* | cpukit/libmisc/shell/hexdump-conv.c: Eliminate printf() format warning | Joel Sherrill | 2015-03-22 | 1 | -1/+5 |
* | cpukit/libmisc/shell/main_df.c: Eliminate printf() format warning | Joel Sherrill | 2015-03-22 | 1 | -2/+3 |
* | score: Simplify debug code and use _Assert() | Sebastian Huber | 2015-03-22 | 3 | -59/+12 |
* | score: Move _Thread_queue_Requeue() | Sebastian Huber | 2015-03-22 | 3 | -68/+43 |
| | | | | Now all the main thread queue operations are in one module. | ||||
* | score: Move _Thread_queue_Extract() | Sebastian Huber | 2015-03-22 | 5 | -174/+118 |
| | | | | | | | | Move _Thread_queue_Dequeue(). We need all or no thread queue functions so it makes no sense to have them in separate modules. One module enables compiler optimizations without link-time optimization. Make _Thread_blocking_operation_Finalize() static since it is use now only in one module. | ||||
* | score: Move _Thread_blocking_operation_Cancel() | Sebastian Huber | 2015-03-22 | 4 | -124/+90 |
| | | | | | | | Move _Thread_blocking_operation_Cancel() and make static since it is only used by _Thread_queue_Enqueue_with_handler(). Move _Thread_blocking_operation_Finalize(). | ||||
* | Replace www.rtems.com with www.rtems.org | Sebastian Huber | 2015-03-20 | 40 | -40/+40 |
* | score: Delete unused _Timestamp_(To|From)_ticks() | Alexander Krutwig | 2015-03-20 | 4 | -103/+1 |
* | score: Delete unused _Timestamp_Divide_by_integer | Alexander Krutwig | 2015-03-20 | 4 | -85/+1 |
* | score: Fix _Thread_Change_priority() | Sebastian Huber | 2015-03-20 | 3 | -14/+31 |
| | | | | | | | | | | Atomically update the current priority of a thread and the wait queue. Serialize the scheduler update in a separate critical section with a generation number. New test sptests/spintrcritical23. Close #2310. | ||||
* | score: Delete unused _Timestamp_Is_valid() | Alexander Krutwig | 2015-03-19 | 2 | -31/+0 |
* | score: Fix _Debug_Is_owner_of_allocator() | Sebastian Huber | 2015-03-19 | 1 | -2/+11 |
* | libmisc/capture: Clean up formatting on ARM. | Chris Johns | 2015-03-19 | 2 | -22/+29 |
| | | | | | | | | The printing of 64bit diff's for the timestamp did not work on ARM so I have changed this to 32bit. A 32bit nano-second diff between events should be more than enough time. Print '____' for POSIX thread output. | ||||
* | testsupport: Do not suspend worker tasks | Sebastian Huber | 2015-03-18 | 1 | -1/+3 |
* | libmisc/redirector: Fix unlock on exit from the handler. | Chris Johns | 2015-03-18 | 1 | -1/+1 |
* | IMFS: NUL-terminate name returned by readdir() | Sebastian Huber | 2015-03-17 | 1 | -2/+5 |
* | cpukit/include/rtems/btimer.h: Improve brief | Joel Sherrill | 2015-03-17 | 1 | -1/+1 |
* | Disable deprecated warning on implementation of deprecated methods | Joel Sherrill | 2015-03-17 | 8 | -4/+46 |
* | libmisc/monitor/mon-task.c: Disable deprecated warning for use of notepads | Joel Sherrill | 2015-03-17 | 1 | -2/+21 |
* | cpukit/libdl/rtl-obj-comp.c: Use correct printf() specification | Joel Sherrill | 2015-03-17 | 2 | -3/+3 |
* | testsupport: Add worker setup handler | Sebastian Huber | 2015-03-17 | 2 | -12/+71 |
| | | | | Add rtems_test_parallel_get_task_id(). | ||||
* | score: Ensure properties of CPU_Uint32ptr | Sebastian Huber | 2015-03-17 | 1 | -0/+10 |
* | cpukit: add and use CPU_Uint32ptr type | Gedare Bloom | 2015-03-16 | 21 | -2/+61 |
* | IMFS: don't strlen() an unterminated string in IMFS_dir_read(). | Jamie Iles | 2015-03-16 | 1 | -1/+1 |
| | | | | | | | | | a43a3466 (IMFS: Implement variable length node names) introduced a changed to IMFS_jnode_t from being a null terminated string to a separate unterminated string and length. IMFS_dir_read() was still performing a strlen() on this unterminated string though and when doing an 'ls' in the fileio example I saw that some filenames had garbage suffixes. | ||||
