* wrapup/Makefile.am: Remove $(ARCH)/$(dirstamp).
Add TMPINSTALL_FILES to CLEANFILES.
* Makefile.am: Re-add dirstamps to PREINSTALL_FILES.
Add PREINSTALL_FILES to CLEANFILES.
Add cpuopts.h to DISTCLEANFILES.
* netinet/in_cksum.c: #include netinet/in_cksum_<cpu>.h.
* Makefile.am: Move include_adadir into RTEMS_ADA condional block.
Add CLEANFILES. Add PREINSTALL_FILES to CLEANFILES.
* automake/local.am: Remove depend-am.
* automake/subdirs.am: Remove depend-recursive.
PR/549 networking
* netinet/in_cksum_powerpc.h: New (copy of in_cksum_powerpc.c).
* netinet/in_cksum_powerpc.c: Remove.
* netinet/in_cksum_i386.h: New (copy of in_cksum_i386.c).
* netinet/in_cksum_i386.c: Remove.
* netinet/in_cksum_arm.h: New (copy of in_cksum_arm.c).
* netinet/in_cksum_arm.c: Remove.
* netinet/in_cksum_m68k.c: New (copy of in_cksum_m68k.c).
* netinet/in_cksum_m68k.c: Remove.
* netinet/Makefile.am: Reflect changes above.
PR 548/rtems
* Makefile.am: Add src/envlock.c.
* configure.ac: Requires automake >= 1.8.1.
* cpu/Makefile.am: Use @RTEMS_CPU@ instead of $(RTEMS_CPU).
* aclocal/rtems-top.m4: Don't AC_SUBST PROJECT_ROOT.
Remove PROJECT_TOPdir (Unused).
* aclocal/env-rtemscpu.m4: Remove PROJECT_RELEASE.
Expand ${PROJECT_ROOT}.
Remove RTEMS_ENABLE_BARE (Unused).
Don't AC_SUBST RTEMS_BSP.
* aclocal/enable-bare.m4: Remove (Unused).
* aclocal/rtems-top.m4: Remove check for cpukit/aclocal/version.m4.
Remove gnu-make endif HACK (Unused).
* Makefile.am: Reformat, add UNUSED_FILES.
* Makefile.am: Include compile.am, again.
Cleanup.
Reformat/Cleanup.
Put man-pages into EXTRA_DIST to work around automake not
distributing conditionally installed *_MANS.
Distribute include/rpcsvc.
Eliminate DOC_FILES.
Eliminate C_FILES. Reformat.
* wrapup/Makefile.am: Include compile.am.
Use TMP_LIBS instead of LIBS to avoid potential conflicts with
auto*tools' LIBS.
Reflect new locations of libscorecpu*.a
* Makefile.am: Include compile.am again. Misc fixes.
* Makefile.am: Remove AUTOMAKE_FILES.
* automake/compile.am: Replace contents with contents of
automake/amcompile.am.
* automake/amcompile.am, automake/lib.am: Remove.
* macros/rtems/score/README: Remove (Redundant with macros/README).
* Makefile.am: Convert to using automake compilation rules.
* configure.ac, aclocal/enable-bare.m4,
aclocal/enable-inlines.m4, aclocal/enable-itron.m4,
aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4,
aclocal/enable-posix.m4, aclocal/enable-rtems-debug.m4, aclocal/multi.m4,
aclocal/multilib.m4: Use AS_HELP_STRING instead of AC_HELP_STRING
(deprecated in autoconf-2.59)
* automake/local.am: Remove clean-local, depend-gcc.
* Makefile.am: Remove *C_FILES.
* Makefile.am: Add libs to CLEANFILES
Set lib*_g_a_SOURCES = lib*_a_SOURCES.
* aclocal/enable-networking.m4: Don't AC_SUBST(RTEMS_HAS_NETWORKING).
* aclocal/check-networking.m4: Don't AC_SUBST(HAS_NETWORKING).
* automake/amcompile.am: Remove $(ARCH).
* wrapup/Makefile.am: Add $(ARCH).
Remove compile.am, lib.am.
Include amcompile.am.
* wrapup/Makefile.am: Use ../*/*$(LIB_VARIANT).a instead of
$(ARCH)/lib*.a.
* Makefile.am: Build lib*$(LIB_VARIANT).a instead of
$(ARCH)/lib*.a.
* Makefile.am: Build libposix$(LIB_VARIANT).a instead of
$(ARCH)/libposix.a.
* Makefile.am: Build libitron$(LIB_VARIANT).a instead of
$(ARCH)/libitron.a.
* Makefile.am: Build libscore$(LIB_VARIANT).a instead of
$(ARCH)/libscore.a.
* Makefile.am: Build librtems$(LIB_VARIANT).a instead of
$(ARCH)/librtems.a.
* Makefile.am: Build libcsupport$(LIB_VARIANT).a instead of
$(ARCH)/libcsupport.a.
* include/rtems/blkdev.h, include/rtems/ide_part_table.h,
src/bdbuf.c, src/ide_part_table.c, src/ramdisk.c:
Switch to using c99 fixed size types instead of RTEMS-types.
* Makefile.am: Build libblock$(LIB_VARIANT).a instead of
$(ARCH)/libblock.a.
Reflect changes to libblock/Makefile.am.
Reflect changes to libcsupport/Makefile.am.
* qsm.h, sim.h: Remove efi68k and efi332 references as they are no
longer in the tree.
* aclocal/rtems-cpu-subdirs.m4: mips64orion port removed as mips port
more completely covers the MIPS family.
* rtems/rtems_bsdnet_internal.h: Include rtems/cdefs.h so things
compile.
* rtems/score/mips.h: Removed junk revision line.
* cpu/Makefile.am: mips64orion port removed as mips port more
* cpu/mips64orion/.cvsignore, cpu/mips64orion/ChangeLog,
cpu/mips64orion/Makefile.am, cpu/mips64orion/asm.h,
cpu/mips64orion/configure.ac, cpu/mips64orion/cpu.c,
cpu/mips64orion/cpu_asm.S, cpu/mips64orion/cpu_asm.h,
cpu/mips64orion/idtcpu.h, cpu/mips64orion/idtmon.h,
cpu/mips64orion/iregdef.h, cpu/mips64orion/rtems/.cvsignore,
cpu/mips64orion/rtems/score/.cvsignore,
cpu/mips64orion/rtems/score/cpu.h,
cpu/mips64orion/rtems/score/mips64orion.h,
cpu/mips64orion/rtems/score/types.h: Removed.
* wrapup/Makefile.am: Reflect changes to library Makefile.ams.
* Makefile.am: Build library using EXTRA_LIBRARIES and automake rules.
* automake/amcompile.am: New.
* configure.ac: Add subdir-objects, AM_PROG_CC_C_O.
