path: root/cpukit (follow)
* 2004-03-23 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-2323-52/+70
| | | | | | | | | | | | | | | | | | * itron/include/itronsys/mbox.h, itron/include/itronsys/types.h, itron/include/rtems/itron/eventflags.h, itron/include/rtems/itron/fmempool.h, itron/include/rtems/itron/mbox.h, itron/include/rtems/itron/msgbuffer.h, itron/include/rtems/itron/port.h, itron/include/rtems/itron/semaphore.h, itron/include/rtems/itron/task.h, itron/include/rtems/itron/vmempool.h, itron/inline/rtems/itron/semaphore.inl, itron/macros/rtems/itron/semaphore.inl, itron/src/eventflags.c, itron/src/fmempool.c, itron/src/itronsem.c, itron/src/mbox.c, itron/src/msgbuffer.c, itron/src/port.c, itron/src/snd_mbx.c, itron/src/task.c, itron/src/trcv_mbx.c, itron/src/vmempool.c: Convert to using c99 fixed size types.
* 2004-03-23 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-2331-65/+86
| | | | | | | | | | | | | | | | | | | | | * posix/include/rtems/posix/cond.h, posix/include/rtems/posix/intr.h, posix/include/rtems/posix/key.h, posix/include/rtems/posix/mqueue.h, posix/include/rtems/posix/mutex.h, posix/include/rtems/posix/pthread.h, posix/include/rtems/posix/semaphore.h, posix/include/rtems/posix/threadsup.h, posix/include/rtems/posix/timer.h, posix/src/cond.c, posix/src/intr.c, posix/src/key.c, posix/src/keycreate.c, posix/src/keydelete.c, posix/src/keygetspecific.c, posix/src/keyrundestructors.c, posix/src/keysetspecific.c, posix/src/killinfo.c, posix/src/mqueue.c, posix/src/mqueuerecvsupp.c, posix/src/mqueuesendsupp.c, posix/src/mqueuetranslatereturncode.c, posix/src/mutex.c, posix/src/posixintervaltotimespec.c, posix/src/posixtimespecsubtract.c, posix/src/psignal.c, posix/src/pthread.c, posix/src/ptimer1.c, posix/src/semaphore.c, posix/src/sysconf.c: Convert to using c99 fixed size types.
* 2004-03-23 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-232-1/+6
| | | | * score/include/rtems/system.h: include <stdint.h>.
* 2004-03-23 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-232-0/+1158
| | | | | PR/589 rtems * include/rtems/pci.h: New (Moved from c/src/libchip/network/pci.h).
* 2004-03-23 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-232-3/+7
| | | | * libcsupport/src/malloc.c: Remove lvalue casts.
* 2004-03-23 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-2325-168/+186
| | | | | | | | | | | | | | | | | | * libcsupport/include/chain.h, libcsupport/include/clockdrv.h, libcsupport/include/ringbuf.h, libcsupport/include/spurious.h, libcsupport/include/timerdrv.h, libcsupport/include/vmeintr.h, libcsupport/include/motorola/mc68230.h, libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/libio.h, libcsupport/include/rtems/libio_.h, libcsupport/include/rtems/termiostypes.h, libcsupport/include/zilog/z8036.h, libcsupport/include/zilog/z8530.h, libcsupport/include/zilog/z8536.h, libcsupport/src/__gettod.c, libcsupport/src/assoc.c, libcsupport/src/assocnamebad.c, libcsupport/src/error.c, libcsupport/src/libio.c, libcsupport/src/libio_sockets.c, libcsupport/src/malloc.c, libcsupport/src/no_libc.c, libcsupport/src/termios.c, libcsupport/src/termiosreserveresources.c: Convert to using c99 fixed-size types.
* 2004-03-22 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-2219-369/+382
| | | | | | | | | | | | | * libfs/src/dosfs/fat.c, libfs/src/dosfs/fat.h, libfs/src/dosfs/fat_fat_operations.c, libfs/src/dosfs/fat_fat_operations.h, libfs/src/dosfs/fat_file.c, libfs/src/dosfs/fat_file.h, libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_initsupp.c, libfs/src/dosfs/msdos_misc.c, libfs/src/imfs/deviceio.c, libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_directory.c, libfs/src/imfs/imfs_fchmod.c, libfs/src/imfs/linearfile.c, libfs/src/imfs/memfile.c: Convert to using c99 fixed-size types.
* Remove refs to Makefile*.Ralf Corsepius2004-03-097-14/+0
* Unused.Ralf Corsepius2004-03-08104-208/+0
* 2004-03-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-03-052-1/+5
| | | | * libnetworking/net/radix.c: Remove warning.
| | | | * libmisc/shell/cmds.c: Remove warning.
* 2004-03-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-03-052-2/+6
| | | | * libnetworking/lib/ftpfs.c: Switch bcopy to memcpy.
