* Makefile.am, preinstall.am, libmisc/Makefile.am: Changed the name of
mw-fb directory into fb. Relocated files.
* libmisc/fb/fb.h, libmisc/fb/mw_uid.c, libmisc/fb/mw_uid.h: New files.
* libmisc/mw-fb/fb.h, libmisc/mw-fb/mw_uid.c, libmisc/mw-fb/mw_uid.h:
Removed.
* sapi/include/confdefs.h, score/Makefile.am,
score/include/rtems/score/thread.h: Only instantiate
_Thread_Idle_body() if it is going ot be used.
* score/src/threadidlebody.c: Removed.
* rtems/score/cpu.h: Mark _CPU_Context_restore() as noreturn so the
compiler will not generate code thinking it returns.
* posix/src/pthread.c: Address sporadic server edge cases. Do not
change priority if thread is holding a priority ceiling or
inheritance mutex. Do not change it if it looks like the thread has
manually changed its priority. Style cleanup on file with new
comments added.
* score/src/heapallocatealigned.c: Remove unused label.
* score/src/heapallocatealigned.c: Change break to continue to fix
issue encountered on ARM. Fix indentation.
* rtems/src/timerreset.c: Rework to ease analysis.
* aclocal/check-networking.m4: Disable BSD TCP/IP for small memory
targets.
* rtems/src/clockget.c: Restructure to ease coverage analysis of
deprecated routine.
* libi2c/libi2c.c: Fix warnings.
* libcsupport/src/termios_baud2num.c: B134 should return 134 not 135.
* libcsupport/src/malloc_boundary.c: This is currently non-funcitonal.
Do not build it when doing coverage until it works again.
* sapi/include/confdefs.h: Address linking errors when building for
configuration.
* libcsupport/Makefile.am: Obsolete coverage file.
* libcsupport/src/end_profile.c: Removed.
* libcsupport/Makefile.am, libcsupport/preinstall.am,
posix/Makefile.am, posix/preinstall.am, rtems/Makefile.am,
rtems/preinstall.am, score/Makefile.am, score/preinstall.am: Revert
modifications accidentally committed.
* score/include/rtems/debug.h: Fix typo.
* cpu.c, cpu_asm.S, rtems/score/cpu.h: Fix bug in
_CPU_Context_Initialize.
* libcsupport/src/__times.c, libfs/src/nfsclient/src/nfsTest.c,
libfs/src/nfsclient/src/rpcio.c: Convert calls to legacy routine
rtems_clock_get( RTEMS_CLOCK_GET_xxx, ..) to rtems_clock_get_xxx().
* score/src/heapresizeblock.c: Remove printk's that were accidentally
committed.
* libcsupport/Makefile.am, posix/Makefile.am, rtems/Makefile.am,
sapi/Makefile.am, score/Makefile.am,
score/include/rtems/score/heap.h: HEAP_BLOCK_USED_OVERHEAD was under
by one uint32_t. This showed up in the unlimited and heapwalk tests
on ARM targets.
* score/src/objectextendinformation.c: Minor rework to eliminate
uncovered ranges introduced by Chris' patch.
* score/src/objectextendinformation.c: Ensure that nothing is moved or
copied until all memory is successfully allocated.
* posix/src/mqueuecreatesupp.c, posix/src/mqueuenametoid.c,
posix/src/mqueueopen.c, posix/src/semaphorecreatesupp.c: Tinker with
error handling for name too long. Use strnlen to ensure we do not run
off the end of the maximum length string.
* rtems/include/rtems/rtems/types.h: Improve documentation.
* libmisc/bspcmdline/bspcmdline.h, libmisc/bspcmdline/bspcmdline_get.c,
libmisc/bspcmdline/bspcmdline_getparam.c,
libmisc/bspcmdline/bspcmdline_getparamraw.c,
libmisc/bspcmdline/bspcmdline_getparamrhs.c: Add rtems_ as prefix to
all routines.
* Makefile.am: added AVR specific Header files to score/cpu/avr/avr.
These are from avr-libc 1.6 and assumed to exist by AVR applications.
* preinstall.am: Regenerated.
* libblock/src/bdbuf.c: Fix group user logic.
* libblock/include/rtems/blkdev.h, libblock/src/blkdev.c,
libblock/src/nvdisk.c, libblock/src/flashdisk.c: Add set block
size, and get media block size support.
* posix/src/sigaction.c: _POSIX_signals_Clear_process_signals now takes
signal number not mask.
* libcsupport/Makefile.am, rtems/Makefile.am, rtems/preinstall.am,
sapi/Makefile.am, sapi/preinstall.am, score/Makefile.am,
score/preinstall.am, score/include/rtems/score/heap.h,
score/inline/rtems/score/heap.inl: Remove inline version now that it
is in a C file.
* libcsupport/src/end_profile.c: New file.
* score/Makefile.am: Move from inline to body to avoid path explosion
from inlining this. Makes coverage analysis easier.
* score/src/heapalignupuptr.c: New file.
libmisc/bspcmdline/bspcmdline_getparamrhs.c: New files.
