Update #4667.
Conditional expressions with inline functions are not optimized away if
optimization is disabled. Avoid such expressions to prevent dead
branches. It helps also during code review to immediately see if a loop
is used or not.
The real implementation of hardpps() is defined in kern_ntptime.c. Use it only
if the NTP support is needed by the application.
Update #2349.
Use CLOCK_REALTIME and CLOCK_MONOTONIC for relative thread queue timeouts
instead of CLOCK_REALTIME_COARSE and CLOCK_MONOTONIC_COARSE. This fixes an
issue with clock_nanosleep() in combination with clock_gettime().
Close #4669.
The original file cpukit/libfs/src/ftpfs/tftpDriver.c
is split into two:
tftpfs.c - This file contains the code from tftpDriver.c
related to file system operations such as mount(),
open(), read(), and so on.
tftpDriver.c - In the original file remains only the code related
to networking. This code implements the Trivial
File Transfer Protocol (TFTP).
Moreover, the code is extended to support
* RFC 2347 TFTP Option Extension
* RFC 2348 TFTP Blocksize Option
* RFC 7440 TFTP Windowsize Option
Update #4666.
Update #4666.
Replace the existing /* fall through */ comments and its variants with
the new pseudo-keyword macro fallthrough[1]. Also, remove unnecessary
fall-through markings when it is the case.
[1] https://www.kernel.org/doc/html/v5.7/process/deprecated.html?highlight=fallthrough#implicit-switch-case-fall-through
Signed-off-by: Gustavo A. R. Silva <gustavoars@kernel.org>
Thanks for the advice mentioned in the email.
This is my v3 patch for this problem.
Mounting jffs2 on nand flash will get message "failed: I/O error"
with the steps listed below.
1.umount jffs2
2.erase nand flash
3.mount jffs2 on it (this mounting operation will be successful)
4.do chown or chmod to the mount point directory
5.umount jffs2
6.mount jffs2 on nand flash
After step 6, we will get message "mount ... failed: I/O error".
Typical image of this problem is like:
Empty space found from 0x00000000 to 0x008a0000
Inode node at xx, totlen 0x00000044, #ino 1, version 1, isize 0...
The reason for this mounting failure is that at the end of function
jffs2_scan_medium(), jffs2 will check the used_size and some info
of nr_blocks.If conditions are met, it will return -EIO.
The detail is that, in the steps listed above, step 4 will write
jffs2_raw_inode into flash without jffs2_raw_dirent, which will
cause that there are some jffs2_raw_inode but no jffs2_raw_dirent
on flash. This will meet the condition at the end of function
jffs2_scan_medium() and return -EIO if we umount jffs2 and mount it
again.
We notice that jffs2 add the value of c->unchecked_size if we find
an inode node while mounting. And jffs2 will never add the value of
c->unchecked_size in other situations. So this patch add one more
condition about c->unchecked_size of the judgement to fix this problem.
Signed-off-by: Zhe Li <lizhe67@huawei.com>
Signed-off-by: Richard Weinberger <richard@nod.at>
Using uninitialized_var() is dangerous as it papers over real bugs[1]
(or can in the future), and suppresses unrelated compiler warnings
(e.g. "unused variable"). If the compiler thinks it is uninitialized,
either simply initialize the variable or make compiler changes.
In preparation for removing[2] the[3] macro[4], remove all remaining
needless uses with the following script:
git grep '\buninitialized_var\b' | cut -d: -f1 | sort -u | \
xargs perl -pi -e \
's/\buninitialized_var\(([^\)]+)\)/\1/g;
s:\s*/\* (GCC be quiet|to make compiler happy) \*/$::g;'
drivers/video/fbdev/riva/riva_hw.c was manually tweaked to avoid
pathological white-space.
No outstanding warnings were found building allmodconfig with GCC 9.3.0
for x86_64, i386, arm64, arm, powerpc, powerpc64le, s390x, mips, sparc64,
alpha, and m68k.
[1] https://lore.kernel.org/lkml/20200603174714.192027-1-glider@google.com/
[2] https://lore.kernel.org/lkml/CA+55aFw+Vbj0i=1TGqCR5vQkCzWJ0QxK6CernOU6eedsudAixw@mail.gmail.com/
[3] https://lore.kernel.org/lkml/CA+55aFwgbgqhbp1fkxvRKEpzyR5J8n1vKT1VZdz9knmPuXhOeg@mail.gmail.com/
[4] https://lore.kernel.org/lkml/CA+55aFz2500WfbKXAx8s67wrm9=yVJu65TpLgN_ybYNv0VEOKA@mail.gmail.com/
Reviewed-by: Leon Romanovsky <leonro@mellanox.com> # drivers/infiniband and mlx4/mlx5
Acked-by: Jason Gunthorpe <jgg@mellanox.com> # IB
Acked-by: Kalle Valo <kvalo@codeaurora.org> # wireless drivers
Reviewed-by: Chao Yu <yuchao0@huawei.com> # erofs
Signed-off-by: Kees Cook <keescook@chromium.org>
There is a regular need in the kernel to provide a way to declare having a
dynamically sized set of trailing elements in a structure. Kernel code should
always use “flexible array members”[1] for these cases. The older style of
one-element or zero-length arrays should no longer be used[2].
