* rtems/new-exceptions/cpu.h: Remove sections on
CPU_INLINE_ENABLE_DISPATCH and CPU_UNROLL_ENQUEUE_PRIORITY.
* rtems/old-exceptions/cpu.h: Remove sections on
* rtems/score/cpu.h: Insert sections on
* src/psignal.c: Fix counting problem which resulted in too many
entries being in the POSIX signals default behavior table.
* idtcpu.h: Removed warning.
* cpu.c: Removed warning.
* src/rpc/pmap_rmt.c: Removed warnings.
* pppd/auth.c, rtems_webserver/uemf.h: Removed warnings.
* kern/uipc_mbuf.c: Comment out m0 in m_copydata to suppress
warning.
* ChangeLog: Corrected.
* idtcpu.h: Removed warnings.
* cpu.c: Removed warnings.
use bootp option 129 to get command line string
change inet_ntoa->inet_ntop
* stackchk/check.c: Removed warnings.
* rtems/score/cpu.h: Removed warning.
* src/rpc/svc_run.c: Remove warning.
* src/mallocfreespace.c: Corrected sense of status check to
match change inside RTEMS.
* src/newlibc.c: Removed warning.
* rtems_webserver/socket.c, rtems_webserver/uemf.h: Removed
warnings.
* stackchk/check.c: Removed warning.
* src/regiongetinfo.c: Corrected return value check.
* libc/rcmd.c, netinet/in_cksum_arm.c: Removed warnings.
* src/heapgetinfo.c: Fixed comment.
* src/mpci.c: Removed warning.
* rtems/new-exceptions/cpu.h: Removed warnings.
which have already obtained the va_list pointer.
* aclocal/check-bsp-cache.m4: Remove.
* aclocal/multilib.m4: Remove RTEMS_ENABLE_MULTILIB_MASTER.
* configure.ac: Remove AC_ENABLE_MULTILIB.
* Makefile.am: Add CVS-Id.
* include/rtems/libio.h: Change rtems_filesystem_node_types_t from
enumeration to int to eliminate warnings when values are overridden.
* Added ATA support.
* include/rtems/blkdev.h: Added last IO status.
* include/rtems/ata.h, include/rtems/ata_internal.h,
include/rtems/ide_part_table.h, src/ata.c, src/ide_part_table.c: New
files.
* Pass to eliminate warnings.
* kern/uipc_mbuf.c: Conditional SYSINIT() usage on __rtems__.
Fix return statement without a value.
* lib/ftpfs.c: read and write filesystem routines return ssize_t.
* lib/syslog.c: Add include of <string.h> to eliminate warning.
* lib/tftpDriver.c: read and write filesystem routines return ssize_t.
* libc/gethostbydns.c: Prototype abort().
* libc/inet_ntoa.c: Prototype strcpy().
* libc/rcmd.c: Add include of <sys/select.h>
* net/if_loop.c: Turn token at end of endif to comment.
* net/rtsock.c, nfs/bootp_subr.c: Conditional SYSINIT() usage
on __rtems__.
* rtems/rtems_bootp.c: Add include of <rtems/rtems_bsdnet_internal.h>.
* rtems/rtems_bsdnet_internal.h: Added prototypes for memcpy() and
memset() since the BSD code tries to avoid using libc .h files
since it is used to being in the kernel.
* rtems/rtems_syscall.c: read and write filesystem routines
return ssize_t.
* src/rpc/clnt_tcp.c, src/rpc/clnt_udp.c, src/rpc/pmap_rmt.c,
src/rpc/rtime.c, src/rpc/svc_tcp.c: Add include of <sys/select.h>
* src/rpc/rpcdname.c: Add prototype of getdomainname() to eliminate
warning.
* src/timerserver.c: Add useless return to avoid warning.
* src/threadhandler.c: Prototype _init() and _main() if they are needed
to avoid a warning.
* idtcpu.h: Removed warning by turning extra token at the end of
an endif into a comment.
* monitor/mon-command.c: Don't build rtems_monitor_line_editor for
RTEMS_UNIX to avoid gcc warning.
* configure.ac: Add nostdinc to AM_INIT_AUTOMAKE.
* rtems/score/sh.h: Fix typo in comment (Starus->Status).
* Makefile.am: Remove bogus reference to CHANGELOG.
* src/eval.c: Per PR293, added freenode calls for evaluate
link failures.
* capture/capture.c, monitor/mon-manager.c, stackchk/check.c:
Patch to remove problems introduced by object name rework.
link failures.
* src/mount.c per PR290, add check for ops->node_type_h
* src/mknod.c per PR291, remove erroneous call to freenod
* aclocal/version.m4: Updated to rtems-20021021-test.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
Add autom4te*cache.
* net/if_ethersubr.c: Add comments to #endif NETATALK to stop
gcc from complaining.
* aclocal/version.m4: Updated to rtems-ss-20021007.
