* libcsupport/src/tcflow.c, libcsupport/src/tcflush.c: Add switches
to detect bad input.
* libcsupport/src/tcsetpgrp.c: Fix typo.
* libcsupport/include/rtems/libio_.h: Declare
rtems_filesystem_mount_table_control.
* libcsupport/include/rtems/libio.h: Removed
rtems_filesystem_table_first(), rtems_filesystem_table_next() and
rtems_filesystem_table_node_t declarations. Declare
rtems_per_filesystem_routine, rtems_filesystem_iterate() and
rtems_filesystem_get_mount_handler().
* libcsupport/src/mount.c: Added rtems_filesystem_mounts_first() and
rtems_filesystem_mounts_next(). Simplify mount(). Removed
rtems_filesystem_mount_table_control_init. Use
* libcsupport/src/mount-mgr.c: Removed rtems_filesystem_mounts_first() and
rtems_filesystem_mounts_next(). Added rtems_filesystem_iterate() and
rtems_filesystem_get_mount_handler(). Use rtems_libio_lock() and
rtems_libio_unlock();
* sapi/include/confdefs.h, libmisc/shell/main_mount.c: Update for
mount API changes.
* libcsupport/include/rtems/libio_.h: Removed macros
rtems_filesystem_is_separator
rtems_filesystem_get_start_loc
rtems_filesystem_get_sym_start_loc
and added them as files under libcsupport/src/
* libcsupport/src/: Added new files
libcsupport/src/sup_fs_get_start_loc.c
libcsupport/src/sup_fs_get_sym_start_loc.c
libcsupport/src/sup_fs_is_separator.c
* libcsupport/Makefile.am: Changes to accommodate new
* score/include/rtems/score/heap.h: Declare
_Heap_Get_first_and_last_block(). Removed Heap_Extend_status.
Changed return type of _Heap_Extend() to bool.
* score/inline/rtems/score/heap.inl: Define
_Heap_Set_last_block_size().
* score/src/heap.c: Define and use _Heap_Get_first_and_last_block().
* score/src/heapgetinfo.c: Removed assert statements. Do not count
the last block. This ensures that all size values are an integral
multiple of the page size which is consistent with the other
statistics.
* score/src/heapextend.c: Implemented support for scattered heap
areas.
* score/src/heapwalk.c: Dump also last block. Changes for new first
and last block values.
* ./score/src/pheapextend.c, rtems/src/regionextend.c: Update for
_Heap_Extend() changes.
* sapi/include/confdefs.h: PR 1543. Make default file system when
nothing is defined IMFS not miniIMFS.
* libcsupport/include/rtems/libio.h: Make the struct name the same
as the typedef.
* sapi/include/confdefs.h: Fixes for use in C++.
* libmisc/shell/print-ls.c: Remove (long) cast of st_ino.
* libcsupport/include/rtems/libio.h, libcsupport/src/mount-mgr.c:
Add missing 'const'.
* libfs/src/nfsclient/src/xdr_mbuf.c: Warning removal.
* libcsupport/include/rtems/libio.h: Remove if 0 section. Formatting.
* libcsupport/Makefile.am: Add mount-mgr.c.
* libcsupport/src/mount-mgr.c: New.
* include/rtems/fs.h: Added rtems_filesystem_location_mount.
* libcsupport/include/rtems/libio.h, libcsupport/src/mount.c: New
mount interface. It is similar to Linux.
* libcsupport/include/rtems/libio_.h: Remove the
init_fs_mount_table call.
* libcsupport/src/base_fs.c: Remove init_fs_mount_table_call. Use
the new mount call. Remove setting the root node in the global
pathloc. Mount does this now.
* libcsupport/src/privateenv.c: Remove the hack to set the root
mount table entry in the environment.
* libcsupport/src/unmount.cL Free the target string.
* libblock/src/bdpart-mount.c: New mount API.
* libfs/src/devfs/devfs.h, libfs/src/devfs/devfs_init.c,
libfs/src/dosfs/dosfs.h, libfs/src/dosfs/msdos.h,
libfs/src/dosfs/msdos_init.c, libfs/src/imfs/imfs.h,
libfs/src/imfs/imfs_eval.c, libfs/src/imfs/imfs_init.c,
libfs/src/imfs/miniimfs_init.c,
libfs/src/nfsclient/src/librtemsNfs.h,
libfs/src/rfs/rtems-rfs-rtems.c, libfs/src/rfs/rtems-rfs.h,
libnetworking/lib/ftpfs.c, libnetworking/rtems/ftpfs.h,
libnetworking/rtems/tftp.h: New mount_h API.
* libfs/src/devfs/devfs_eval.c: Local include of extern ops.
