reduce size of data area.
IMFS: Fixed creation of symbolic links to avoid a compiler warning.
DOSFS: Use LibBlock instead of read() to read the boot record.
and RTEMS_ID_NONE. No object can have this ID.
* libnetworking/netinet/ip_output.c: when fragmenting
multicast packets M_MCAST must be set on all fragments.
This was fixed in FreeBSD ip_output.c 1.82 on 1998/8/23 !
(see my email to rtems-users from 2008/5/15).
* itron/include/rtems/itron/task.h, itron/src/del_tsk.c,
itron/src/exd_tsk.c, itron/src/task.c,
posix/include/rtems/posix/threadsup.h, posix/src/cancel.c,
posix/src/cancelrun.c, posix/src/pthread.c, posix/src/pthreadexit.c,
posix/src/setcancelstate.c, posix/src/setcanceltype.c,
posix/src/testcancel.c, rtems/src/taskdelete.c,
score/inline/rtems/score/object.inl, score/src/objectclose.c,
score/src/threadclose.c: Make all task delete/exit/cancel routines
follow the same critical section pattern. Also ensure that POSIX
cancelation routines are run at thread exit.
* libcsupport/src/termios_baud2index.c,
libcsupport/src/termios_baud2num.c,
libcsupport/src/termios_num2baud.c,
libcsupport/src/termios_setinitialbaud.c: New files.
* libcsupport/Makefile.am, libcsupport/preinstall.am,
libcsupport/include/rtems/termiostypes.h: Move termios helper
routines from libchip to libcsupport. Add routine which makes it easy
for a termios device driver to inform termios of its default baud
rate. This avoids inconsistencies in later termios settings changes.
* libcsupport/include/rtems/watchdogdrv.h: Finish writing comments.
* libcsupport/preinstall.am, sapi/include/confdefs.h: Add baseline
interface for Watchdog Driver.
* libcsupport/include/rtems/watchdogdrv.h: New file.
* score/src/threadchangepriority.c: Just in case the transient
state was set when we entered, ensure that it is still set when
we exit.
* score/src/threadclose.c: When a thread is being deleted, it should
go into the dormant state -- not the transient state.
* libi2c/libi2c.h: Fix typo.
* pppd/example/system.h: Fix path in example -- NOT COMPILED WITH
CPUKIT.
* sapi/include/rtems/init.h, sapi/src/exinit.c: Refactored and renamed
initialization routines to rtems_initialize_data_structures,
rtems_initialize_before_drivers, rtems_initialize_device_drivers, and
rtems_initialize_start_multitasking. This opened the sequence up so
that bootcard() could provide a more robust and flexible framework
which is easier to explain and understand. This also lays the
groundwork for sharing the division of available memory between the
RTEMS workspace and heap and the C library initialization across all
BSPs.
* sapi/src/exinit.c, score/src/threadstartmultitasking.c: Improve
comments.
* score/src/objectget.c: Improve comments and readability.
* rtems/include/rtems/rtems/message.h, sapi/include/confdefs.h,
score/src/coresemseize.c, score/src/threadhandler.c: Comment
improvements from class.
PR 1285/rtems
* sapi/include/rtems/config.h: Remove obsolete
rtems_configuration_get_maximum_devices().
* libblock/include/rtems/nvdisk-sram.h,
libblock/include/rtems/nvdisk.h,
libblock/src/nvdisk-sram.c,
libblock/src/nvdisk.c: New. A Non-volatile memory disk drive.
* Makefile.am, preinstall.am, libblock/Makefile.am: Updated for
the NV disk driver.
* libnetworking/rtems/rtems_dhcp.c: Removed panic()s. Added
interface for rtems_dhcp_failsafe.
* libnetworking/rtems/rtems_dhcp.h: Added interface for
2008-05-01 Arnout Vandecappelle <arnout@mind.be>
* libnetworking/nfs/bootp_subr: Allow some errors for sosend() and
return on timeout in bootpc_call(). Removed panic()s.
* libnetworking/rtems/rtems_glue.c: Fix the cast for the
SIOCAIFADDR ioctl call.
* libnetworking/rtems/rtems_dhcp_failsafe.c,
libnetworking/rtems/rtems_dhcp_failsafe.h: New.
* libnetworking/Makefile.am, libnetworking/preinstall.am: Added
rtems_dhcp_failsafe.c and rtems_dhcp_failsafe.h files.
* rtems/include/rtems/rtems/timer.h: Fix typo.
* rtems/include/rtems.h, rtems/include/rtems/rtems/ratemon.h,
rtems/include/rtems/rtems/status.h,
rtems/include/rtems/rtems/tasks.h, rtems/include/rtems/rtems/timer.h,
rtems/inline/rtems/rtems/sem.inl: More Doxygen warnings removed.
