1997-10-08 | Fixed typo in the pointer to the license terms. | Joel Sherrill | 250 | -500/+500 | |
1997-10-06 | Fixed comment. | Joel Sherrill | 1 | -1/+1 | |
1997-10-06 | Make Post an atomic operation. | Joel Sherrill | 2 | -2/+12 | |
1997-10-06 | Added _Thread_Enable_dispatch to already_timedout path on Wait_support. | Joel Sherrill | 1 | -2/+3 | |
1997-10-05 | If the specified time period is less than a clock tick, then | Joel Sherrill | 1 | -1/+4 | |
it is arbitrarily assumed to be 1 clock tick. | |||||
1997-09-30 | fixed typo | Joel Sherrill | 1 | -1/+1 | |
1997-09-30 | Fixed typos. | Joel Sherrill | 1 | -1/+1 | |
1997-09-21 | Uncommented gettimeofday_r to resolve missing symbol. | Joel Sherrill | 1 | -2/+0 | |
1997-09-21 | Cleaned up as part of adding the Monitor test. | Joel Sherrill | 17 | -27/+21 | |
1997-09-19 | Bug fix from Eric Norum: | Joel Sherrill | 1 | -1/+0 | |
After weeks of trying to figure why my RTEMS/KASQ server crashes now and then I found a nasty bug I introduced in adding multiple-driver support to libio. The bug only affects `add-on' driver classes (like the networking code). Old-style file descriptors were not affected. The bug cleared 32 bytes of memory (unspecified location) whenever a `close' of a socket was performed! I was clearing an IOP I hadn't allocated -- and the pointer wasn't initiallized, either! | |||||
1997-09-16 | updated | Joel Sherrill | 1 | -4/+11 | |
1997-08-28 | Fixed IO Manager calls to remove an argument which was used in 3.2.1 | Joel Sherrill | 2 | -64/+9 | |
but not in newer RTEMS. | |||||
1997-08-28 | Added RTEMS_IO_ERROR status code. | Joel Sherrill | 2 | -1/+3 | |
1997-08-28 | Added IO_Error status code and fixed No_Memory error number. | Joel Sherrill | 1 | -3/+5 | |
1997-08-27 | Added error numbers and changed default error code from 0 to -1 for | Joel Sherrill | 1 | -7/+9 | |
error number mapping. | |||||
1997-08-22 | Corrected bug per Katsutoshi Shibuya's report: | Joel Sherrill | 2 | -4/+4 | |
The definition of "BEGIN_DATA" should not be null; should be ".data". Also, the definition of "BEGIN_BSS" should be ".bss". For this error, the compiled object has codes that write on the text segment area. It is fatal when the code runs on ROM. | |||||
1997-08-22 | Removed assert condition when not initialized or there are 0 periods. | Joel Sherrill | 1 | -0/+5 | |
1997-08-22 | Moved reentrant wrappers into their own file. | Joel Sherrill | 1 | -4/+2 | |
1997-08-22 | Fixed iop/memory leak bug reported by Dan Dickey. | Joel Sherrill | 1 | -1/+6 | |
1997-08-22 | Fixed infinite recursion bug in PTHREAD_MUTEX_INITIALIZER. | Joel Sherrill | 1 | -10/+15 | |
1997-08-22 | Added commit about missing support for condition initializer. | Joel Sherrill | 1 | -0/+1 | |
1997-08-04 | new implementation of mc68681.h | Joel Sherrill | 1 | -72/+291 | |
1997-08-04 | Added GNAT configuration parameters. | Joel Sherrill | 1 | -4/+19 | |
1997-08-04 | moved from main include directory | Joel Sherrill | 5 | -0/+478 | |
1997-08-02 | Added these files to contain bodies for routines included in the API | Joel Sherrill | 2 | -0/+101 | |
but which did not have real bodies. This is necessary for languages like Ada95 which must have real entries in a library for bindings. | |||||
1997-08-01 | Katsutoshi Shibuya (shibuya@mxb.meshnet.or.jp)of BU-Denken Co., Ltd. | Joel Sherrill | 2 | -0/+191 | |
