* | 2009-02-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-11 | 48 | -443/+149 |
| | | | | | | * cpu.c, rtems/score/cpu.h: Eliminate _CPU_Thread_dispatch_pointer and passing address of _Thread_Dispatch to _CPU_Initialize. Clean up comments. | ||||
* | 2009-02-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-11 | 3 | -15/+7 |
| | | | | | | * rtems/new-exceptions/cpu.h, rtems/score/cpu.h: Eliminate _CPU_Thread_dispatch_pointer and passing address of _Thread_Dispatch to _CPU_Initialize. Clean up comments. | ||||
* | 2009-02-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-11 | 2 | -0/+6 |
| | | | | * rtems/score/cpu.h: Use a 16 bit object id on this target. | ||||
* | 2009-02-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-11 | 2 | -1/+12 |
| | | | | | * rtems/score/cpu.h: Do not unroll any code on this target and use a 16-bit object id. | ||||
* | 2009-02-11 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-02-11 | 2 | -1/+6 |
| | | | | | PR 1374/misc * libmisc/stackchk/check.c: Fix printk formatting string. | ||||
* | 2009-02-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-11 | 2 | -3/+8 |
| | | | | | * sapi/src/exinit.c: Interrupts are guaranteed to be disabled by boot_card(), do not do it here as well. | ||||
* | Partial update from FreeBSD. | Ralf Corsepius | 2009-02-11 | 2 | -9/+11 |
* | 2009-02-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-11 | 1 | -0/+2 |
| | | | | | * libnetworking/sys/kernel.h: Remove PSEUDO_* (Unused, not in FreeBSD). | ||||
* | Remove PSEUDO_* (Unused, not in FreeBSD). | Ralf Corsepius | 2009-02-11 | 1 | -28/+0 |
* | 2009-02-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-11 | 1 | -0/+1 |
| | | | | * libnetworking/sys/kernel.h: Remove struct linker_set (Unused). | ||||
* | Remove struct linker_set (Unused). | Ralf Corsepius | 2009-02-11 | 1 | -6/+0 |
| | | | | * libnetworking/net/if_loop.c: Remove PSEUDO_SET (Unused). | ||||
* | Remove PSEUDO_SET (Unused). | Ralf Corsepius | 2009-02-11 | 1 | -2/+1 |
| | | | | * libnetworking/kern/uipc_domain.c: Remove domain_set (Unused). | ||||
* | Remove domain_set (Unused). | Ralf Corsepius | 2009-02-11 | 1 | -2/+0 |
* | 2009-02-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-11 | 2 | -41/+12 |
| | | | | | | | * libnetworking/sys/kernel.h: Remove execsw_set, si_elem_t (Unused, not in FreeBSD). #include <sys/linker_set.h>. Add #ifdef _KERNEL guards (From FreeBSD). | ||||
* | 2009-02-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-11 | 2 | -5/+5 |
| | | | | | * libnetworking/sys/kernel.h: Remove hostnamelen, domainnamelen, lbolt, tickdelta, timedelta (Unused, not in FreeBSD). | ||||
* | 2009-02-10 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-10 | 1 | -0/+1 |
| | | | | * libnetworking/vm/vm.h: Cosmetics from FreeBSD. | ||||
* | Cosmetics from FreeBSD. | Ralf Corsepius | 2009-02-10 | 1 | -6/+32 |
* | 2009-02-10 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-10 | 1 | -0/+2 |
| | | | | | * libnetworking/rtems/rtems_bsdnet_internal.h: Remove struct vm_page, vm_page_t, boolean_t (Unused). | ||||
* | Remove struct vm_page, vm_page_t, boolean_t (Unused). | Ralf Corsepius | 2009-02-10 | 1 | -5/+0 |
* | 2009-02-10 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-10 | 1 | -0/+8 |
