PR 1477/cpukit
* score/src/objectsetname.c: Ensure destination is NULL terminated.
String copy was not getting the NULL.
* libnetworking/sys/uio.h: Include <sys/types.h>.
Use ssize_t for uio_resid in struct uio (From FreeBSD).
* posix/Makefile.am: Unconditionally build
posix/src/sigaddset.c, posix/src/sigdelset.c,
posix/src/sigfillset.c, posix/src/sigemptyset.c,
posix/src/sigismember.c.
* posix/src/sigaddset.c, posix/src/sigdelset.c,
posix/src/sigemptyset.c, posix/src/sigfillset.c,
posix/src/sigismember.c, posix/src/sigprocmask.c:
Remove unnecessary includes.
* posix/Makefile.am: Unconditionally install
posix/include/rtems/posix/sigset.h.
* posix/include/rtems/posix/psignal.h: Reflect having split out
* posix/include/rtems/posix/sigset.h: New (Split out from
posix/include/rtems/posix/psignal.h).
* posix/Makefile.am: Unconditionally build src/wait.c src/waitpid.c.
* posix/Makefile.am: Unconditionally build fork.c, vfork.c.
* configure.ac, posix/Makefile.am, wrapup/Makefile.am:
Eliminate AM_CONDITIONAL LIBPOSIX.
* libcsupport/src/__times.c, libmisc/cpuuse/cpuusagedata.c,
libmisc/cpuuse/cpuusagereport.c, libmisc/cpuuse/cpuusagereset.c,
rtems/include/rtems/rtems/types.h, rtems/src/ratemongetstatistics.c,
rtems/src/ratemonreportstatistics.c, score/src/threaddispatch.c,
score/src/threadinitialize.c, score/src/threadtickletimeslice.c:
Updated copyright line.
* configure.ac, libcsupport/src/__times.c,
libmisc/cpuuse/cpuusagedata.c, libmisc/cpuuse/cpuusagereport.c,
libmisc/cpuuse/cpuusagereset.c, rtems/include/rtems/rtems/ratemon.h,
rtems/src/ratemongetstatus.c, rtems/src/ratemonperiod.c,
score/include/rtems/score/thread.h, score/src/threaddispatch.c,
Changed the configuration of statistics granularity to use just one
define.
* shttpd/def.h: Use __m32c__ for m32c.
* shttpd/def.h: Shrink default URI_MAX to 32767.
Add special cases for sizeof(size_t) < 2.
* rtems/score/avr.h: Add avr6.
* score/cpu/powerpc/rtems/score/cpu.h: Added space for non-
volatile AltiVec registers to context struct. Added declaration
for AltiVec-related routines to be implemented by CPU/BSP
support.
* libmisc/stringto/stringto.h, libmisc/stringto/stringto_template.h:
Tidy up as part of adding new test.
* libcsupport/Makefile.am: Split no_posix.c so using sleep() does not
pull in kill() stubs.
* libcsupport/src/kill_noposix.c, libcsupport/src/sleep_noposix.c:
New files.
* libcsupport/src/no_posix.c: Removed.
* libmisc/shell/login_prompt.c: Fix problem where timeout on login
prompt at console results in tight loop repeating login prompt.
* score/src/threaddelayended.c: Clear only the states that are used to
block until someone calls _Thread_Delay_ended().
infinite output drain loop
_Heap_Allocate_aligned_with_boundary().
Changed type of boolean variables to bool. Use unsigned integer type
for radix and width parameters.
Avoid designated initializers for C++ compatibility
Fixed invalid state transition from FRESH to CACHED
Free memory in case of an error.
Removed _Timer_Server thread pointer
Added _Timer_server pointer to the default timer server control block
Rework of the timer server implementation.
* libmisc/shell/shell.c: Always duplicate the environment passed to us
because we will delete it when the shell exits. If we do not
duplicate it, we could end up freeing memory which was not allocated
from the heap or double freeing it.
* libmisc/shell/login_prompt.c: Properly process EOF and do not depend
on ungetc() to propagate the status back.