Missed in previous commit.
* Makefile.am, preinstall.am, libmisc/Makefile.am, wrapup/Makefile.am:
Add new BSP Boot Command Line helper routines. Recently boot_card()
has grown the ability to have a command line string pointer. These
routines provide an interface to that string.
* sapi/include/confdefs.h: Fix typo.
* posix/src/psignalclearsignals.c: Add comments.
* libcsupport/include/rtems/libio_.h,
libcsupport/src/fs_null_handlers.c: Null handlers are now const.
* libi2c/libi2c.c, libi2c/libi2c.h: Documentation. Do not create
semaphores on the fly.
* cpukit/libblock/src/bdpart.c: Fixed format specifier.
* cpukit/libblock/include/rtems/bdbuf.h, rtems/include/rtems.h,
rtems/include/rtems/rtems/asr.h, rtems/include/rtems/rtems/attr.h,
rtems/include/rtems/rtems/barrier.h,
rtems/include/rtems/rtems/barriermp.h,
rtems/include/rtems/rtems/cache.h, rtems/include/rtems/rtems/clock.h,
rtems/include/rtems/rtems/config.h, rtems/include/rtems/rtems/dpmem.h,
rtems/include/rtems/rtems/event.h,
rtems/include/rtems/rtems/eventmp.h,
rtems/include/rtems/rtems/eventset.h,
rtems/include/rtems/rtems/intr.h, rtems/include/rtems/rtems/message.h,
rtems/include/rtems/rtems/modes.h, rtems/include/rtems/rtems/mp.h,
rtems/include/rtems/rtems/msgmp.h, rtems/include/rtems/rtems/object.h,
rtems/include/rtems/rtems/part.h, rtems/include/rtems/rtems/partmp.h,
rtems/include/rtems/rtems/region.h,
rtems/include/rtems/rtems/regionmp.h,
rtems/include/rtems/rtems/rtemsapi.h, rtems/include/rtems/rtems/sem.h,
rtems/include/rtems/rtems/semmp.h, rtems/include/rtems/rtems/signal.h,
rtems/include/rtems/rtems/signalmp.h,
rtems/include/rtems/rtems/status.h,
rtems/include/rtems/rtems/support.h,
rtems/include/rtems/rtems/taskmp.h, rtems/include/rtems/rtems/tasks.h,
rtems/include/rtems/rtems/timer.h, rtems/include/rtems/rtems/types.h,
rtems/inline/rtems/rtems/support.inl: Documentation.
* include/rtems/irq-extension.h: Documentation. Added API for
interrupt servers.
* sapi/include/confdefs.h: Account for memory for POSIX message queue
file descriptors.
* posix/src/mqueuecreatesupp.c: Now that the number of POSIX message
queues and message queue descriptors are independently configured,
this code is reachable.
* posix/include/rtems/posix/psignal.h, posix/src/mqueuecreatesupp.c,
posix/src/psignalclearsignals.c: Minor rework to ease coverage
analysis.
* rtems/include/rtems/rtems/intr.h, rtems/src/intrcatch.c: Disable
rtems_interrupt_catch on targets which do not use the simple vectored
interrupt model.
* score/src/heapallocatealigned.c: Fix spacing.
* score/src/wkspace.c: Improve debug output.
* posix/include/rtems/posix/config.h, posix/src/mqueue.c,
sapi/include/confdefs.h: Add configuration of posix message queue
file descriptors as separate entity.
* rtems/include/rtems/rtems/region.h: Use new name.
* score/include/rtems/debug.h: Fix spacing.
* libmisc/dummy/dummy-networking.c: New.
* libmisc/dummy/dummy.c, libmisc/Makefile.am: Move
trhe networking configuration into a separate file so
configuration varations do not cause conflicts.
* score/inline/rtems/score/object.inl,
score/include/rtems/score/object.h: Remove warnings.
* score/inline/rtems/score/object.inl: Add _Chain_First,
_Chain_Last, _Chain_Mext, and _Chain_Previous.
* sapi/inline/rtems/chain.inl: Add rtems_chain_first,
rtems_chain_last, rtems_chain_mext, and rtems_chain_previous.
* libblock/include/rtems/diskdevs.h: Remove the bdbuf pool id and
block_size_log2. Add media_block_size.
* libblock/src/diskdevs.c: Remove size restrictions on block
size. Add media block size initialisation. Remove comment to clean
up the bdbuf cache.
* libblock/src/blkdev.c: Remove references to
block_size_log2. Allow any block size.
* libblock/include/rtems/bdbuf.h, libblock/src/bdbuf.c: Remove all
references to pools and make the cache handle demand driver
variable buffer size allocation. Added worker threads support the
swapout task.
* sapi/include/confdefs.h: Updated the bdbuf configutation.
* sapi/include/confdefs.h: Account for allocation of user extension
data area pointers.
* Makefile.am, preinstall.am, libmisc/Makefile.am: changed the
references to mw_fb.h into fb.h
* libmisc/mw-fb/mw_fb.h: renamed fb.h
