* | Patch from Emmanuel Raguet <raguet@crf.canon.fr>: | Joel Sherrill | 1999-02-18 | 1 | -1/+9 | |
| | | | | | | | You will find enclosed a patch which contains, for Intel PC386 target : - an Ethernet driver for DEC21140 device based boards. - a simple cache management with paging mechanism. | |||||
* | GLobal reentrancy structure is now dynamically initialized. | Joel Sherrill | 1999-02-18 | 1 | -1/+2 | |
* | Patch from Eric Valette <valette@crf.canon.fr> to undo the patch | Joel Sherrill | 1999-02-15 | 1 | -2/+0 | |
| | | | | that added ifdef on the pc386. | |||||
* | POSIX timer support. | Joel Sherrill | 1999-02-10 | 1 | -1/+1 | |
* | Set the read/write offset to 0 when the file is opened. The ACVC had a test | Joel Sherrill | 1999-02-10 | 1 | -0/+1 | |
| | | | | | that performed the sequence open/write/close/open/read/close on a file. It did not get the correct result since the file descriptor was reused. | |||||
* | Corrected multiple places the file size was not being properly updated. | Joel Sherrill | 1999-02-10 | 1 | -2/+8 | |
* | Added getcwd(). | Joel Sherrill | 1999-02-10 | 1 | -0/+280 | |
* | POSIX timer support modifications. | Joel Sherrill | 1999-02-10 | 3 | -4/+16 | |
* | Comments fixed after problem report from Ian Lance Taylor <ian@airs.com>. | Joel Sherrill | 1999-02-10 | 1 | -19/+10 | |
* | Patch from Eric Norum to correct bug induced by select() patch. | Joel Sherrill | 1999-02-05 | 2 | -5/+11 | |
* | Corrected spacing and added some new error checks that were needed | Joel Sherrill | 1999-02-05 | 3 | -24/+34 | |
| | | | | to avoid dereferencing NULLs. | |||||
* | Added printf()'s that can be uncommented to trace MBUF operations. This | Joel Sherrill | 1999-02-04 | 1 | -0/+3 | |
| | | | | is very useful when debugging a device driver. | |||||
* | Modifed to reflect transition from device driver to file system. | Joel Sherrill | 1999-02-04 | 1 | -41/+4 | |
* | Added debug printf()'s that are commented out. Uncommenting these | Joel Sherrill | 1999-02-04 | 1 | -0/+3 | |
| | | | | | | allows one to trace the enqueueing and dequeueing of messages. This can be used to insure that packets are getting to the boundary between the network stack and the device driver. | |||||
* | Added PowerPC specific header checksum code. | Joel Sherrill | 1999-02-04 | 2 | -68/+10 | |
* | Added PowerPC specific header checksum code. | Joel Sherrill | 1999-02-04 | 1 | -4/+61 | |
| | | | | Added volatile to i386 assembly statements in header checksum code. | |||||
* | Debugged and now works except for handling of minor number. | Joel Sherrill | 1999-02-04 | 1 | -313/+429 | |
* | Modified to include comments on how to get TCPDEBUG turned on and | Joel Sherrill | 1999-02-04 | 2 | -1/+11 | |
| | | | | printing messages. | |||||
* | POSIX Timers submitted by Juan Zamorano Flores | Joel Sherrill | 1999-02-03 | 5 | -8/+1011 | |
| | | | | <jzamora@avellano.datsi.fi.upm.es>. | |||||
* | Added debug #define and commented it out. | Joel Sherrill | 1999-02-02 | 1 | -0/+1 | |
* | Added PowerPC specific in_cksum file. | Joel Sherrill | 1999-02-02 | 1 | -0/+4 | |
* | New file. Based on the i386 version. | Joel Sherrill | 1999-02-02 | 2 | -0/+404 | |
* | Prepended macro variables with "_" to avoid name conflicts in expansions. | Joel Sherrill | 1999-01-31 | 1 | -78/+78 | |
* | Split psignal.c into many more files. This reduced the amount of | Joel Sherrill | 1999-01-31 | 21 | -918/+1341 | |
| | | | | | object code that has to be loaded just for initializing the signal manager. | |||||
* | New files added to ease debugging. | Joel Sherrill | 1999-01-31 | 2 | -0/+96 | |
* | Patch from Eric Norum <eric@skatter.usask.ca> to avoid dereferencing a | Joel Sherrill | 1999-01-28 | 1 | -1/+4 | |
| | | | | NULL pointer. | |||||
* | Patch from Eric Norum <eric@skatter.usask.ca> to set more flags in | Joel Sherrill | 1999-01-28 | 1 | -2/+2 | |
| | | | | rtems_bsdnet_makeFdForSocket(). | |||||
* | Added include of <rtems/posix/priority.h> so a macro would expand | Joel Sherrill | 1999-01-26 | 1 | -0/+1 | |
| | | | | and eliminate a link error. | |||||
* | Changed prototype of rtems_bsdnet_makeFdForSocket to (void *) pointer | Joel Sherrill | 1999-01-26 | 1 | -1/+1 | |
| | | | | so that the libc code did not have to know about (struct socket). | |||||
* | Switched from printf() to puts(). | Joel Sherrill | 1999-01-26 | 1 | -1/+1 | |
* | Added libio_sockets.c to hold support routines for networking code. | Joel Sherrill | 1999-01-26 | 1 | -0/+58 | |
* | Split most of POSIX Threads Manager into multiple files. | Joel Sherrill | 1999-01-25 | 30 | -957/+1347 | |
* | Added enough prototypes to allow most of POSIX Threads Manager to be | Joel Sherrill | 1999-01-25 | 1 | -0/+26 | |
| | | | | split into multiple files. | |||||
* | Made to compile after hacking tftp driver into beginnings of a mini-filesystem. | Joel Sherrill | 1999-01-21 | 5 | -39/+299 | |
