PR 1647/cpukit
* posix/src/nanosleep.c, posix/src/sched_yield.c,
rtems/src/taskwakeafter.c, sapi/include/confdefs.h,
sapi/include/rtems/config.h, sapi/src/exinit.c, score/Makefile.am,
score/preinstall.am, score/include/rtems/score/prioritybitmap.h,
score/inline/rtems/score/thread.inl, score/src/thread.c,
score/src/threadchangepriority.c, score/src/threadclearstate.c,
score/src/threadclose.c, score/src/threadinitialize.c,
score/src/threadready.c, score/src/threadresume.c,
score/src/threadsetpriority.c, score/src/threadsetstate.c,
score/src/threadsettransient.c, score/src/threadsuspend.c,
score/src/threadtickletimeslice.c: Refactor scheduler out of thread
handler to facilitate alternate scheduler implementations.
* score/src/threadyieldprocessor.c: Removed.
* score/src/schedulerprioritythreadschedulerupdate.c,
score/src/schedulerprioritythreadschedulerfree.c,
score/src/schedulerpriorityblock.c, score/src/scheduler.c,
score/src/schedulerprioritythreadschedulerallocate.c,
score/src/schedulerpriorityunblock.c,
score/src/schedulerpriority.c, score/src/schedulerpriorityyield.c,
score/include/rtems/score/schedulerpriority.h,
score/include/rtems/score/scheduler.h,
score/inline/rtems/score/scheduler.inl,
score/inline/rtems/score/schedulerpriority.inl: New files.
PR 1719/cpukit
* arm_exc_abort.S: Avoid "bx" instruction to support ARMv4 and below.
* score/src/iterateoverthreads.c, libmisc/cpuuse/cpuusagereport.c:
Avoid dead code if POSIX API is enabled.
Fixed NULL pointer access in case POSIX API is disabled.
* rtems/score/cpu.h: Set alignment requirements according to AAPCS.
* libmisc/monitor/mon-monitor.c: Fixed broken monitor command list.
* rtems/score/sparc64.h: Fix typo.
PR 1718/cpukit
* sapi/include/confdefs.h: POSIX threads are allocated twice the
minimum stack space by default. confdefs.h only accounts for one
minimum -- not the 2x factor.
PR 1717/cpukit
* libcsupport/src/gxx_wrappers.c: Free memory on error.
* libmisc/monitor/mon-monitor.c: Move node code into multiprocessing
ifdef.
* score/src/objectnametoid.c, score/src/objectnametoidstring.c:
Remove useless variable pointed out by clang.
* score/src/threadstackallocate.c: Remove useless variable
initialization pointed out by clang.
* rtems/src/ratemonreportstatistics.c, rtems/src/ratemonresetall.c:
Remove unchecked return status pointed out by clang.
* libcsupport/src/putk.c: Remove useless variable initialization
* cpu.c: Remove unused variable reported by clang.
* score/include/rtems/score/userext.h: Documentation.
* score/src/watchdoginsert.c: Removed superfluous cast and use
appropriate API function. This special case handling is obsolete
since 2006 with the introduction of compiler memory barriers in the
interrupt routines. Removed obsolete comments.
PR 1715/cpukit
* rtems/score/cpu.h: Fix typo on _CPU_Context_Restart_self.
* libmisc/stackchk/check.c: Make compile again.
* sapi/src/io.c, score/src/heap.c: Address dead assignment
issues found by clang.
* libmisc/stackchk/check.c: Address casting issue highlighted by clang.
There was no need for an intermediate cast to a structure pointer.
* posix/include/rtems/posix/aio_misc.h, posix/src/aio_misc.c: Small
fixes.
* rtems/powerpc/registers.h: Added HID2 define. Fixed comments.
* posix/src/psignalunblockthread.c: Formatting.
* posix/src/mutextimedlock.c: Check status local variable not
lock_status.
* rtems/score/cpu.h: Add RTEMS_COMPILER_NO_RETURN_ATTRIBUTE to
_CPU_Context_restore() because it does not return. Telling GCC this
avoids generation of dead code.
* libnetworking/lib/ftpfs.c: Do not fall back to BOOTP server address
in case hostname was not specified.
* libnetworking/lib/ftpfs.c: Fixed a special case with no username and
password.
* libfs/src/rfs/rtems-rfs-rtems-file.c: Add missing unlock in
write. Return the error code in close.
* libfs/src/rfs/rtems-rfs-trace.c,
libfs/src/rfs/rtems-rfs-trace.h: Add inode-delete.
* libfs/src/rfs/rtems-rfs-shell.c: Fix formatting.
* libfs/src/rfs/rtems-rfs-rtems-dir.c: Use ssize_t. Fix spelling.
* libfs/src/rfs/rtems-rfs-block.c: Fix rtems_rfs_block_get_bpos to
return the position correctly. A bpos does not have any special
processing. Do no reset the buffer handle when shrinking
indirectly.
* libfs/src/rfs/rtems-rfs-inode.c: Add trace.
* libfs/src/rfs/rtems-rfs-format.c: Fix comments.
* libfs/src/rfs/rtems-rfs-group.c: Limit the inodes to the blocks
in a group so the accounting works.
* libfs/src/rfs/rtems-rfs-dir.c: PR 1705. Fix handling the offsets
when deleting an entry.
* libfs/src/rfs/rtems-rfs-buffer.h: Remove
rtems_rfs_buffer_handle_reset. It is not needed and dangerous.
* configure.ac: pthread_attr* functions are in <pthread.h>, not in
<pthreads.h>.
* aclocal/check-func.m4: Linearize checks.
Add missing $2 to AC_CHECK_DECL.
* Makefile.am, configure.ac: Revert accident commit adding libdbm to
build.
* Makefile.am, configure.ac, posix/Makefile.am, posix/src/pthread.c:
* posix/src/pthreadattrgetguardsize.c, posix/src/pthreadattrgetstack.c,
posix/src/pthreadattrsetguardsize.c, posix/src/pthreadattrsetstack.c:
New files.
* posix/src/psignal.c: Fixed NULL pointer access.
* libfs/src/defaults/default_close.c: Return 0 instead of an error
status.
PR 1697/cpukit
* rtems/score/cpu.h: lm32 really needs aligned stack. Recent changes
highlighted that this macro was incorrect.
* libmd/md5.h: C++ compatibility.
* configure.ac: Add checks for pthread_attr_getguardsize,
pthread_attr_setguardsize, pthread_attr_setstack,
pthread_attr_getstack.
PR 1698/cpukit
* libcsupport/src/privateenv.c: Check return values of
rtems_filesystem_evaluate_path().
PR 1696/networking:
* libnetworking/arpa/inet.h: Partial update from FreeBSD.
#include <rtems/endian.h>.
Remove addr2ascii, ascii2addr.
* libnetworking/libc/addr2ascii.c,
libnetworking/libc/ascii2addr.c,
libnetworking/libc/addr2ascii.3: Remove.
* libnetworking/Makefile.am: Reflect changes above.
* posix/include/devctl.h, posix/src/devctl.c: Remove.
* posix/Makefile.am: Remove devctl.
* posix/src/killinfo.c: Ensure interested is non-NULL before using it.
* libcsupport/src/privateenv.c: Add macro to test status when
RTEMS_DEBUG is enabled. Note than evaluation of root directory should
always work.
* libcsupport/src/getlogin.c: Modify to use strncpy() on all paths.
PR 1694/shell
* libmisc/shell/main_setenv.c: Address memory leak identified by
Coverity.