| | | | | | | | | * libnetworking/nfs/bootp_subr.c, libnetworking/nfsclient/nfsdiskless.h: Cosmetics from FreeBSD. * libnetworking/rtems/rtems_bsdnet_internal.h: Remove struct file (Unused). | ||||
* | Cosmetics from FreeBSD. | Ralf Corsepius | 2009-02-10 | 2 | -47/+29 |
* | Remove struct file (Unused). | Ralf Corsepius | 2009-02-10 | 1 | -1/+0 |
* | 2009-02-09 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-09 | 1 | -1/+5 |
| | | | | | * libnetworking/sys/socketvar.h: Remove struct file, soo_ioctl, soo_select, soo_stat, getsock (Unused). | ||||
* | Remove struct file, soo_ioctl, soo_select, soo_stat, getsock (Unused). | Ralf Corsepius | 2009-02-09 | 1 | -10/+0 |
* | Regenerate. | Ralf Corsepius | 2009-02-06 | 1 | -4/+0 |
* | 2009-02-06 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-06 | 1 | -0/+5 |
| | | | | | * posix/include/sched.h, posix/src/sched_getparam.c: Make sched_getparam() POSIX compliant. | ||||
* | Make sched_getparam() POSIX compliant. | Ralf Corsepius | 2009-02-06 | 2 | -2/+2 |
* | 2009-02-06 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-06 | 1 | -0/+4 |
| | | | | * Makefile.am: Don't install libcsupport/include/tar.h. | ||||
* | Remove tar.h. | Ralf Corsepius | 2009-02-06 | 1 | -2/+0 |
| | | | | | * aclocal/canonical-target-name.m4, aclocal/enable-posix.m4: Remove comment referring to HPUX. | ||||
* | Remove comment referring to HPUX. | Ralf Corsepius | 2009-02-06 | 2 | -2/+0 |
* | 2009-02-05 Sebastian Huber <sebastian.huber@embedded-brains.de> | Ralf Corsepius | 2009-02-05 | 2 | -2/+7 |
| | | | | | * libnetworking/lib/ftpfs.c: Enable write and mount filesystem with read-write access. | ||||
* | 2009-02-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-05 | 1 | -0/+1 |
| | | | | * ftpd/ftpd.c: Change SIX_MONTHS to time_t. | ||||
* | Change SIX_MONTHS to time_t. | Ralf Corsepius | 2009-02-05 | 1 | -1/+1 |
* | 2009-02-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-05 | 1 | -0/+4 |
| | | | | * sapi/include/rtems/io.h: Move extern "C" brace after includes. | ||||
* | Move extern "C" brace after includes. | Ralf Corsepius | 2009-02-05 | 1 | -2/+2 |
* | 2009-02-04 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-05 | 1 | -0/+6 |
| | | | | | | * libnetworking/net/if_ppp.h: Eliminate pppattach, pppintr (Unused). * libnetworking/net/if_ppp.c: Eliminate pppintr (Unused). | ||||
* | Eliminate pppattach, pppintr (Unused). | Ralf Corsepius | 2009-02-04 | 1 | -4/+0 |
* | Eliminate pppintr (Unused). | Ralf Corsepius | 2009-02-04 | 1 | -8/+0 |
* | 2009-02-04 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-04 | 1 | -0/+1 |
| | | | | * libnetworking/rtems/rtems_dhcp.c: Remove #define KERNEL. | ||||
* | Remove #define KERNEL. | Ralf Corsepius | 2009-02-04 | 1 | -6/+0 |
* | 2009-02-04 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-04 | 1 | -0/+3 |
| | | | | | | * libnetworking/Makefile.am, libnetworking/rtems/rtems_bsdnet.h, libnetworking/rtems/rtems_dhcp.c: Remove -D_COMPILING_BSD_KERNEL_ (Unused). | ||||
* | Remove -D_COMPILING_BSD_KERNEL_ (Unused). | Ralf Corsepius | 2009-02-04 | 1 | -5/+0 |
* | Remove -D_COMPILING_BSD_KERNEL_. | Ralf Corsepius | 2009-02-04 | 2 | -3/+1 |
| | | | | * libnetworking/Makefile.am: Remove -DKERNEL. | ||||
* | Remove -DKERNEL. | Ralf Corsepius | 2009-02-04 | 1 | -1/+1 |
| | | | | * libnetworking/rtems/rtems_mii_ioctl.c: Remove #undef KERNEL. | ||||
* | Remove #undef KERNEL. | Ralf Corsepius | 2009-02-04 | 1 | -1/+0 |
