* | imfs: Use most efficient way to get the time | Sebastian Huber | 2018-03-16 | 1 | -18/+17 |
| | | | | | | As a side-effect, this fixes some warnings. Close #3350. | ||||
* | Add PowerPC paravirtualization support | Joel Sherrill | 2018-03-13 | 4 | -0/+94 |
| | | | | | | | | | Cannot read or write MSR when executing in user mode. This is used when RTEMS_PARAVIRT is defined. Provide alternate methods to disable/enable interrupts Closes #3306. | ||||
* | Add ARM Paravirtualization support | Joel Sherrill | 2018-03-13 | 4 | -3/+90 |
| | | | | Closes #3305. | ||||
* | Rework i386 Paravirtualization to have paravirt.h | Joel Sherrill | 2018-03-13 | 5 | -3/+70 |
* | sparc64: Move libcpu content to cpukit | Sebastian Huber | 2018-03-13 | 5 | -5/+906 |
| | | | | | | This patch is a part of the BSP source reorganization. Update #3285. | ||||
* | sparc: Move libcpu content to cpukit | Sebastian Huber | 2018-03-13 | 8 | -4/+756 |
* | sparc/include/rtems/score/types.h: Eliminate this file | Joel Sherrill | 2018-03-12 | 4 | -56/+5 |
| | | | | Updates #3327. | ||||
* | sparc64/include/rtems/score/types.h: Eliminate this file | Joel Sherrill | 2018-03-12 | 3 | -47/+4 |
* | powerpc/include/rtems/score/types.h: Eliminate this file | Joel Sherrill | 2018-03-12 | 4 | -63/+5 |
* | m68k/include/rtems/score/types.h: Eliminate this file | Joel Sherrill | 2018-03-12 | 3 | -45/+3 |
* | riscv/include/rtems/score/types.h: Eliminate this file | Joel Sherrill | 2018-03-12 | 3 | -72/+4 |
* | arm/include/rtems/score/types.h: Eliminate this file | Joel Sherrill | 2018-03-12 | 3 | -53/+4 |
* | v850/include/rtems/score/types.h: Eliminate this file | Joel Sherrill | 2018-03-12 | 3 | -45/+4 |
* | no_cpu/include/rtems/score/types.h: Eliminate this file | Joel Sherrill | 2018-03-12 | 3 | -45/+5 |
* | or1k/include/rtems/score/types.h: Eliminate this file | Joel Sherrill | 2018-03-12 | 3 | -55/+4 |
* | m32c/include/rtems/score/types.h: Eliminate this file | Joel Sherrill | 2018-03-12 | 3 | -51/+4 |
* | moxie/include/rtems/score/types.h: Eliminate this file | Joel Sherrill | 2018-03-12 | 3 | -58/+4 |
* | sh/include/rtems/score/types.h: Eliminate this file | Joel Sherrill | 2018-03-12 | 3 | -58/+8 |
* | nios2/include/rtems/score/types.h: Eliminate this file | Joel Sherrill | 2018-03-12 | 3 | -48/+4 |
* | epiphany/include/rtems/score/types.h: Eliminate this file | Joel Sherrill | 2018-03-12 | 3 | -69/+4 |
* | lm32/include/rtems/score/types.h: Eliminate this file | Joel Sherrill | 2018-03-12 | 3 | -48/+4 |
* | i386/include/rtems/score/types.h: Eliminate this file | Joel Sherrill | 2018-03-12 | 4 | -49/+4 |
* | mips/include/rtems/score/types.h: Eliminate this file | Joel Sherrill | 2018-03-12 | 3 | -60/+4 |
* | bfin/include/rtems/score/types.h: Eliminate this file | Joel Sherrill | 2018-03-12 | 3 | -51/+4 |
* | shell: Fix rtems_shell_init_env() | Sebastian Huber | 2018-03-12 | 1 | -1/+1 |
| | | | | Do not discard a user provided task name in rtems_shell_init_env(). | ||||
* | libblock: C++ compatibility | Sebastian Huber | 2018-03-12 | 2 | -0/+16 |
* | config: Use new scheduler configuration defines | Sebastian Huber | 2018-03-12 | 1 | -18/+18 |
