* wrapup/Makefile.am: Install by using cpulibdir, cpulib_DATA.
* aclocal/check-bsp-cache.m4: Remove RTEMS_BSP_FAMILY.
* aclocal/project-root.m4: Remove.
* aclocal/enable-multiprocessing.m4: enable_multiprocessing=no.
* aclocal/prog-cc.m4: Remove obsolete comments.
Comment out GCCSED.
* src/__times.c: Cleaned up comments, return more information,
and eliminated the fatal error on clock not set since it cannot
occur.
* Addition of a ftp client filesystem, comparable to the tftp one.
* lib/ftpfs.c, rtems/ftpfs.h: New files.
* lib/Makefile.am, rtems/Makefile.am: Modified to reflect above.
* With the addition of serdbg, the standard polled I/O functions
for gdbstub and/or printk are optionally routed to any termios-aware
device driver, that supports polled mode. See libmisc/serdbg/README.
* serdbg/Makefile.am, serdbg/README, serdbg/serdbg.c, serdbg/serdbg.h,
serdbg/serdbgcnf.h, serdbg/serdbgio.c, serdbg/termios_printk.c,
serdbg/termios_printk.h, serdbg/termios_printk_cnf.h,
serdbg/.cvsignore: New files.
* configure.ac, Makefile.am, wrapup/Makefile.am: Modified to
reflect addition.
* Makefile.am, cpu.c, cpu_asm.S, rtems.S: Modified to make
this all compile again. It has been a while since we have
had a semi-working hppa1.1-rtems cross compiler. :)
* configure.ac: Add RTEMS_PROG_CCAS
* aclocal/prog-ccas.m4: New.
* aclocal/canonicalize-tools.m4: Remove AS, OBJCOPY, NM, SIZE, STRIP.
RTEMS_GCC_PRINT
* aclocal/check-multiprocessing.m4: Fix typo.
* automake/compile.am: Remove CXX support.
Replace AS by CCAS. Remove LINK_LIBS, LINK_OBJS, LINK_FILES.
RTEMS_GCC_PRINT
* configure.ac: Use AC_CONFIG_AUX_DIR(../..).
Add AC_PROG_RANLIB.
* configure.ac: Use AC_CONFIG_AUX_DIR(..).
* configure.ac: Use AC_CONFIG_AUX_DIR(../../../..).
Add AC_PROG_RANLIB.
* wrapup/Makefile.am: Don't preinstall libmisc.a.
* wrapup/Makefile.am: Don't preinstall libnetworking.a.
* wrapup/Makefile.am: Don't preinstall libfs.a.
* src/Makefile.am: Don't preinstall libblock.a.
* configure.ac: Remove references to RTEMS_BSP.
* src/Makefile.am: Add libposix.a.
* src/Makefile.am: Add libitron.a.
* aclocal/check-multiprocessing.m4: Remove references to RTEMS_BSP.
Allow building w/ --enable-multiprocessing --enable-multilib.
Eliminate RTEMS_HAS_MULTIPROCESSING.
Remove RTEMS_CANONICAL_HOST.
Use RTEMS_ENV_RTEMSCPU.
Add AC_PROG_RANLIB.
* include/rpc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* include/rpcsvc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
ACLOCAL_AMFLAGS = -I ../aclocal.
* src/rpc/PSD.doc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* src/rpc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* src/xdr/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* wrapup/Makefile.am: Fix stupid typo in previous patch.
* configure.ac: Add librpc. AC_PROG_RANLIB.
* wrapup/Makefile.am: Add librpc.
Use relative path to lib*.a for
POSIX_OBJS, ITRON_OBJS, NETWORKING_OBJS.
* aclocal/subdirs.m4: Remove.
* Makefile.am: Remove commented out net-apps.
* wrapup/Makefile.am: Use relative path to lib*.a for
LIBCSUPPORT_OBJS, LIBBLOCK_OBJS, LIBDOSFS_OBJS, LIBIMFS_OBJS.
* Makefile.am: Merge src/Makefile.am.
* src/Makefile.am: Remove.
* Makefile.am: Include $(top_srcdir)/automake/*.am.
Use aclocal.
* sapi/include/Makefile.am: Include $(top_srcdir)/automake/*.am.
* sapi/Makefile.am: Include $(top_srcdir)/automake/*.am.
* sapi/inline/Makefile.am: Include $(top_srcdir)/automake/*.am.
* sapi/macros/Makefile.am: Include $(top_srcdir)/automake/*.am.
* sapi/src/Makefile.am: Include $(top_srcdir)/automake/*.am.
* score/include/Makefile.am: Include $(top_srcdir)/automake/*.am.
* score/Makefile.am: Include $(top_srcdir)/automake/*.am.
* score/cpu/Makefile.am: Include $(top_srcdir)/automake/*.am.
* score/inline/Makefile.am: Include $(top_srcdir)/automake/*.am.