* 2004-03-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-03-053-19/+54
| | | | | | * libcsupport/src/newlibc.c, libcsupport/src/sync.c: Eliminate warnings. Explicitly defeat __STRICT_ANSI__ since both legitimately use routines beyond ANSI.
* 2004-03-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-03-052-1/+6
| | | | * libblock/src/bdbuf.c: Initialize pointer to avoid warning.
* 2004-03-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-03-057-19/+24
| | | | | | | | | | * libnetworking/rtems_webserver/ejparse.c, libnetworking/rtems_webserver/emfdb.c, libnetworking/rtems_webserver/sock.c, libnetworking/rtems_webserver/socket.c, libnetworking/rtems_webserver/sym.c, libnetworking/rtems_webserver/webs.c, libnetworking/rtems_webserver/websuemf.c: Remove warnings.
* 2004-03-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-03-053-21/+9
| | | | | * score/macros/rtems/score/chain.inl, score/src/objectidtoname.c: Add cast to avoid type punning warning in gcc 3.3.
* 2004-03-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-03-0535-193/+52
| | | | | | | | | | | | | | | | | | | | | * libblock/src/bdbuf.c, libblock/src/ramdisk.c, libcsupport/src/newlibc.c, libcsupport/src/sync.c, libmisc/cpuuse/cpuuse.c, libmisc/monitor/mon-symbols.c, libmisc/shell/cmds.c, libmisc/shell/shell.c, libnetworking/kern/kern_sysctl.c, libnetworking/lib/ftpfs.c, libnetworking/lib/tftpDriver.c, libnetworking/libc/gethostbydns.c, libnetworking/libc/gethostbyht.c, libnetworking/libc/gethostnamadr.c, libnetworking/libc/getnetbyht.c, libnetworking/libc/getnetnamadr.c, libnetworking/libc/inet_addr.c, libnetworking/libc/linkaddr.c, libnetworking/libc/map_v4v6.c, libnetworking/libc/ns_print.c, libnetworking/libc/ns_ttl.c, libnetworking/libc/nsap_addr.c, libnetworking/libc/rcmd.c, libnetworking/libc/res_debug.c, libnetworking/libc/res_mkupdate.c, libnetworking/libc/res_query.c, libnetworking/libc/res_send.c, libnetworking/libc/res_update.c, libnetworking/net/radix.c, libnetworking/rtems/mkrootfs.c, librpc/src/rpc/clnt_perror.c, librpc/src/rpc/svc.c, score/macros/rtems/score/chain.inl, score/src/objectidtoname.c: Too much was accidentally committed -- revert.
* 2004-03-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-03-0537-37/+244
| | | | | | | | | | | | | | | | | | | | | * libblock/src/bdbuf.c, libblock/src/ramdisk.c, libcsupport/src/newlibc.c, libcsupport/src/sync.c, libmisc/cpuuse/cpuuse.c, libmisc/monitor/mon-symbols.c, libmisc/shell/cmds.c, libmisc/shell/shell.c, libnetworking/kern/kern_sysctl.c, libnetworking/lib/ftpfs.c, libnetworking/lib/tftpDriver.c, libnetworking/libc/gethostbydns.c, libnetworking/libc/gethostbyht.c, libnetworking/libc/gethostnamadr.c, libnetworking/libc/getnetbyht.c, libnetworking/libc/getnetnamadr.c, libnetworking/libc/inet_addr.c, libnetworking/libc/linkaddr.c, libnetworking/libc/map_v4v6.c, libnetworking/libc/ns_print.c, libnetworking/libc/ns_ttl.c, libnetworking/libc/nsap_addr.c, libnetworking/libc/rcmd.c, libnetworking/libc/res_debug.c, libnetworking/libc/res_mkupdate.c, libnetworking/libc/res_query.c, libnetworking/libc/res_send.c, libnetworking/libc/res_update.c, libnetworking/net/radix.c, libnetworking/rtems/mkrootfs.c, librpc/src/rpc/clnt_perror.c, librpc/src/rpc/rtems_rpc.c, librpc/src/rpc/svc.c, sapi/include/confdefs.h, score/macros/rtems/score/chain.inl, score/src/objectidtoname.c:
* 2004-02-26 Andreas Karlsson <andreas.karlsson@space.se>Joel Sherrill2004-02-262-0/+16
| | | | | * cpu_asm.S: Close window while restoring interrupted task state which resulted in CWP corruption.
* 2004-02-26 Thomas Rauscher <trauscher@loytec.com.Joel Sherrill2004-02-262-9/+26
| | | | | PR 584/RTEMS * rtems/src/eventtimeout.c: Fix critical section window.
* 2004-02-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-02-265-6/+44
| | | | | | | | | PR 582/core * posix/src/mqueue.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueueunlink.c: Use memory from workspace to avoid use of mutex during dispatch disable critical section. Besides memory for object names should come from the Workspace anyway.
