997-07-10 | 1 | -4/+4 |
* | fixed milliseconds and microseconds to tick conversion routines. | Joel Sherrill | 1997-07-10 | 1 | -11/+10 |
* | Repository damaged -- files readded. | Joel Sherrill | 1997-07-09 | 1 | -0/+214 |
* | Changed name from entry to thread_entry to be more compatible with | Joel Sherrill | 1997-07-09 | 2 | -2/+2 |
| | | | | Ada interface where entry is a keyword. | ||||
* | Added postswitch extension. | Joel Sherrill | 1997-07-09 | 1 | -0/+2 |
* | Added post switch extension. | Joel Sherrill | 1997-07-09 | 1 | -0/+5 |
* | Corrected typos and spacing. | Joel Sherrill | 1997-07-09 | 1 | -3/+3 |
* | Added sp, sfc, and fpcsr register defines. | Joel Sherrill | 1997-07-09 | 2 | -0/+8 |
* | Added True and False constants for RTEMS.Boolean types. This necessitated | Joel Sherrill | 1997-06-03 | 2 | -8/+36 |
| | | | | making sure every True/False reference was fully qualified. | ||||
* | Added RTEMS boolean constants. | Joel Sherrill | 1997-06-03 | 1 | -0/+3 |
* | Added Pending_Events and lined up other event constants | Joel Sherrill | 1997-06-03 | 1 | -33/+34 |