* score/macros/Makefile.am: Include $(top_srcdir)/automake/*.am.
* score/src/Makefile.am: Include $(top_srcdir)/automake/*.am.
* wrapup/Makefile.am: Include $(top_srcdir)/automake/*.am.
* include/Makefile.am: Include $(top_srcdir)/automake/*.am.
* rtems/include/Makefile.am: Include $(top_srcdir)/automake/*.am.
* rtems/Makefile.am: Include $(top_srcdir)/automake/*.am.
* rtems/inline/Makefile.am: Include $(top_srcdir)/automake/*.am.
* rtems/macros/Makefile.am: Include $(top_srcdir)/automake/*.am.
* rtems/src/Makefile.am: Include $(top_srcdir)/automake/*.am.
* Include $(top_srcdir)/automake/*.am. Use aclocal/.
* Makefile.am: Include $(top_srcdir)/../../../automake/*.am.
Use ../../../aclocal.
Use ../aclocal.
* arpa/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* kern/Makefile.am: Include $(top_srcdir)/../automake/*.am.
Use ../aclocal.
* lib/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* libc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* machine/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* net/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* netinet/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* nfs/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* rtems/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* sys/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* vm/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* wrapup/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* src/dosfs/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* src/imfs/Makefile.am: Include $(top_srcdir)/../automake/*.am.
Use ../aclocal.
Use ../aclocal.
Use ../aclocal.
* inline/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* macros/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* aclocal/bsp-alias.m4: Copied over from aclocal/.
* aclocal/canonical-host.m4: Ditto.
* aclocal/canonical-target-name.m4: Ditto.
* aclocal/canonicalize-tools.m4: Ditto.
* aclocal/check-bsp-cache.m4: Ditto.
* aclocal/check-bsps.m4: Ditto.
* aclocal/check-cpu.m4: Ditto.
* aclocal/check-itron.m4: Ditto.
* aclocal/check-multiprocessing.m4: Ditto.
* aclocal/check-networking.m4: Ditto.
* aclocal/check-newlib.m4: Ditto.
* aclocal/check-posix.m4: Ditto.
* aclocal/check-tool.m4: Ditto.
* aclocal/enable-bare.m4: Ditto.
* aclocal/enable-inlines.m4: Ditto.
* aclocal/enable-itron.m4: Ditto.
* aclocal/enable-multiprocessing.m4: Ditto.
* aclocal/enable-networking.m4: Ditto.
* aclocal/enable-posix.m4: Ditto.
* aclocal/enable-rtemsbsp.m4: Ditto.
* aclocal/env-rtemsbsp.m4: Ditto.
* aclocal/env-rtemscpu.m4: Ditto.
* aclocal/gcc-pipe.m4: Ditto.
* aclocal/gcc-specs.m4: Ditto.
* aclocal/multi.m4: Ditto.
* aclocal/multilib.m4: Ditto.
* aclocal/prog-cc.m4: Ditto.
* aclocal/project-root.m4: Ditto.
* aclocal/rtems-cpu-subdirs.m4: Ditto.
* aclocal/rtems-debug.m4: Ditto.
* aclocal/rtems-top.m4: Ditto.
* aclocal/subdirs.m4: Ditto.
* aclocal/sysv-ipc.m4: Ditto.
* aclocal/tool-paths.m4: Ditto.
* aclocal/version.m4: Ditto.
* copied over from aclocal/.
* rtems/Makefile.am: include multilib.am instead of RTEMS_BSP.cfg.
* automake/compile.am: Copied over from automake/.
* automake/lib.am: Copied over from automake/.
* automake/local.am: Copied over from automake/.
* automake/multilib.am: Copied over from automake/.
* automake/subdirs.am: Copied over from automake/.
* Makefile.am: Add automake/*.am.
* configure.ac: Remove RTEMS_CHECK_POSIX_API.
Remove RTEMS_ENABLE_POSIX.
Remove RTEMS_CHECK_CUSTOM_BSP.
* configure.ac: Add libnetworking.
* wrapup/Makefile.am: Ditto.
Relocate c/src/libnetworking.
* Makefile.am: Reflect moval.
* machine/Makefile.am: Ditto.
* net/Makefile.am: Ditto.
* lib/Makefile.am: Ditto.
* netinet/Makefile.am: Ditto.
* vm/Makefile.am: Ditto.
* libc/Makefile.am: Ditto.
* sys/Makefile.am: Ditto.
* arpa/Makefile.am: Ditto.
* nfs/Makefile.am: Ditto.
* kern/Makefile.am: Ditto.
* rtems/Makefile.am: Ditto.
* configure.ac: Dittp.
* wrapup/Makefile.am: Ditto. Remove references to networking apps.
* rtems/score/m68k.h: Per PR227, mc68060 does not require FPSP
since it is now multilib'ed.
