* aclocal/version.m4: Updated to rtems-ss-20030411.
* aclocal/version.m4: Updated to rtems-ss-20020411.
* rtems_webserver/cgi.c, rtems_webserver/sockGen.c,
rtems_webserver/umui.c, rtems_webserver/websSSL.c,
rtems_webserver/websSSL.h, rtems_webserver/websda.c,
rtems_webserver/websda.h: New files. Not included in previous commit.
* rtems_webserver/NOTES, rtems_webserver/asp.c,
rtems_webserver/balloc.c, rtems_webserver/default.c,
rtems_webserver/ej.h, rtems_webserver/ejIntrn.h,
rtems_webserver/ejlex.c, rtems_webserver/ejparse.c,
rtems_webserver/emfdb.c, rtems_webserver/emfdb.h,
rtems_webserver/form.c, rtems_webserver/h.c,
rtems_webserver/handler.c, rtems_webserver/license.txt,
rtems_webserver/md5.h, rtems_webserver/md5c.c,
rtems_webserver/mime.c, rtems_webserver/misc.c,
rtems_webserver/ringq.c, rtems_webserver/rom.c,
rtems_webserver/security.c, rtems_webserver/sock.c,
rtems_webserver/sym.c, rtems_webserver/uemf.c,
rtems_webserver/uemf.h, rtems_webserver/um.c, rtems_webserver/um.h,
rtems_webserver/url.c, rtems_webserver/value.c,
rtems_webserver/wbase64.c, rtems_webserver/webcomp.c,
rtems_webserver/webpage.c, rtems_webserver/webrom.c,
rtems_webserver/webs.c, rtems_webserver/webs.h,
rtems_webserver/websuemf.c, rtems_webserver/wsIntrn.h:
Update to GoAhead Webserver 2.1.4. The following URL is
the release notes from GoAhead.
http://data.goahead.com/Software/Webserver/2.1.4/release.htm
I have only done a minimal amount of testing (i.e. the network
demo program works fine). Please try this out and let me know
if it works. The patch needs to be applied on the
c/src/libnetworking/rtems_webserver directory.
PR 371/pppd
* pppd/auth.c, pppd/chat.c, pppd/demand.c, pppd/fsm.c, pppd/lcp.c,
pppd/options.c, pppd/pppd.h, pppd/rtemsmain.c, pppd/rtemspppd.c:
Change many symbols to static. There are still global symbols in
rtemspppd.h which might need to be changed or converted into member
of a structure which is dereferenced with a pointer that is managed
as a per task variable. But this patch should avoid many conflicts.
PR 381/core
* src/newlibc.c: Switch from using _REENT_INIT to _REEINT_INIT_PTR
to fix strange run-time problem where EIP was corrupted on pc386 BSP.
* ChangeLog, Makefile.am: ATA code depends upon libchip/ide which is
not allowed in the cpukit source code since it must be buildable
independent of any BSP. These files were moved to libchip/ide.
* include/rtems/ata.h, include/rtems/ata_internal.h: Removed.
* kern/kern_sysctl.c: Converted from BSP strlcpy() to strncpy().
* rtems/rtems_bsdnet_malloc_starvation.c: Fixed name of include file.
PR 374/networking
* Makefile.am, rtems/rtems_bsdnet.h, rtems/rtems_glue.c:
The patch sent as part of PR270 got applied to the wrong place.
The effect was that (1) startup was no faster than before and
(2) malloc starvation messages came way too quickly. The attached
patch fixes both these problems and also provides a mechanism for
applications to handle malloc starvation conditions as they see fit.
* rtems/rtems_bsdnet_malloc_starvation.c: New file.
PR 367/filesystem
* Makefile.am, include/rtems/ide_part_table.h, src/ata.c,
src/ide_part_table.c: Some bugs were still present in the DOSFS
implementation:
- FAT12 did not work properly on Big-Endian machines
- Some synchronization and error handling problems were present
- Some legal codings for EOC were not recognized
PR 367/filesystem
* src/dosfs/Makefile.am, src/dosfs/fat.c, src/dosfs/fat.h,
src/dosfs/fat_fat_operations.c, src/dosfs/fat_file.c,
src/dosfs/msdos.h, src/dosfs/msdos_dir.c: Some bugs were still
present in the DOSFS implementation:
PR 356/bsps
* sys/linker_set.h: This patch makes RTEMS/PowerPC eabi compliant.
Declare all linker-script defined addresses as
variables of unknown size and not as short objects
like 'int', 'void*' etc. Since only addresses are used and never those
variable's values, the type used in a declaration is not important.
PR 356/bsps
* src/threadhandlerc: This patch makes RTEMS/PowerPC eabi compliant.
Let Thread_Handler verify that _init/_main are non-NULL
before calling them (gives the linker script/user more
freedom to handle special cases).
PR 349/bsps
* rtems/powerpc/registers.h: Add definitions for HID1 and DABR SPRs.
