* posix/src/psignal.c: Do not allocate any memory for queued signals if
the configuration parameter is 0. Before we would end up with an
allocation of 0 which rounded up and wasted some memory when POSIX
was configured.
* libcsupport/src/newlibc_exit.c: Only run the fini section on exit if
the target toolset uses init/fini sections.
* itron/include/rtems/itron/task.h, itron/src/task.c: ITRON currently
has no functional data in the user extension data area structure so
this disables the definition, allocation and deallocation of that
structure. If we ever have to add data to it, then it will be easy to
reenable.
* rtems/score/cpu.h: Add CPU_SIMPLE_VECTORED_INTERRUPTS porting
parameter to indicate that the port uses the Simple Vectored
Interrupt model or the Programmable Interrupt Controller Model. The
PIC model is implemented primarily in the BSP and it is responsible
for all memory allocation.
* score/src/objectgetinfo.c, score/src/objectidtoname.c,
score/src/threadget.c: Make sure the pointer to the API object table
is valid before derefencing it.
* rtems/score/cpu.h: Use a constant for CPU_STACK_MINIMUM_SIZE so it
can be used in cpp expressions. Using sizeof() requires actually
compiling the file.
* score/include/rtems/score/interr.h, score/src/interr.c: Convention
calls for leading underscore on private RTEMS variables.
* score/include/rtems/score/object.h,
score/include/rtems/score/watchdog.h: Move #include's out of
extern "C" {}.
* libfs/src/nfsclient/src/nfs.c:BUGFIX: must not attempt to
release node if rtems_filesystem_evaluate_path() fails
in nfs_eval_link() since pathloc contains no valid node.
* libmisc/shell/shell_getchar.c: Minor change so dropping connection
while at prompt results in shell logging out and connection still
being available.
* libcsupport/src/newlibc_exit.c, score/src/threadhandler.c: Call
fini() as part of exit(). This avoids atexit() being a required
function.
* libmisc/shell/shell.c: Minor change so dropping connection during
login prompt results in connection still being available.
reduce size of data area.
IMFS: Fixed creation of symbolic links to avoid a compiler warning.
DOSFS: Use LibBlock instead of read() to read the boot record.
and RTEMS_ID_NONE. No object can have this ID.
* libnetworking/netinet/ip_output.c: when fragmenting
multicast packets M_MCAST must be set on all fragments.
This was fixed in FreeBSD ip_output.c 1.82 on 1998/8/23 !
(see my email to rtems-users from 2008/5/15).
* itron/include/rtems/itron/task.h, itron/src/del_tsk.c,
itron/src/exd_tsk.c, itron/src/task.c,
posix/include/rtems/posix/threadsup.h, posix/src/cancel.c,
posix/src/cancelrun.c, posix/src/pthread.c, posix/src/pthreadexit.c,
posix/src/setcancelstate.c, posix/src/setcanceltype.c,
posix/src/testcancel.c, rtems/src/taskdelete.c,
score/inline/rtems/score/object.inl, score/src/objectclose.c,
score/src/threadclose.c: Make all task delete/exit/cancel routines
follow the same critical section pattern. Also ensure that POSIX
cancelation routines are run at thread exit.
* libcsupport/src/termios_baud2index.c,
libcsupport/src/termios_baud2num.c,
libcsupport/src/termios_num2baud.c,
libcsupport/src/termios_setinitialbaud.c: New files.
* libcsupport/Makefile.am, libcsupport/preinstall.am,
libcsupport/include/rtems/termiostypes.h: Move termios helper
routines from libchip to libcsupport. Add routine which makes it easy
for a termios device driver to inform termios of its default baud
rate. This avoids inconsistencies in later termios settings changes.
* libcsupport/include/rtems/watchdogdrv.h: Finish writing comments.
* libcsupport/preinstall.am, sapi/include/confdefs.h: Add baseline
interface for Watchdog Driver.
* libcsupport/include/rtems/watchdogdrv.h: New file.
* score/src/threadchangepriority.c: Just in case the transient
state was set when we entered, ensure that it is still set when
we exit.
* score/src/threadclose.c: When a thread is being deleted, it should
go into the dormant state -- not the transient state.
* libi2c/libi2c.h: Fix typo.
* pppd/example/system.h: Fix path in example -- NOT COMPILED WITH
CPUKIT.
* sapi/include/rtems/init.h, sapi/src/exinit.c: Refactored and renamed
initialization routines to rtems_initialize_data_structures,
rtems_initialize_before_drivers, rtems_initialize_device_drivers, and
rtems_initialize_start_multitasking. This opened the sequence up so
that bootcard() could provide a more robust and flexible framework
which is easier to explain and understand. This also lays the
groundwork for sharing the division of available memory between the
RTEMS workspace and heap and the C library initialization across all
BSPs.
* sapi/src/exinit.c, score/src/threadstartmultitasking.c: Improve
comments.
* score/src/objectget.c: Improve comments and readability.
* rtems/include/rtems/rtems/message.h, sapi/include/confdefs.h,
score/src/coresemseize.c, score/src/threadhandler.c: Comment
improvements from class.
PR 1285/rtems
* sapi/include/rtems/config.h: Remove obsolete
rtems_configuration_get_maximum_devices().
* libblock/include/rtems/nvdisk-sram.h,
libblock/include/rtems/nvdisk.h,
libblock/src/nvdisk-sram.c,
libblock/src/nvdisk.c: New. A Non-volatile memory disk drive.
* Makefile.am, preinstall.am, libblock/Makefile.am: Updated for
the NV disk driver.
* libnetworking/rtems/rtems_dhcp.c: Removed panic()s. Added
interface for rtems_dhcp_failsafe.
* libnetworking/rtems/rtems_dhcp.h: Added interface for
2008-05-01 Arnout Vandecappelle <arnout@mind.be>
* libnetworking/nfs/bootp_subr: Allow some errors for sosend() and
return on timeout in bootpc_call(). Removed panic()s.
* libnetworking/rtems/rtems_glue.c: Fix the cast for the
SIOCAIFADDR ioctl call.
* libnetworking/rtems/rtems_dhcp_failsafe.c,
libnetworking/rtems/rtems_dhcp_failsafe.h: New.
* libnetworking/Makefile.am, libnetworking/preinstall.am: Added
rtems_dhcp_failsafe.c and rtems_dhcp_failsafe.h files.
* rtems/include/rtems/rtems/timer.h: Fix typo.
* rtems/include/rtems.h, rtems/include/rtems/rtems/ratemon.h,
rtems/include/rtems/rtems/status.h,
rtems/include/rtems/rtems/tasks.h, rtems/include/rtems/rtems/timer.h,
rtems/inline/rtems/rtems/sem.inl: More Doxygen warnings removed.
* posix/src/keycreate.c, posix/src/pthreadequal.c,
rtems/src/semtranslatereturncode.c,
score/cpu/powerpc/rtems/score/powerpc.h,
score/src/threadblockingoperationcancel.c: Fix compilation errors
when --enable-rtems-debug is used.
* score/include/rtems/system.h: Fix typo in comment.
* rtems/include/rtems/rtems/partmp.h, sapi/include/confdefs.h: Fix
typos added with recent changes.
* libcsupport/Makefile.am, libcsupport/include/rtems/libio.h: Remove
rtems_termios_reserve_resources. It is obsolete.
* libcsupport/src/termiosreserveresources.c: Removed.
* rtems/mainpage.h: New file.
