* | updates from Tony Bennett. | Joel Sherrill | 1996-05-23 | 1 | -58/+76 |
| | | | | | Broke the setjmp/longjmp pair in the context switch into a separate routine so no code depended on local variables surviving the jump. | ||||
* | Modified to correct variables which defined the range of object classes | Joel Sherrill | 1996-05-22 | 1 | -1/+1 |
| | | | | which are tasks. | ||||
* | These files have been modified in the initial pass at getting the portion | Joel Sherrill | 1996-05-22 | 14 | -7/+24 |
| | | | | | | of the POSIX API necessary to support the GNAT runtime to initially compile. We now have verified that the specifications for the necessary routines are correct per the POSIX standards we have. | ||||
* | These files have been modified in the initial pass at getting the portion | Joel Sherrill | 1996-05-22 | 1 | -1/+1 |
| | | | | | | | | | of the POSIX API necessary to support the GNAT runtime to initially compile. We now have verified that the specifications for the necessary routines are correct per the POSIX standards we have. The removed files were moved to newlib as they were duplicates of files already included there. | ||||
* | This commit was generated by cvs2svn to compensate for changes in r257, | Ralf Corsepius | 1996-05-21 | 2 | -0/+1574 |
|\ | | | | | which included commits to RCS files with non-trunk default branches. | ||||
| * | Import from zlib-1.2.4 | Ralf Corsepius | 1996-05-21 | 2 | -0/+1574 |
* | fixed typo | Joel Sherrill | 1996-05-10 | 1 | -1/+1 |
* | *** empty log message *** | Joel Sherrill | 1996-05-08 | 1 | -1/+2 |
* | Updates from Eric Norum to use the mcpu32 flags and fix comments. | Joel Sherrill | 1996-05-01 | 2 | -54/+28 |
* | added comment regarding stack alignment issues to thread stack allocation | Joel Sherrill | 1996-04-24 | 1 | -0/+14 |
| | | | | routine. | ||||
* | updates from Tony Bennett | Joel Sherrill | 1996-04-22 | 22 | -181/+130 |
* | Updates from Tony Bennett. | Joel Sherrill | 1996-04-22 | 4 | -25/+34 |
* | thread.c: added support for optional user provided stack allocator | Joel Sherrill | 1996-04-22 | 2 | -8/+123 |
| | | | | wkspace.c: made initialization routine a regular subroutine | ||||
* | made initialization routine a regular subroutine | Joel Sherrill | 1996-04-22 | 2 | -88/+0 |
* | interr.h: added stack allocater error code | Joel Sherrill | 1996-04-22 | 2 | -1/+15 |
| | | | | wkspace.h: made initialization routine a regular subroutine | ||||
* | added stack allocation fields to the cpu table | Joel Sherrill | 1996-04-22 | 1 | -23/+53 |
| | | | | | updates from Tony Bennett. Most were to insure all variables were properly initialized and to correct the stray signal number reporting. | ||||
* | added stack allocation fields to the cpu table | Joel Sherrill | 1996-04-22 | 2 | -0/+1786 |
| | | | | added CPU_M68K_EXTB_L model flag | ||||
* | updartes from Tony Bennett | Joel Sherrill | 1996-04-22 | 1 | -256/+80 |
* | event.c: _Event_Manager_initialization no longer a static inline | Joel Sherrill | 1996-04-19 | 2 | -0/+29 |
| | | | | sem.c: modified to eliminate Purify warnings | ||||
* | _Event_Manager_initialization no longer a static inline | Joel Sherrill | 1996-04-19 | 1 | -19/+0 |
* | event.h: _Event_Manager_initialization no longer a static inline | Joel Sherrill | 1996-04-19 | 1 | -19/+0 |
* | event.h: _Event_Manager_initialization no longer a static inline | Joel Sherrill | 1996-04-19 | 2 | -0/+12 |
| | | | | support.h: updated to use RTEMS_APPLICATION macro | ||||
* | changes to compile in macro configuration without warnings. | Joel Sherrill | 1996-04-19 | 3 | -2/+24 |
* | *** empty log message *** | Joel Sherrill | 1996-03-21 | 2 | -6/+4 |
* | updated for 68302 and so gen68360 bsp would compile | Joel Sherrill | 1996-03-21 | 2 | -2/+6 |
* | As part of reducing visibility into rtems and hiding the .inl files | Joel Sherrill | 1996-03-06 | 8 | -0/+8 |
| | | | | | from the application code, this file required more visibility than is given by default to application code. | ||||
* | Removed prototyes for static inline routines and moved the comments into | Joel Sherrill | 1996-03-06 | 79 | -3420/+1212 |
