* aclocal/version.m4: Updated to rtems-4.6.99.2.
PR 820/rtems
* score/inline/rtems/score/coremsg.inl,
score/macros/rtems/score/coremsg.inl, score/src/coremsginsert.c:
Increment of pending message count should be atomic with insertion on
the pending message chain. Determination of the need to call the
notification handler should also be in this atomic section of code.
PR 796/rtems
* posix/src/semtimedwait.c: sem_timedwait is supposed to use absolute
time for timeout specification. This patch is a modified version of
the one suggested by Peter Dufault.
PR 804
* sapi/include/confdefs.h: Memory for POSIX timers not accounted for.
Patch adapted from edit comment in PR filed.
PR 819/filesystem
* libcsupport/src/ttyname_r.c: Remove.
* libcsupport/src/ttyname.c: Partial update from FreeBSD.
* libcsupport/Makefile.am: Reflect changes above.
PR 807/rtems
* rtems/src/timerfireafter.c, rtems/src/timerserverfireafter.c: First
patch returned without exitting dispatching critical section.
PR 805/rtems
* posix/include/rtems/posix/timer.h: Due to bad choice of error
constants by original submitter, it was impossible to create more
than 10 POSIX timers.
PR 807/rtems
* rtems/src/timerfireafter.c, rtems/src/timerserverfireafter.c,
score/src/watchdoginsert.c: Tighten critical section checks on an ISR
using the same timer being inserted by a lower priority ISR or
interupt task.
PR 744/filesystem
* libcsupport/src/unlink.c, libfs/src/dosfs/msdos_eval.c: DOSFS did not
support permissions on directories so the check performed by unlink
would always fail. The unlink code was modified to support a not
supported status being returned.
* posix/include/mqueue.h, posix/src/mqueuetimedreceive.c:
ssize_t mq_timedreceive() (POSIX compliance).
* wrapup/Makefile.am: Use librtemscpu_a_LIBRARIES.
PR 808/rtems_misc
* libcsupport/src/printk.c: Fix bug where specifying field width
crashed on pc386 BSP.
* libnetworking/nfs/bootp_subr.c: Don't include
nfs/nfs.h, nfs/krpc.h.
* libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_create.c,
libfs/src/dosfs/msdos_eval.c, libfs/src/dosfs/msdos_file.c,
libfs/src/dosfs/msdos_free.c, libfs/src/dosfs/msdos_fsunmount.c,
libfs/src/dosfs/msdos_init.c, libfs/src/dosfs/msdos_misc.c,
libfs/src/dosfs/msdos_mknod.c:
Introduce msdos_status_t (dosfs statii are at least 32bit, not int).
* Makefile.am: Add libnetworking/memory.h
* libnetworking/Makefile.am: Remove memory.h
PR 817/rtems
* libcsupport/src/gxx_wrappers.c: Rename
rtems_gxx_recursive_mutex_init_function to
rtems_gxx_recursive_mutex_init.
* libnetworking/sys/syslog.h: Partial update from FreeBSD.
which included commits to RCS files with non-trunk default branches.
* libnetworking/lib/syslog.c: Fix spelling mistake.
* libnetworking/sys/uio.h: Partial update from FreeBSD.
* libnetworking/kern/kern_subr.c: Reflect changes above.
* libblock/include/rtems/ide_part_table.h: Add C++ guards.
* libnetworking/net/if.h: Avoid use of struct mbuf to avoid unintended
dependencies added by the RTEMS specific tap interface.
PR 790/rtems
* sapi/src/extensioncreate.c, sapi/src/extensionident.c: Correct use of
name. This was missed when the other ident services in rtems/src
where changed.
PR 803/patch
* rtems/score/cpu.h, rtems/score/m68k.h: Correct definition of _VBR.
* libnetworking/net/if.h: Partial update from FreeBSD.
* libnetworking/netinet/if_ether.h: Remove BYTE_PACK.
* libnetworking/netinet/ip_var.h: Remove BYTE_PACK.
* librpc/include/rpc/clnt.h: Partial update from FreeBSD.
* libnetworking/lib/ftpfs.c, librpc/include/rpc/svc.h,
librpc/src/rpc/get_myaddress.c, librpc/src/rpc/pmap_getmaps.c,
librpc/src/rpc/pmap_getport.c: Remove warnings.
* librpc/include/rpc/clnt.h, librpc/include/rpc/svc.h,
src/rpc/pmap_rmt.c: Use void* instead of caddr_t.
Cosmetics from FreeBSD.
* librpc/include/rpc/auth_des.h: Remove (Unused, unsupported).
* librpc/include/rpc/rpc.h, librpc/Makefile.am: Reflect removing
auth_des.h.