[1] https://en.wikipedia.org/wiki/Flexible_array_member
[2] https://github.com/KSPP/linux/issues/21
jffs2_add_frag_to_fragtree()"
This reverts commit f2538f999345405f7d2e1194c0c8efa4e11f7b3a. The patch
stopped JFFS2 from being able to mount an existing filesystem with the
following errors:
jffs2: error: (77) jffs2_build_inode_fragtree: Add node to tree failed -22
jffs2: error: (77) jffs2_do_read_inode_internal: Failed to build final fragtree for inode #5377: error -22
Fixes: f2538f999345 ("jffs2: Fix possible null-pointer dereferences...")
Cc: stable@vger.kernel.org
Suggested-by: Hou Tao <houtao1@huawei.com>
Signed-off-by: Joel Stanley <joel@jms.id.au>
In jffs2_scan_eraseblock(), 'sumptr' is allocated through kmalloc() if
'sumlen' is larger than 'buf_size'. However, it is not deallocated in the
following execution if jffs2_fill_scan_buf() fails, leading to a memory
leak bug. To fix this issue, free 'sumptr' before returning the error.
Signed-off-by: Wenwen Wang <wenwen@cs.uga.edu>
Merge these two helpers into the only callers to get rid of some
amazingly bad calling conventions.
Suggested-by: Al Viro <viro@zeniv.linux.org.uk>
Signed-off-by: Christoph Hellwig <hch@lst.de>
In jffs2_add_frag_to_fragtree(), there is an if statement on line 223 to
check whether "this" is NULL:
if (this)
When "this" is NULL, it is used at several places, such as on line 249:
if (this->node)
and on line 260:
if (newfrag->ofs > this->ofs)
Thus possible null-pointer dereferences may occur.
To fix these bugs, -EINVAL is returned when "this" is NULL.
These bugs are found by a static analysis tool STCheck written by us.
Signed-off-by: Jia-Ju Bai <baijiaju1990@gmail.com>
Linux kernel tolerates C++ style comments these days. Actually, the
SPDX License tags for .c files start with //.
On the other hand, uapi headers are written in more strict C, where
the C++ comment style is forbidden.
I simply dropped these lines instead of fixing the comment style.
This code has been always commented out since it was added around
Linux 2.4.9 (i.e. commented out for more than 17 years).
'Maybe later...' will never happen.
Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Acked-by: Richard Weinberger <richard@nod.at>
free the symlink body after the same RCU delay we have for freeing the
struct inode itself, so that traversal during RCU pathwalk wouldn't step
into freed memory.
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
Need to tell the compiler that the acl entries follow the acl header.
Signed-off-by: Matthew Wilcox <mawilcox@microsoft.com>
Updates #6442
Updates #4662
The false trigger is covered in:
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=99578
GCC 11 and 12 has been patched for constant pointer casts above
4K. This code casts a constant pointer within the first 4K
page. As a result the patch disables the warning.
Updates #4662
Since pps->capgen equal to zero is not a special value in uniprocessor configurations, there is no need to check for this condition.
Update #2349
Sections with identical attributes may be contiguous with a respective
begin and end address which is not on a minimum region boundary. The
begin address is aligned down to the region base address. The end
address is aligned up to the region end address. Account for this in
the check for contiguous sections.
Update #4202.
A section may span up to the end of the address range. In this case the
end address is zero. Use the base address to check if a region should
be before another region.
Update #4202.
Return early only if there was a timeout, otherwise return the PPS info.
Update #2349.
Close #2349.
Update #2349.
Update #2349.
Update #2349.
Update #2349.
Update #2349.
Rename tc_getfrequency() to _Timecounter_Get_frequency().
Update #2349.
Update #2349.
Update #2349.
Update #2349.
Update #2349.
Remove URL in copyright notice.
Update #3053.
Change license to BSD-2-Clause according to file history.
Update #3053.
Use the copyright notice of the associated header file from FreeBSD if the
kernel space header file contains a substantial amount of imported code.
Synchronize all file descriptors and not just the ones associated with a FILE
object.
Close #4656.
This file had no header, copyright, or license. Based on git history,
added appropriate copyright and license.