| | | | | | | | | | | | | | | | the inline implementation. The impetus for this was twofold. First, it is incorrect to have static inline prototypes when using the macro implementation. Second, this reduced the number of lines in the include files seen by rtems.h by about 2000 lines. Next we restricted visibility for the inline routines to inside the executive itself EXCEPT for a handful of objects. This reduced the number of include files included by rtems.h by 40 files and reduced the lines in the include files seen by rtems.h by about 6000 lines. In total, these reduced the compile time of the entire RTEMS tree by 20%. This results in about 8 minutes savings on the SparcStation 10 morgana. | ||||
* | Removed prototyes for static inline rgutines and moved the comments into | Joel Sherrill | 1996-03-06 | 1 | -41/+2 |
* | Changed io manager initialization routine to not be static and added it here. | Joel Sherrill | 1996-02-21 | 1 | -0/+37 |
* | changed io manager initialization routine to not be static | Joel Sherrill | 1996-02-21 | 1 | -3/+1 |
* | Dispersal of internal thread handler resulted in the SYSI task being | Joel Sherrill | 1996-02-21 | 1 | -2/+2 |
| | | | | | | only required in a multiprocessor system. It was replace by the MPCI Receive Server. As a result, the CPU Table field for extra stack for the SYSI task was changed to be extra stack for the MPCI Receive Server. | ||||
* | Removed the internal thread objects and dispersed its contents to | Joel Sherrill | 1996-02-21 | 9 | -12/+532 |
| | | | | | | | | | | the thread handler (IDLE), MPCI object (SYSI now MP Receive) and initialize_executive_early (IO initialization). The SYSI task no longer exists in a single processor configuration. This reduces single processor Workspace requirements by a TCB and a stack which is often larger than the minimum stack size. Moving the IO initialization plus accompanying BSP hooks eliminated an initialization ordering problem in which a global task could be created before the MPCI was initialized. | ||||
* | Dispersal of internal thread handler resulted in IDLE thread becoming | Joel Sherrill | 1996-02-21 | 3 | -6/+6 |
| | | | | | part of the Thread Handler. This required the name of the optional CPU dependent IDLE thread implementation to change. | ||||
* | Removed the internal thread objects and dispersed its contents to | Joel Sherrill | 1996-02-21 | 1 | -12/+14 |
* | Removed arguments from _Thread_Start_multitasking. | Joel Sherrill | 1996-02-14 | 1 | -4/+1 |
* | idle thread now created before system initialization thread. | Joel Sherrill | 1996-02-14 | 1 | -4/+1 |
| | | | | Also system initialization thread only created in MP systems. | ||||
* | removed arguments from _Thread_Start_multitasking | Joel Sherrill | 1996-02-14 | 1 | -12/+10 |
* | white space problem | Joel Sherrill | 1996-02-14 | 1 | -1/+0 |
* | Moved some initialization from the system initialization thread to | Joel Sherrill | 1996-02-14 | 1 | -2/+42 |
| | | | | | initialize_executive_early. This was done to clear up an ordering problem in which global tasks could be created before the MPCI layer was initialized. | ||||
* | removed post switch extension | Joel Sherrill | 1996-02-13 | 1 | -1/+0 |
* | changed post task extension from user set to api set and added flag | Joel Sherrill | 1996-02-13 | 10 | -63/+56 |
| | | | | in each thread which must be set when the post switch extension is to be run. | ||||
* | more comments added and existing ones cleaned up in synchronization paths | Joel Sherrill | 1996-02-13 | 1 | -1/+13 |
* | comma removed from end of last enumerated element | Joel Sherrill | 1996-02-13 | 1 | -1/+1 |
* | comment added to describe synchronization logic in timeout routine | Joel Sherrill | 1996-02-13 | 1 | -0/+21 |
* | *** empty log message *** | Joel Sherrill | 1996-02-12 | 1 | -4/+0 |
* | new isr synchronization algorithm using a single enumerated set of states. | Joel Sherrill | 1996-02-09 | 7 | -59/+105 |
* | added rtems_interrupt_is_in_progress | Joel Sherrill | 1996-02-09 | 1 | -0/+14 |
* | added clear of _ISR_Signals_to_thread_executing | Joel Sherrill | 1996-02-09 | 2 | -0/+2 |
* | changed synchronization algorithm to be a single list of enumerated states | Joel Sherrill | 1996-02-08 | 1 | -2/+2 |
* | alignment on workspace changed from CPU_ALIGNMENT to CPU_HEAP_ALIGNMENT | Joel Sherrill | 1996-02-08 | 1 | -1/+1 |