(Sapporo, Japan) submitted the extended console driver for the MVME162LX BSP and the POSIX tcsetattr() and tcgetattr() routines. This device driver supports four serial ports, cooked IO, and provides a portable base for Zilog 8530 based console drivers. | |||||
1997-07-31 | Merged very large and much appreciated patch from Chris Johns | Joel Sherrill | 2 | -4/+110 | |
<cjohns@plessey.com.au>. This patch includes the ods68302 bsp, the RTEMS++ class library, and the rtems++ test. | |||||
1997-07-31 | Added rtems_message_queue_get_number_pending directive. | Joel Sherrill | 4 | -17/+107 | |
1997-07-18 | fixed typo | Joel Sherrill | 1 | -4/+4 | |
1997-07-10 | Reordered specs. | Joel Sherrill | 1 | -4/+4 | |
1997-07-10 | fixed milliseconds and microseconds to tick conversion routines. | Joel Sherrill | 1 | -11/+10 | |
1997-07-09 | Repository damaged -- files readded. | Joel Sherrill | 1 | -0/+214 | |
1997-07-09 | Changed name from entry to thread_entry to be more compatible with | Joel Sherrill | 2 | -2/+2 | |
Ada interface where entry is a keyword. | |||||
1997-07-09 | Added postswitch extension. | Joel Sherrill | 1 | -0/+2 | |
1997-07-09 | Added post switch extension. | Joel Sherrill | 1 | -0/+5 | |
1997-07-09 | Corrected typos and spacing. | Joel Sherrill | 1 | -3/+3 | |
1997-07-09 | Added sp, sfc, and fpcsr register defines. | Joel Sherrill | 2 | -0/+8 | |
1997-06-03 | Added True and False constants for RTEMS.Boolean types. This necessitated | Joel Sherrill | 2 | -8/+36 | |
making sure every True/False reference was fully qualified. | |||||
1997-06-03 | Added RTEMS boolean constants. | Joel Sherrill | 1 | -0/+3 | |
1997-06-03 | Added Pending_Events and lined up other event constants | Joel Sherrill | 1 | -33/+34 | |
1997-06-03 | added more constants and fixed numer | Joel Sherrill | 2 | -24/+64 | |
1997-06-03 | added Signal constants, Is_Status_Successful, and Attribute constants. | Joel Sherrill | 2 | -5/+74 | |
1997-06-03 | added rtems_interrupt_level_attribute routien to return a properly | Joel Sherrill | 2 | -16/+6 | |
shifted interrupt_level attribute field and RTEMS_INTERRUPT_MASK. | |||||
1997-06-02 | added Minimum_Stack_Size and Mode constants | Joel Sherrill | 1 | -8/+23 | |
1997-06-02 | added new files from test area. | Joel Sherrill | 2 | -0/+3372 | |
This code has successfully been used to run sp01. | |||||
1997-05-28 | Added support for context switching the data used by the gcc m68k | Joel Sherrill | 3 | -2/+31 | |
software floating point emulation code. Code implemented by Karen Sara Looney <Karen.Looney@colorado.edu> with much email assistance from Joel. | |||||
1997-04-25 | Corrected by adding check for NULL address passed into get_status | Joel Sherrill | 1 | -0/+3 | |
directive. | |||||
1997-04-25 | Added to comment header block to include new status directive. | Joel Sherrill | 1 | -0/+1 | |
1997-04-22 | Patch from Chris John <cjohns@awa.com.au> to add use of a select statement | Joel Sherrill | 2 | -2/+138 | |
in the unix port idle thread task. This should keep the entire application from blocking when any component does a blocking application. Also added TOD_MICROSECONDS_TO_TICKS. | |||||
1997-04-22 | promote TOD_MICROSECONDS_TO_TICKS through API as RTEMS_MICROSECONDS_PER_TICK. | Joel Sherrill | 1 | -0/+2 | |