Author: Till Straumann <strauman@slac.stanford.edu>
2003/2/11
This patch addresses the following issues:
2003-02-20 Till Straumann <strauman@slac.stanford.edu>
PR 349/bsps
* src/mount.c, src/privateenv.c:
- mount() bugfix: allocated 'loc' node must be released if
mount fails due to missing node_type_h
- silence compiler warning about improper pointer type
Index: cpukit/libcsupport/src/mount.c
RCS file: /afs/slac/g/spear/cvsrep/rtems/src-20030128/cpukit/libcsupport/src/mount.c,v
retrieving revision 1.1.1.2
diff -c -r1.1.1.2 mount.c
*** cpukit/libcsupport/src/mount.c 29 Jan 2003 22:57:19 -0000 1.1.1.2
--- cpukit/libcsupport/src/mount.c 7 Feb 2003 20:47:49 -0000
*** 142,147 ****
--- 142,149 ----
mount_point, RTEMS_LIBIO_PERMS_RWX, &loc, TRUE ) == -1 )
goto cleanup_and_bail;
+ loc_to_free = &loc;
* Test for node_type_h
*** 155,161 ****
* Test to see if it is a directory
- loc_to_free = &loc;
if ( loc.ops->node_type_h( &loc ) != RTEMS_FILESYSTEM_DIRECTORY ) {
errno = ENOTDIR;
--- 157,162 ----
Index: cpukit/libcsupport/src/privateenv.c
RCS file: /afs/slac/g/spear/cvsrep/rtems/src-20030128/cpukit/libcsupport/src/privateenv.c,v
retrieving revision 1.1.1.3
diff -c -r1.1.1.3 privateenv.c
*** cpukit/libcsupport/src/privateenv.c 29 Jan 2003 22:57:20 -0000 1.1.1.3
--- cpukit/libcsupport/src/privateenv.c 30 Jan 2003 18:01:40 -0000
*** 65,71 ****
tmp->refcnt = 1;
#endif
! sc = rtems_task_variable_add(RTEMS_SELF,(void*)&rtems_current_user_env,free_user_env);
if (sc != RTEMS_SUCCESSFUL) {
/* don't use free_user_env because the pathlocs are
* not initialized yet
--- 65,71 ----
tmp->refcnt = 1;
#endif
! sc = rtems_task_variable_add(RTEMS_SELF,(void*)&rtems_current_user_env,(void(*)(void *))free_user_env);
PR 351/networking
* nfs/bootp_subr.c: Fix ridiculous leak in bootp and use
strdup_bootp_realloc() everywhere for sake of consistency.
PR 357/rtems_misc
* src/termios.c (rtems_termios_open): Fixed code the incorrectly
checked that the wrong pointer during allocation was NULL.
PR 352/rtems_misc
* shell/shell.c: make rtems_shell main task an FP enabled task.
AMD a29k declared obsolete.
* cpu/Makefile.am: Removed reference.
* cpu/a29k/.cvsignore, cpu/a29k/ChangeLog, cpu/a29k/Makefile.am,
cpu/a29k/amd.ah, cpu/a29k/asm.h, cpu/a29k/configure.ac,
cpu/a29k/cpu.c, cpu/a29k/cpu_asm.S, cpu/a29k/pswmacro.ah,
cpu/a29k/register.ah, cpu/a29k/sig.S, cpu/a29k/rtems/.cvsignore,
cpu/a29k/rtems/score/.cvsignore, cpu/a29k/rtems/score/a29k.h,
cpu/a29k/rtems/score/cpu.h, cpu/a29k/rtems/score/cpu_asm.h,
cpu/a29k/rtems/score/types.h: Removed.
PR 347/rtems
* rtems/powerpc/registers.h (PPC_Set_decrementer): Correct inline
assembly so it correctly generates on newer gcc's.
* cpu_asm.c: Rework logic that decides when to call
_Thread_Dispatch. Analysis by Sergei Organov <osv@javad.ru>
determined that _ISR_Signals_to_thread_executing was not being
honored and/or cleared properly.
* irq.c: Rework logic that decides when to call
* rtems/rtems_glue.c: A small patch to the network daemon task
code. I just added code to check the return value of
the rtems_bsdnet_event_receive function. Only when
this function returns a SUCCESSFUL status, will the
event flags be checked. This is more of a code cleanup issue
than a bug. The patch will just ensure the ipintr() and
arpintr() functions are only called when a event is signaled.
* pppd/chat.c: Convert routines with common names to static. This
included get_char(), put_char(), and character() among others.
* m68360.h: Correct the order of fields in the ethernet structure
to account for the typo in MC68360UM (page 7-248).
PR 342/networking
* kern/uipc_mbuf.c: The RTEMS version of the m_copyback is changing
the m_len value of the mbuf. I looked into the source from another
BSD system and the mbuf length is not changed inside this function.
The m_copyback function is only being used in the net/rtsock.c file.
So I think this problem is only visable under certain routing table
conditions.
* include/sys/ioccom.h: Include <sys/types.h> not <machine/types.h> so
Linux port builds.
PR 341/networking
* lib/ftpfs.c: Account for NULL at end of strings when malloc()'ing
memory.
PR 340/filesystem
* src/fcntl.c: Add missing _fcntl_r assumed to exist by newlib.
