* | Modified references to task name. | Joel Sherrill | 1995-08-18 | 1 | -2/+3 | |
* | + Added object type field to object id. | Joel Sherrill | 1995-08-18 | 12 | -15/+36 | |
| | | | | | | | | | | + Added name pointer to Object_Control. + Modified Object Open and Close to address name field. + Removed name as separate element from Thread and Proxy Control. + Added parameter "object class" to calls to Initialize Information | |||||
* | + Added object type field to object id. | Joel Sherrill | 1995-08-18 | 4 | -21/+102 | |
| | | | | | | | | + Added name pointer to Object_Control. + Modified Object Open and Close to address name field. + Removed name as separate element from Thread and Proxy Control. | |||||
* | Numerous miscellaneous features incorporated from Tony Bennett | Joel Sherrill | 1995-08-17 | 38 | -543/+4640 | |
| | | | | | | | | | (tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables | |||||
* | variable length messages | Joel Sherrill | 1995-08-17 | 2 | -119/+269 | |
* | Id reinserted | Joel Sherrill | 1995-08-17 | 1 | -1/+1 | |
* | no limit removed | Joel Sherrill | 1995-08-17 | 1 | -4/+3 | |
* | bug fixes to make macro implementations work | Joel Sherrill | 1995-08-16 | 18 | -87/+36 | |
* | Added functions to access the errno of the native system when using the | Joel Sherrill | 1995-08-11 | 2 | -1/+50 | |
| | | | | | | | newlib C library. Fixed bug where length did not take into account amount added for alignment requirements. | |||||
* | Added functions to access the errno of the native system when using the | Joel Sherrill | 1995-08-11 | 1 | -7/+2 | |
| | | | | newlib C library. | |||||
* | added constant for number of notepads | Joel Sherrill | 1995-08-11 | 1 | -8/+10 | |
* | cleanup and optimization from Tony | Joel Sherrill | 1995-08-04 | 1 | -12/+18 | |
* | split out event support functions in anticipation of making a handler | Joel Sherrill | 1995-08-04 | 1 | -191/+0 | |
* | *** empty log message *** | Joel Sherrill | 1995-08-02 | 1 | -1/+0 | |
* | deleted unused code | Joel Sherrill | 1995-08-01 | 1 | -38/+0 | |
* | moved ringbuf.h to a shared include directory | Joel Sherrill | 1995-08-01 | 1 | -0/+42 | |
* | Switched to events for mp receive server and eliminated the special | Joel Sherrill | 1995-07-31 | 5 | -110/+52 | |
| | | | | blocking mechanism for it. | |||||
* | after testing go32 and cvme961 | Joel Sherrill | 1995-07-21 | 1 | -1/+8 | |
* | fixed for Linux | Joel Sherrill | 1995-07-18 | 1 | -13/+24 | |
* | merged Linux UNIX simulator support (C) | Joel Sherrill | 1995-07-18 | 2 | -2/+23 | |
* | Ada95, gnat, go32 | Joel Sherrill | 1995-07-12 | 10 | -361/+553 | |
* | added David Glessner's 68302 work. | Joel Sherrill | 1995-06-14 | 1 | -5/+5 | |
* | corrected pseudo-code for _ISR_Handler | Joel Sherrill | 1995-06-07 | 1 | -5/+17 | |
* | incorporated mc68302 support | Joel Sherrill | 1995-06-07 | 4 | -1/+1240 | |
* | incorporate Tony's patches: | Joel Sherrill | 1995-06-05 | 1 | -0/+1 | |
| | | | | | | | | | | + c/src/lib/libc/support/generic/malloc.c did not initialize the sbrk amount + _Thread_Handler in c/src/exec/rtems/thread.c left a window during the begin extension which could result in a context switch fixed places which did not correctly distinguish between an CPU_isr and a CPU_isr_entry. | |||||
* | changed release number to 3.2.0 | Joel Sherrill | 1995-06-04 | 2 | -11/+12 | |
* | TEST | Joel Sherrill | 1995-05-25 | 1 | -0/+2 | |
* | Fully tested on all in-house targets | Joel Sherrill | 1995-05-24 | 22 | -204/+165 | |
* | Initial revision | Joel Sherrill | 1995-05-11 | 203 | -0/+34929 | |