* Remove.Ralf Corsepius2004-02-131-79/+0
* 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-122-1/+5
| | | | * aclocal/version.m4: 4.6.99.0.
* 2004-02-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-093-8/+23
| | | | | PR 565/rtems * asm.h: Various hacks.
* 2004-02-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-094-4/+0
| | | | | | | | * libnetworking/pppd/Makefile.am, libnetworking/rtems_servers/Makefile.am, libnetworking/rtems_telnetd/Makefile.am, libnetworking/rtems_webserver/Makefile.am, optman/Makefile.am, support/Makefile.am: Don't include lib.am.
* 2004-02-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-092-2/+4
| | | | * libnetworking/Makefile.am: Remove ACLOCAL_AMFLAGS.
* 2004-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-034-5/+13
| | | | | | | * libnetworking/rtems_webserver/Makefile.am: Add PREINSTALL_DIRS. * libnetworking/rtems_telnetd/Makefile.am: Add PREINSTALL_DIRS. * libnetworking/rtems_servers/Makefile.am: Add PREINSTALL_DIRS. * libnetworking/pppd/Makefile.am: Add PREINSTALL_DIRS.
* 2004-01-30 Wilfried Busalski <w.busalski@lancier-monitoring.de>Joel Sherrill2004-01-304-17/+54
| | | | | | | | PR pppd/564 * libnetworking/net/if_ppp.c, libnetworking/net/if_pppvar.h, libnetworking/net/ppp_tty.c: ppp0 Interface lose packets if the system use a slow baudrate for the modem or the tcp/ip-packet is fragmented.
* 2004-01-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-01-303-39/+7
| | | | | * ChangeLog, rtems/Makefile.am, rtems/include/rtems/rtems/support.h: Reverse developmental patches accidentally committed.
* 2004-01-30 Wilfried Busalski <w.busalski@lancier-monitoring.de>Joel Sherrill2004-01-303-4/+41
| | | | | | | PR pppd/564 * rtems/Makefile.am, rtems/include/rtems/rtems/support.h: ppp0 Interface lose packets if the system use a slow baudrate for the modem or the tcp/ip-packet is fragmented.
* 2004-01-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-303-8/+15
| | | | | PR 561/rtems * asm.h: Add CONCAT0, EVAL. Let SYM and REG use CONCAT0 and EVAL.
* Reformat/Cleanups.Ralf Corsepius2004-01-241-957/+555
* ReformatRalf Corsepius2004-01-241-79/+28
* 2004-01-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-232-1073/+998
| | | | | * ChangeLog: Merge-in libnetworking/ChangeLog. * libnetworking/ChangeLog: Remove.
* Cleanup ChangeLog.Ralf Corsepius2004-01-231-471/+357
* 2004-01-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-232-436/+345
| | | | | * ChangeLog: Merge-in libcsupport/ChangeLog. * libcsupport/ChangeLog: Remove.
* Cleanup ChangeLog.Ralf Corsepius2004-01-231-161/+107
* 2004-01-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-233-882/+702
| | | | | * ChangeLog: Merge-in libblock/ChangeLog, libfs/ChangeLog. * libblock/ChangeLog, libfs/ChangeLog: Remove.
* 2004-01-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-233-970/+793
| | | | | * ChangeLog: Merge-in libmisc/ChangeLog, librpc/ChangeLog. * libmisc/ChangeLog, librpc/ChangeLog: Remove.
* Cleanup ChangeLog.Ralf Corsepius2004-01-231-308/+228
* 2004-01-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-236-2300/+1893
| | | | | | | * ChangeLog: Merge-in itron/ChangeLog, posix/ChangeLog, score/ChangeLog, sapi/ChangeLog, rtems/ChangeLog. * itron/ChangeLog, posix/ChangeLog, score/ChangeLog, sapi/ChangeLog, rtems/ChangeLog: Remove.
* Cleanup ChangeLog.Ralf Corsepius2004-01-231-6/+6
* Cleanup ChangeLog.Ralf Corsepius2004-01-231-1/+1
* Cleanup ChangeLog.Ralf Corsepius2004-01-233-524/+387
* Cleanup ChangeLog.Ralf Corsepius2004-01-231-387/+320
* Cleanup ChangeLog.Ralf Corsepius2004-01-231-120/+90
* Cleanup ChangeLog.Ralf Corsepius2004-01-231-86/+61
* Cleanup ChangeLog.Ralf Corsepius2004-01-233-700/+426
* 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-214-26/+62
| | | | | | | * aclocal/rtems-top.m4: Remove PROJECT_ROOT. Prepend ../ to $1. * aclocal/env-rtemscpu.m4: Reworked. * configure.ac: RTEMS_TOP([.]).
