* | bfin libcpu and libbsp: Fix warnings | Joel Sherrill | 2014-10-16 | 1 | -0/+1 |
* | libmisc/redirector/stdio-redirect.c: Use UL constants since usleep() should ↵ | Joel Sherrill | 2014-10-16 | 1 | -1/+1 |
| | | | | take more than 16-bit constants | ||||
* | jffs2/src/fs-rtems.c: Add include of <rtems/libio.h> for prototypes | Joel Sherrill | 2014-10-16 | 1 | -0/+1 |
* | jffs2/src/fs-rtems.c: Eliminate set but not used warnings | Joel Sherrill | 2014-10-16 | 1 | -0/+3 |
* | shell: Print null mount table entry via LSOF | Sebastian Huber | 2014-10-16 | 1 | -16/+32 |
* | shell: Improve LSOF output | Sebastian Huber | 2014-10-16 | 1 | -12/+19 |
* | score: Fix compile error for POSIX disabled | Sebastian Huber | 2014-10-16 | 1 | -2/+1 |
* | rfs: explicitly cast to dev_t | Gedare Bloom | 2014-10-16 | 1 | -1/+1 |
* | h8300/cpu_asm.S: Correct register size suffix for loading DISPATCH_NEEDED | Joel Sherrill | 2014-10-15 | 1 | -1/+1 |
* | rtems/score/object.h: Include <rtems/score/cpu.h> to honor 16-bit Ids | Joel Sherrill | 2014-10-15 | 1 | -0/+1 |
| | | | | | | | Selection of 16-bit object Ids is a port specific decision. Somewhere along the way, the file providing this information was dropped from the include file set. This resulted in the code being compiled with a mix of 16 and 32 bit ID assumptions for those targets with 16-bit Ids. | ||||
* | sparc64: fix warnings in cpukit/score/cpu | Gedare Bloom | 2014-10-13 | 2 | -4/+2 |
* | score/cpu/m32c: Fix warnings | Joel Sherrill | 2014-10-13 | 2 | -4/+5 |
* | libcsupport/include/clockdrv.h: Remove rtems_clock_major/minor | Joel Sherrill | 2014-10-13 | 1 | -2/+0 |
* | libmisc/redirector/stdio-redirect.c: Use sleep not usleep and do not ↵ | Joel Sherrill | 2014-10-13 | 1 | -1/+1 |
| | | | | overflow 16-bit int | ||||
* | shell/main_cp.c: Delete unused -rtems_shell_cp_exit() | Joel Sherrill | 2014-10-13 | 1 | -6/+0 |
* | score: Rework global construction | Sebastian Huber | 2014-10-13 | 6 | -85/+134 |
| | | | | | | Ensure that the global construction is performed in the context of the first initialization thread. On SMP this was not guaranteed in the previous implementation. | ||||
* | cpukit/include/rtems/irq.h: Fix spacing | Joel Sherrill | 2014-10-10 | 1 | -1/+1 |
* | arm: Fix warning | Sebastian Huber | 2014-10-10 | 1 | -0/+6 |
* | shell/lsof: Fix warnings | Sebastian Huber | 2014-10-10 | 1 | -8/+9 |
* | m32r/cpu_asm.c: Add prototype to fix warning | Joel Sherrill | 2014-10-09 | 1 | -0/+5 |
* | m32r/rtems/score/cpu.h: Fix macros to avoid warnings | Joel Sherrill | 2014-10-09 | 1 | -18/+20 |
* | h8300/rtems/score/cpu.h: Fix macros to avoid warnings | Joel Sherrill | 2014-10-09 | 1 | -6/+17 |
* | avr/rtems/score/cpu.h: Fix macros to avoid warnings | Joel Sherrill | 2014-10-09 | 1 | -6/+5 |
* | cpukit/score/src/ts64*: Return a value from non-void function | Joel Sherrill | 2014-10-09 | 4 | -4/+4 |
* | m68k/rtems/score/cpu.h: _CPU_Context_Restart_self needed ↵ | Joel Sherrill | 2014-10-09 | 1 | -1/+1 |
| | | | | RTEMS_COMPILER_NO_RETURN_ATTRIBUTE | ||||
* | moxiertems/score/cpu.h: _CPU_Context_switch needed ↵ | Joel Sherrill | 2014-10-09 | 1 | -9/+22 |
| | | | | RTEMS_COMPILER_NO_RETURN_ATTRIBUTE plus fix warnings on unimplemented ISR enable/disable | ||||
* | arm/rtems/score/cpu.h: _ARMV7M_Start_multitasking needed ↵ | Joel Sherrill | 2014-10-09 | 1 | -1/+2 |
* | nios2-iic-irq.c: Fix warnings | Joel Sherrill | 2014-10-09 | 1 | -0/+6 |
* | nios2-iic-irq.c: Include <rtems/score/interr.h> so it builds | Joel Sherrill | 2014-10-09 | 1 | -0/+1 |
* | ppp: PR1943: Avoid NULL pointer access | Sebastian Huber | 2014-10-08 | 1 | -8/+2 |
| | | | | | | | Waiting for mbufs at this level is a bad solution. It would be better to try to allocate a new mbuf chain before we hand over the current mbuf chain to the upper layer. In case the allocation fails we should drop the current packet and use its mbuf chain for a new packet. | ||||