| | | | | Update #3325. | ||||
* | config: Simplify clustered scheduler configuration | Sebastian Huber | 2018-03-12 | 2 | -86/+173 |
| | | | | | | | | | Do not use names derived from scheduler implementation details. Instead use names derived from the scheduler configuration or documentation. Provide defines for backward compatibility. Update #3325. | ||||
* | network: Optionally install network headers | Sebastian Huber | 2018-03-09 | 24 | -28/+26 |
| | | | | | | Install the network headers only if --enable-networking is specified. Update #3254. | ||||
* | cpukit/include/mqueue.h: Delete unneeded includes | Joel Sherrill | 2018-03-08 | 1 | -3/+0 |
* | score/cpu/powerpc/include/rtems/score/powerpc.h: Fix typo | Joel Sherrill | 2018-03-08 | 1 | -1/+1 |
* | powerpc/include/rtems/score/types.h: Remove unused ppc_isr | Joel Sherrill | 2018-03-08 | 1 | -2/+0 |
* | config: Remove RTEMS prefix from internal defines | Sebastian Huber | 2018-03-08 | 1 | -42/+42 |
* | capture: Fix get priority methods | Sebastian Huber | 2018-03-07 | 1 | -2/+2 |
* | Add a simple task console driver | Sebastian Huber | 2018-03-06 | 7 | -31/+313 |
| | | | | Close #3320. | ||||
* | termios: Fix use of uninitialized variable | Sebastian Huber | 2018-02-22 | 1 | -4/+4 |
| | | | | Update #2840. | ||||
* | confdefs.h: Minor rework to avoid warnings when CONFIGURE_HAS_OWN_INIT_TABLE | Joel Sherrill | 2018-02-19 | 1 | -13/+16 |
| | | | | | | CONFIGURE_HAS_OWN_INIT_TABLE was used both with and without defining CONFIGURE_RTEMS_INIT_TASKS_TABLE. This rework allows it to work both ways without warnings. | ||||
* | dev/sc16is752: Check return values. | Christian Mauderer | 2018-02-12 | 1 | -4/+6 |
| | | | | | Escalate a failed installation of the interrupts to the next higher level. | ||||
* | dev/sc16is752: Add GPIO access via ioctl. | Christian Mauderer | 2018-02-12 | 3 | -0/+67 |
* | Use _Thread_Dispatch_direct() | Sebastian Huber | 2018-02-08 | 7 | -9/+9 |
| | | | | | | | Use _Thread_Dispatch_direct() for operations that block the executing thread. This ensures that we get a fatal error (INTERNAL_ERROR_BAD_THREAD_DISPATCH_DISABLE_LEVEL) if we try to block in an invalid context, e.g. during system start or an interrupt handler. | ||||
* | rtems: Use _Per_CPU_Get_executing() | Sebastian Huber | 2018-02-08 | 2 | -2/+2 |
* | fdt: Use self-contained mutex | Sebastian Huber | 2018-02-08 | 1 | -119/+29 |
| | | | | Update #2843. | ||||
* | network: Fix integer types | Sebastian Huber | 2018-02-07 | 2 | -2/+2 |
* | stdio-redirector: Use self-contained mutex | Sebastian Huber | 2018-02-07 | 2 | -62/+31 |
* | syslog: Use self-contained recursive mutex | Sebastian Huber | 2018-02-07 | 1 | -24/+6 |
* | tftpfs: Use self-contained mutex | Sebastian Huber | 2018-02-07 | 1 | -23/+9 |
* | libdl: Fix potential overwrite of dest buffer | Sebastian Huber | 2018-02-07 | 2 | -2/+2 |
* | libdl: Use self-contained mutex for RAP | Sebastian Huber | 2018-02-07 | 1 | -76/+16 |
* | libdl: Use self-contained recursive mutex | Sebastian Huber | 2018-02-07 | 2 | -64/+15 |
* | ftpd: Use self-contained synchronization objects | Sebastian Huber | 2018-02-07 | 1 | -52/+22 |
| | | | | Update #2843. |
