Remove superfluous check for the objects maximum since the maximum is
also used as a loop limit.
Fix formatting.
Check for an integer overflow. Add a validation test for task create
errors.
CID 1468688: Unchecked return value in snapshot_thread().
Closes #4262
CID 1459004: Unchecked return value in endgrent().
Closes #4261
CID 1456677: Unchecked return value in resolve_hold_back().
Closes #4260
CID 1399710: Unchecked return value in printer_task().
CID 1472764: Unchecked return value in rtems_print_printer_task().
Closes #4258
Update #4267.
Close the thread object if a thread create extension fails. Also call
the delete extension to avoid resource leaks in early extensions if a
late extension fails.
Close #4270.
Update #4267.
Update #4267.
Update #4267.
Update #4267.
Update #4267.
Update #4269.
Update #4269.
Use the right system initialization step for the stack allocator
initialization. Do the stack allocator initialization before the
workspace initialization so that _Memory_Allocate() can be used to get
memory for the allocator.
This type is not only used by Task Manager directives. This is a
preparation to move the rtems_scheduler_*() directives from
<rtems/rtems/tasks.h> to a new <rtems/rtems/scheduler.h>.
Call _Thread_queue_Flush_critical() directly.
Use the number of threads which must arrive at the barrier to trip the
automatic release also to indicate if the barrier is a manual release
barrier.
Use the type safe _Objects_Open_u32() instead. Return the object
identifier to enforce a common usage pattern.
Do the preemption and ASR processing changes in one rush and acquire the
thread state lock only once.
Do the mode changes necessary for the ASR processing directly under
protection of the thread state lock to avoid the recursive calls to
thread dispatching done in rtems_task_mode().
Close #4244.
Update #4244.
Ensure that no invalid modes are set during ASR processing.
Update #4244.
This call just obfuscated the call to _ISR_Set_level().
Update #4244.
The api pointer is never NULL.
Update #4244.
Remove superfluous ASR_Information::signals_posted. Move code out of
trivial inline functions.
Update #4244.
Move _Signal_Action_handler() and signal MP initialization to
rtems_signal_send(). The goal is to make _Signal_Action_handler() a
static function in a follow up patch.
Update #4244.
Update #4244.
Update #4244.
Update #4244.
Update #4244.
Require that the corresponding lock is acquired before the action
handler returns. This helps to avoid recursion in the signal
processing.
Update #4244.
Change license to BSD-2-Clause according to file histories and
documentation re-licensing agreement.
Update #3899.
Update #3993.
CID 1467420: Dereference before null check in rtems_shell_line_editor().
Closes #4254
Update #3899.
Update #3993.
Update #3899.
Update #3993.
Update #3899.
Update #3993.
Unify the wording across similar directives of other managers.
Update #3993.
Update #3993.
Update #3993.
Unify the wording across similar directives of other managers. Add
"CONSTRAINTS" section.
Update #3993.
Update #3993.
CID 1468681: Dereference before null check in rtems_debugger_thread_continue().
CID 1468690: Dereference before null check in rtems_debugger_thread_system_resume().
CID 1468694: Dereference before null check in rtems_debugger_thread_find_index().
Closes #4241.
CID 1468682: swbreaks is assigned a value dereferenced from target before
it has been verified that target is not null.
Closes #4240.