* libfs/src/nfsclient/src/nfs.c: New mount API. Removed the mount
me call and fixed the initialisation to happen when mounting.
* libmisc/Makefile.am, libmisc/shell/shellconfig.h: Remove mount
filesystem files.
* libmisc/fsmount/fsmount.c, libmisc/fsmount/fsmount.h: Updated to
the new mount table values.
* libmisc/shell/main_mount_ftp.c,
libmisc/shell/main_mount_msdos.c, libmisc/shell/main_mount_rfs.c,
libmisc/shell/main_mount_tftp.c: Removed.
* libmisc/shell/main_mount.c: Use the new mount API. Also access
the file system table for the file system types.
* libnetworking/lib/tftpDriver.c: Updated to the new mount
API. Fixed to allow mounting from any mount point. Also can now
have more than file system mounted.
* sapi/include/confdefs.h: Add file system configuration support.
filesystem files.
* libfs/src/nfsclient/src/rpcio.c: Warning removal.
* irq.c: Change _exception_stack_frame into void*.
PR 1531/newlib:
* libmisc/shell/fts.c:
Add local copy of ALIGN().
* libnetworking/net/if.c:
Use uintptr_t and void* in _offsetof().
* libnetworking/netinet/raw_ip.c:
Cast nam to uintptr_t instead of int.
* libnetworking/libc/gethostnamadr.c:
Cast addr to uintptr_t instead of size_t.
* libfs/src/nfsclient/src/xdr_mbuf.c (xdrmbuf_setup):
* librpc/src/xdr/xdr_mem.c (xdr_memcreate):
* libfs/src/nfsclient/src/dirutils.c: Add PRIomode_t, PRIdoff_t.
* configure.ac: Add AC_CHECK_SIZEOF(mode_t), AC_CHECK_SIZEOF(off_t).
* libfs/src/rfs/rtems-rfs-rtems.c: Use size_t for node_len.
Try to make crazy address arithmetic more portable.
Use void* arithmetic instead of u_long arithmetic.
* libnetworking/netinet/raw_ip.c,
libnetworking/netinet/udp_usrreq.c:
Cast mbufs to uintptr_t instead of u_long.
* libnetworking/rtems/rtems_mii_ioctl.h,
libnetworking/rtems/rtems_mii_ioctl_kern.c:
Use uint32_t instead of int as ioctl cmd arg.
* libnetworking/lib/ftpfs.c, libnetworking/lib/tftpDriver.c:
Use size_t instead of int for pathnamelen.
Use size_t instead of int for pathlen.
Use %zi to print pathlen.
* libcsupport/include/rtems/libio_.h, libcsupport/src/eval.c:
* libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_eval.c:
* libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_eval.c:
* libfs/src/devfs/devfs.h, libfs/src/devfs/devfs_eval.c:
Use uint32_t instead of u_int_t for readarg and writearg.
* libfs/src/nfsclient/src/nfs.c: Introduce union nfs_evalpath_arg.
* librpc/src/rpc/clnt_tcp.c, librpc/src/rpc/clnt_udp.c:
Revert to using u_long instead of rpcprog_t, rpcvers_t
to stay bug-ward compatible to freebsd.
* librpc/src/xdr/xdr_mem.c: Cosmetics from freebsd.
Cast pointers to uintptr_t instead of long.
xids are uint32_t not u_long.
* libfs/src/nfsclient/src/nfs.c (NFS_MAKE_DEV_T_INO_HACK,
NFS_MAKE_DEV_T): Cast "id"'s to rtems_device_minor_number.
* libfs/src/nfsclient/src/rpcio.c, libfs/src/nfsclient/src/rpcio.h:
Use rpcprog_t for "program args", use rpcvers_t for "version args".
* librpc/src/rpc/rtems_portmapper.c: Reflect changes to librpc.
* librpc/include/rpc/clnt.h, librpc/include/rpc/rpc_msg.h,
librpc/src/rpc/clnt_generic.c, librpc/src/rpc/clnt_raw.c,
librpc/src/rpc/clnt_tcp.c, librpc/src/rpc/clnt_udp.c,
librpc/src/rpc/pmap_clnt.c, librpc/src/rpc/pmap_getmaps.c
librpc/src/rpc/pmap_getport.c:
Partial merger from freebsd (portability fixes).
* libnetworking/sys/socketvar.h (struct sockbuf):
Use void* instead of caddr_t.
Use address to rpciod in calls to rxWakeupCB.
* libnetworking/sys/socket.h (struct sockwakeup):
* librpc/include/rpc/xdr.h: Cosmetics from freebsd.
* librpc/src/rpc/clnt_udp.c: Cosmetics from freebsd.
* librpc/src/rpc/clnt_tcp.c: Partial merger from freebsd
(Fix strict-aliasing).