* | Patch from Eric Norum <eric@skatter.usask.ca> to make m68360.h usable | Joel Sherrill | 1999-01-20 | 2 | -714/+732 | |
| | | | | | | | | outside RTEMS. Comment: I found a couple of places other than RTEMS where I'd like to use the declarations supplied in m68360.h. To make this easier to do, I've redone the declarations in m68360.h to use standard C types. | |||||
* | More general fix based on bug report and patch from Ian Lance Taylor | Joel Sherrill | 1999-01-20 | 14 | -2/+42 | |
| | | | | | | | | | | <ian@airs.com> to fix this problem: There is a small bug in __rtems_close in c/src/lib/libc/libio.c. It does not check whether the file descriptor it is passed is open. This can cause it to make a null dereference if it is passed a file descriptor which is in the valid range but which was not opened, or which was already closed. | |||||
* | Added comments for changing to a filesystem | Joel Sherrill | 1999-01-19 | 1 | -0/+4 | |
* | Per bug report from Jiri Gaisler that RTEMS would no longer build | Joel Sherrill | 1999-01-19 | 1 | -1/+13 | |
| | | | | | with the --disable-posix option, stubs for some routines (_getpid_r and _kill_r) that are normally defined with POSIX were added. | |||||
* | Patch from Jiri Gaisler <jgais@ce.chalmers.se>: | Joel Sherrill | 1999-01-19 | 1 | -0/+2 | |
| | | | | | | | | getting the spurious trap handling to work required a couple more fixes - I have attached a patch against rtems-4.0.0 with the necessary changes. I also added functionality so that the address of the trapped instruction is reported and in case of a data access error, the data address is also reported. | |||||
* | Patch from D. V. Henkel-Wallace <gumby@zembu.com> to use puts and have ↵ | Joel Sherrill | 1999-01-04 | 2 | -2/+6 | |
| | | | | prototype. | |||||
* | Patch from D. V. Henkel-Wallace <gumby@zembu.com> to fix braces nesting problem. | Joel Sherrill | 1999-01-04 | 1 | -1/+2 | |
* | Patch from D. V. Henkel-Wallace <gumby@zembu.com> to make macro nest ↵ | Joel Sherrill | 1999-01-04 | 1 | -3/+5 | |
| | | | | properly in conditionals | |||||
* | Removed blank lines | Joel Sherrill | 1999-01-04 | 2 | -3/+0 | |
* | Switched to use of ASM compilation conditional. | Joel Sherrill | 1998-12-15 | 1 | -2/+2 | |
* | Changed reference from no_cpu to mips64orion. | Joel Sherrill | 1998-12-15 | 3 | -3/+3 | |
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to rename all | Joel Sherrill | 1998-12-14 | 7 | -0/+2964 | |
| | | | | | .s files to .S in conformance with GNU conventions. This is a minor step along the way to supporting automake. | |||||
* | Corrected prototype to confirm to POSIX 1003.1b. | Joel Sherrill | 1998-12-14 | 2 | -10/+4 | |
* | Merged Eric Norum's select patch that was based on 4.0 and resolved | Joel Sherrill | 1998-12-10 | 18 | -240/+187 | |
| | | | | all conflicts. | |||||
* | Patch from Ian Lance Taylor <ian@airs.com>: | Joel Sherrill | 1998-12-10 | 4 | -0/+31 | |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | From: Eric Norum <eric@skatter.usask.ca> Date: Sat, 5 Dec 98 13:20:51 -0600 What do you think of this patch? It implements your `tap' suggestion in a way that adds support for all ethernet devices with no driver modifications. I also added a return value from the tap function. If the return value is zero, the packet will be passed up the chain as usual. If the return value is non-zero the mbuf holding the packet will be freed and the packet will be dropped. If you like it, please submit it to Joel. I guess there needs to be an addition to the network documentation describing the additional ioctl's -- and a big warning that the tap function is called from a context that holds the network semaphore. Here is Eric's patch. I've tested it a bit, and made a couple of trivial changes. This is certainly better than mine: it should work for all Ethernet drivers. ================================================== The only concern I have about this patch is that the tap function may want to fiddle with the mbuf, calling functions like m_pullup and the like. If those force the networking code to rearrange the mbuf structure, then the caller's call to m_freem may crash. I don't know if this is a realistic concern--I don't know enough about the mbuf layer. | |||||
* | Patch from Ian Lance Taylor <ian@airs.com>: | Joel Sherrill | 1998-12-07 | 3 | -5/+12 | |
| | | | | | | | | | | | | | RTEMS permits using the SO_SNDTIMEO and SO_RCVTIMEO socket options to set a timeout for most socket I/O operations. However, in RTEMS 4.0.0, those options do not affect connect or accept. I don't know of any way to put a timeout on those calls in RTEMS 4.0.0; can anybody point to one. Since it is frequently useful to have a timeout on accept, and sometimes useful to have a timeout on connect shorter than the BSD system default of 75 seconds, the following patch causes SO_RCVTIMEO to affect connect and accept. |