* | IMFS: Avoid NULL pointer access | Sebastian Huber | 2014-10-08 | 1 | -1/+2 |
| | | | | | Avoid NULL pointer access in IMFS_is_imfs_instance(). File systems mounted via mount() always have a valid type string. | ||||
* | posix: Add auto initializaton for rwlock | Sebastian Huber | 2014-10-08 | 10 | -46/+54 |
* | posix: Fix mutex auto initialization | Sebastian Huber | 2014-10-08 | 1 | -1/+10 |
| | | | | Use the once lock to prevent race conditions during auto initialization. | ||||
* | posix: Use function instead of macros | Sebastian Huber | 2014-10-08 | 1 | -41/+28 |
* | ppp: Add ppp_unit() | Sebastian Huber | 2014-10-08 | 1 | -15/+21 |
| | | | | This makes porting to the new network stack easier. | ||||
* | ppp: Nothing to transmit hint for Termios driver | Sebastian Huber | 2014-10-07 | 1 | -1/+10 |
* | termios: Partially hide rtems_termios_tty | Sebastian Huber | 2014-10-07 | 5 | -106/+195 |
| | | | | | | | Move interrupt lock to device context and expose only this structure to the read, write and set attributes device handler. This makes these device handler independent of the general Termios infrastructure suitable for direct use in printk() support. | ||||
* | termios: Separate flow control from normal handler | Sebastian Huber | 2014-10-07 | 2 | -17/+41 |
* | termios: Fix transmit daemon | Sebastian Huber | 2014-10-07 | 1 | -1/+9 |
| | | | | | | Do not call rtems_termios_refill_transmitter() in case a PPP line discipline is present. This is similar to rtems_termios_dequeue_characters(). | ||||
* | SPARC: Fatal_halt use source and exit codes | Daniel Hellstrom | 2014-10-06 | 1 | -8/+2 |
| | | | | | | | | | | | | | | | The Fatal_halt handler now have two options, either halt as before or enter system error state to return to debugger or simulator. The exit-code is now also propagated to the debugger which is very useful for testing. The CPU_Fatal_halt handler was split up into two, since the only the LEON3 support the CPU power down. The LEON3 halt now uses the power-down instruction to save CPU power. This doesn't stop a potential watch-dog timer from expiring. | ||||
* | libmisc/shell: Remove the need for -lm when linking from the ping command. | Chris Johns | 2014-10-04 | 1 | -5/+12 |
| | | | | | Remove the use of sqrt and so the need to link to -lm. Clean up some warnings. | ||||
* | pppd: Import change from NetBSD | Sebastian Huber | 2014-09-30 | 1 | -1/+1 |
| | | | | | This avoids the use of gethostbyname() in case the "noipdefault" option is given. The gethostbyname() uses DNS by default. | ||||
* | pppd: Fix warnings | Sebastian Huber | 2014-09-30 | 2 | -3/+22 |
* | libnetworking: Update due to Termios changes | Sebastian Huber | 2014-09-30 | 2 | -3/+3 |
* | or1k fix bug: Initialize thread context with higher stack address. | Hesham ALMatary | 2014-09-29 | 1 | -2/+3 |
| | | | | | | Since or1k architecture stack grows down, threads should be initialized with high stack addresses instead of lower ones. This is done in _CPU_Context_Initialize function. | ||||
* | m68k: Use CPU_TIMESTAMP_USE_STRUCT_TIMESPEC | Sebastian Huber | 2014-09-23 | 1 | -1/+1 |
| | | | | | | | Converting 64-bit nanoseconds values into the common struct timeval or struct timespec formats requires a 64-bit division to get the seconds value. Performance analysis of high network loads revealed that this is too costly on PowerPC. | ||||
* | powerpc: Use CPU_TIMESTAMP_USE_STRUCT_TIMESPEC | Sebastian Huber | 2014-09-23 | 1 | -1/+1 |
* | score: Delete Thread_Wait_information::Block2n | Sebastian Huber | 2014-09-23 | 1 | -4/+0 |
| | | | | This field is no longer used. | ||||
* | score: Critical fix for _Thread_queue_Dequeue() | Sebastian Huber | 2014-09-19 | 1 | -6/+8 |
| | | | | | Do not return NULL in case we can dequeue the executing thread. This bug was introduced with 32506647001a815e3c0daf25757d386104a07184. | ||||
* | sparc: Add comment | Sebastian Huber | 2014-09-18 | 1 | -0/+5 |
