_ISR_Enable() takes the magic cookie expected by the cpu's status register
instead of a simple isr level.
Broke the setjmp/longjmp pair in the context switch into a separate routine
so no code depended on local variables surviving the jump.
which are tasks.
of the POSIX API necessary to support the GNAT runtime to initially compile.
We now have verified that the specifications for the necessary routines
are correct per the POSIX standards we have.
The removed files were moved to newlib as they were duplicates of files
already included there.
which included commits to RCS files with non-trunk default branches.
routine.
wkspace.c: made initialization routine a regular subroutine
wkspace.h: made initialization routine a regular subroutine
updates from Tony Bennett. Most were to insure all variables were properly
initialized and to correct the stray signal number reporting.
added CPU_M68K_EXTB_L model flag
sem.c: modified to eliminate Purify warnings
support.h: updated to use RTEMS_APPLICATION macro
from the application code, this file required more visibility than
is given by default to application code.
only required in a multiprocessor system. It was replace by the MPCI
Receive Server. As a result, the CPU Table field for extra stack for
the SYSI task was changed to be extra stack for the MPCI Receive Server.
the thread handler (IDLE), MPCI object (SYSI now MP Receive)
and initialize_executive_early (IO initialization). The SYSI task
no longer exists in a single processor configuration. This reduces
single processor Workspace requirements by a TCB and a stack which
is often larger than the minimum stack size. Moving the IO initialization
plus accompanying BSP hooks eliminated an initialization ordering problem
in which a global task could be created before the MPCI was initialized.
part of the Thread Handler. This required the name of the optional
CPU dependent IDLE thread implementation to change.
Also system initialization thread only created in MP systems.
initialize_executive_early. This was done to clear up an ordering problem
in which global tasks could be created before the MPCI layer was initialized.
in each thread which must be set when the post switch extension is to be run.
