Update #4105.
This adds a CPU port for AArch64(ARMv8) with support for exceptions and
interrupts.
Close #4120.
Before this patch RTEMS_Malloc_Initialize() had a fixed dependency on
_Workspace_Area. Introduce _Workspace_Malloc_initializer to have this
dependency only if CONFIGURE_UNIFIED_WORK_AREAS is defined by the
application configuration.
Check the name followed by the id check in all create directives.
Compare pointers against NULL. Fix formatting.
The implementation was added and removed in 2009.
This patch fixes a tiny bug in the command line editing of the RTEMS shell.
Typing CTRL-U in the shell should remove all characters left of the cursor.
After pressing CTRL-U, the current implementation does wrongly place the cursor
at the end of the line instead at its beginning.
To reproduce the bug, start the shell and type 'abc123' (no <RETURN>):
> ~/src/rtems $ qemu-system-arm -net none -nographic -M realview-pbx-a9 \
-m 256M -kernel build/arm/realview_pbx_a9_qemu/testsuites/libtests/dl10.exe
> *** BEGIN OF TEST libdl (RTL) 10 ***
> *** TEST VERSION: 6.0.0.d9bdf166644f612dd628fe4951c12c6f8e94ba5f
> *** TEST STATE: USER_INPUT
> *** TEST BUILD: RTEMS_DEBUG RTEMS_NETWORKING RTEMS_POSIX_API RTEMS_SMP
> *** TEST TOOLS: 10.2.1 20200904 \
(RTEMS 6, RSB 31f936a7b74d60bda609a9960c6e1a705ba54974, Newlib a0d7982)
> RTL (libdl) commands: dl, rtl
> RTEMS Shell on /dev/foobar. Use 'help' to list commands.
> SHLL [/] # abc123
Then move the cursor onto the '1' by hitting three times the <ARROW-LEFT> key.
Next type <CTRL>-U:
> SHLL [/] # 123
Note that the cursor is at the end of the line (after '3') instead of correctly
at the beginning (on the '1'), now.
Continuing typing 'echo ' incorrectly results in the output:
> SHLL [/] # 123echo 123
The patch changes this behavior so that the cursor in the second last step will
be on the '1' and typing 'echo ' will then correctly reflected as:
> SHLL [/] # echo 123
Close #4097.
In contrast to message queues created by rtems_message_queue_create(), the
message queues constructed by this directive use a user-provided message buffer
storage area.
Add RTEMS_MESSAGE_QUEUE_BUFFER() to define a message buffer type for message
buffer storage areas.
Update #4007.
Add Message_queue_Control::is_global if RTEMS_MULTIPROCESSING is defined. This
reduces the Message_queue_Control size in standard RTEMS configurations.
Update #4007.
Move the CORE_message_queue_Buffer definition to a separate header file to be
able to use it independent of the remaining Message Queue Handler API.
Change license to BSD-2-Clause according to file history.
Update #3053.
Update #4007.
Merge CORE_message_queue_Buffer structure into
CORE_message_queue_Buffer_control.
Use a zero-length array for the actual message buffer. This reduces the
structure size on all targets.
Update #4007.
Return a status code and differentiate between error conditions.
Update #4007.
Initialize the structure in a single code block after the error checks and
calculations.
Update #4007.
The previous multiplication error check is broken on 64-bit machines. Use the
recommended check from SEI CERT C Coding Standard, "INT30-C. Ensure that
unsigned integer operations do not wrap".
Make sure the message size computation does not overflow.
Update #4007.
Update #4007.
Issue found by Coverity (CID 1437643).
Debug output can be added to user-defined fatal error handlers.
Including <stdio.h> in <rtems/score/cpu.h> breaks libbsd.
Provide the default trace data in a separate file to avoid issues on targets
with a small-data area.
Close #3883.
Change license to BSD-2-Clause according to file history and
documentation re-licensing agreement.
Update #3053.
Update #3899.
Update #3993.
Move multiprocessing related definitions to <rtems/rtems/mp.h>. This
makes <rtems.h> an include only header file.
Move type related definition to <rtems/rtems/types.h>. The goal is to
make <rtems.h> an include only header file.
Move task related declarations and definitions to <rtems/rtems/tasks.h>.
The goal is to make <rtems.h> an include only header file.
Move object related declarations and definitions to
<rtems/rtems/object.h>. The goal is to make <rtems.h> an include only
header file.
Move configuration related declarations and definitions to
<rtems/config.h>. The goal is to make <rtems.h> an include only header
file.
Update #3959.
Add a general purpose test suite for validation tests.
This is the first test suite generated from a specification item in the
rtems-central repository.
Update #3959.
Update #3959.
In contrast to rtems_task_create() this function constructs a task with
a user-provided task storage area. The new directive uses a
configuration structure instead of individual parameters.
Add RTEMS_TASK_STORAGE_SIZE() to calculate the recommended size of a
task storage area based on the task attributes and the size dedicated to
the task stack and thread-local storage. This macro may allow future
extensions without breaking the API.
Add application configuration option
CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE to adjust RTEMS
Workspace size estimate.
Update #3959.
Add this application configuration option. This configuration option can be
used to reserve space for the dynamic linking of modules with thread-local
storage objects.
Add RTEMS_TASK_STORAGE_ALIGNMENT to define the minium alignment of a
thread-local storage size.
Update #4074.
Update #3959.
Update #4074.
Update #3959.
Update #4074.
If RTEMS_DEBUG is not defined, then we have to explicitly set the node
off the chain.
Update #3199.
In a multi-processor system we must broadcast the TLB maintenance operation to
the Inner Shareable domain to ensure that the other processors update their TLB
caches accordingly.
Close #4068.
Closes #4076.
Fix an error cleanup path in SMP configurations to avoid a NULL pointer access.
Update #3959.
This avoids a dependency to the stack free function in the thread
destruction.
Update #3959.
This decouples the task stack allocation from the deallocation.
Update #3959.
Do the stack allocator initialization and sanity check only if a
user-provided stack allocator was configured. This avoids a dependency
of _Thread_Handler_initialization() on the stack allocator.
Update #3959.
The nodes are never NULL.
Update #3959.
Hide implementation details.
Update #3959.
Update #3959.
Do not access executing->current_state outside the protection of the
thread state lock. Add missing state with a comment.