* | shell: remove rtems ifdef, upstream is correct | Gedare Bloom | 2015-03-16 | 1 | -8/+0 |
* | shell: fix printf warnings | Gedare Bloom | 2015-03-16 | 1 | -4/+5 |
* | capture: fix warnings in print | Gedare Bloom | 2015-03-16 | 1 | -4/+6 |
* | rtems: make error codes uintptr_t | Gedare Bloom | 2015-03-16 | 1 | -1/+1 |
* | rfs: cast minor to uintptr_t to truncate explicitly | Gedare Bloom | 2015-03-16 | 1 | -2/+2 |
* | score: Add _Objects_ISR_disable_and_acquire() | Sebastian Huber | 2015-03-15 | 1 | -7/+22 |
* | score/or1k: Fix warnings. Add missing prototypes | Hesham ALMatary | 2015-03-13 | 1 | -0/+4 |
| | | | | Closes #2304 | ||||
* | posix/src/nanosleep.c: Address issue when delay is longer than desired | Joel Sherrill | 2015-03-12 | 1 | -16/+27 |
| | | | | | | | This resulted in the elapsed time going below 0 and an arbitrarily large number returned as the time remaining. closes #2296. | ||||
* | posix: Return error code if mmap is used | Daniel Cederman | 2015-03-12 | 1 | -1/+1 |
* | posix: Move function to file with matching name | Daniel Cederman | 2015-03-12 | 2 | -10/+10 |
| | | | | mmap was previously in munmap.c and munmap was in mmap.c. | ||||
* | confdefs.h: Improve the Doxygen | Joel Sherrill | 2015-03-11 | 1 | -121/+780 |
* | cpukit/include/rtems/btimer.h: Add DOxygen comments | Joel Sherrill | 2015-03-11 | 1 | -2/+56 |
* | cpukit/include/rtems/bspIo.h: Add Doxygen comments | Joel Sherrill | 2015-03-11 | 1 | -29/+107 |
* | cpukit: Remove old DESCRIPTION: in comments | Joel Sherrill | 2015-03-11 | 12 | -131/+24 |
| | | | | These were remnants of pre-Doxygen comment style. | ||||
* | cpukit: deprecate task variables. closes #2293. | Gedare Bloom | 2015-03-10 | 3 | -4/+15 |
* | cpukit: deprecate rtems_clock_get(). closes #2294. | Gedare Bloom | 2015-03-10 | 1 | -1/+4 |
* | cpukit: deprecate notepads | Gedare Bloom | 2015-03-10 | 3 | -7/+18 |
| | | | | | | | | | | | | | | | Deprecate Classic API Notepads. Mark task_set/get_note() with the deprecated attribute, and also mark the notepads field. Replace disable with enable option for notepads in confdefs.h, and make notepads disabled by default. The previous option CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS is now unused and will emit a compile-time warning. A new option CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS is available to turn on notepads, but it also will emit a compile-time warning to indicate that notepads are deprecated. Closes #2265 | ||||
* | cpukit/libcrypt/misc.c: Reverse order of statements in ifdef | Joel Sherrill | 2015-03-10 | 1 | -2/+2 |
* | posix: Install <semaphore.h> only if not provided | Sebastian Huber | 2015-03-10 | 3 | -1/+7 |
* | libcsupport: Delete superfluous _gettimeofday() | Sebastian Huber | 2015-03-10 | 1 | -16/+0 |
* | posix: Change sem_t to the 32-bit object type | Sebastian Huber | 2015-03-10 | 2 | -2/+2 |
| | | | | | This change is also valid for 16-bit object type architectures since in this case POSIX_Semaphore_Control::Semaphore_id is used as a proxy. | ||||
* | posix: Use a value of 0 for SEM_FAILED | Sebastian Huber | 2015-03-10 | 1 | -1/+1 |
| | | | | This is the standard NULL pointer. | ||||
* | score: Add rtems_set_errno_and_return_value() | Sebastian Huber | 2015-03-10 | 3 | -17/+16 |
| | | | | Remove rtems_set_errno_and_return_minus_one_cast(). | ||||
* | cpukit/libmisc/fsmount/fsmount.h: Remove duplicate comments and copyright | Joel Sherrill | 2015-03-09 | 1 | -29/+7 |
* | cpukit/dev/include/dev/i2c/i2c.h: Fix Doxygen grouping | Joel Sherrill | 2015-03-09 | 1 | -0/+2 |
* | Move contents of libcsupport/include/zilog into libbsp/shared | Joel Sherrill | 2015-03-09 | 4 | -223/+0 |
| | | | | Only a few BSPs use this and it should not have been in libcsupport. |