* posix/src/keycreate.c, posix/src/pthreadequal.c,
rtems/src/semtranslatereturncode.c,
score/cpu/powerpc/rtems/score/powerpc.h,
score/src/threadblockingoperationcancel.c: Fix compilation errors
when --enable-rtems-debug is used.
* score/include/rtems/system.h: Fix typo in comment.
* rtems/include/rtems/rtems/partmp.h, sapi/include/confdefs.h: Fix
typos added with recent changes.
* libcsupport/Makefile.am, libcsupport/include/rtems/libio.h: Remove
rtems_termios_reserve_resources. It is obsolete.
* libcsupport/src/termiosreserveresources.c: Removed.
* rtems/mainpage.h: New file.
* rtems/Doxyfile, rtems/include/rtems/rtems/asr.h,
rtems/include/rtems/rtems/attr.h,
rtems/include/rtems/rtems/barrier.h,
rtems/include/rtems/rtems/barriermp.h,
rtems/include/rtems/rtems/cache.h,
rtems/include/rtems/rtems/config.h,
rtems/include/rtems/rtems/dpmem.h, rtems/include/rtems/rtems/event.h,
rtems/include/rtems/rtems/eventmp.h,
rtems/include/rtems/rtems/eventset.h,
rtems/include/rtems/rtems/intr.h,
rtems/include/rtems/rtems/modes.h, rtems/include/rtems/rtems/mp.h,
rtems/include/rtems/rtems/msgmp.h,
rtems/include/rtems/rtems/options.h,
rtems/include/rtems/rtems/part.h, rtems/include/rtems/rtems/partmp.h,
rtems/include/rtems/rtems/region.h,
rtems/include/rtems/rtems/regionmp.h,
rtems/include/rtems/rtems/rtemsapi.h,
rtems/include/rtems/rtems/sem.h, rtems/include/rtems/rtems/semmp.h,
rtems/include/rtems/rtems/signal.h,
rtems/include/rtems/rtems/signalmp.h,
rtems/include/rtems/rtems/support.h,
rtems/include/rtems/rtems/taskmp.h,
rtems/include/rtems/rtems/types.h, rtems/inline/rtems/rtems/asr.inl,
rtems/inline/rtems/rtems/attr.inl,
rtems/inline/rtems/rtems/barrier.inl,
rtems/inline/rtems/rtems/dpmem.inl,
rtems/inline/rtems/rtems/event.inl,
rtems/inline/rtems/rtems/message.inl,
rtems/inline/rtems/rtems/modes.inl,
rtems/inline/rtems/rtems/options.inl,
rtems/inline/rtems/rtems/part.inl,
rtems/inline/rtems/rtems/ratemon.inl,
rtems/inline/rtems/rtems/region.inl,
rtems/inline/rtems/rtems/sem.inl,
rtems/inline/rtems/rtems/status.inl,
rtems/inline/rtems/rtems/support.inl,
rtems/inline/rtems/rtems/timer.inl: More Doxygen improvements.
* rtems/include/rtems.h, rtems/include/rtems/rtems/asr.h,
rtems/include/rtems/rtems/cache.h, rtems/include/rtems/rtems/clock.h,
rtems/include/rtems/rtems/object.h,
rtems/inline/rtems/rtems/eventset.inl,
rtems/inline/rtems/rtems/tasks.inl,
rtems/inline/rtems/rtems/timer.inl: Initial conversion of Classic API
header files to Doxygen.
* rtems/Doxyfile: New file.
* posix/src/key.c: Include <limits.h>
* posix/src/psignal.c, rtems/src/tasks.c: Do not attempt to process
a NULL extension block.
* cpu.c: Add comment.
* libmisc/dummy/dummy.c, sapi/include/confdefs.h: Add checks for
application configuration errors. If any POSIX objects or a POSIX
init thread is configured without POSIX being configure, then error
out. Similarly for ITRON. Add
CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER configuration
parameter so the application has to explicitly configure the Clock
driver in or out if the Timer driver is not configured. Also verify
RTEMS was built for multiprocessing, if the user tries to configure a
multiprocessing application.
* cpu.c: Add arm_cpu_mode so ARM BSP can overrid default value for
cpsr.
* libmisc/shell/shell.c, libmisc/shell/shell.h,
libmisc/shell/shell_script.c: Add support to echo the commands to
stdout. This is useful with the -v script option to show commands
as the run. Also added support to chdir to the directory the task
invoking the script is in.
* libmisc/shell/extern-cp.h, libmisc/shell/main_cp.c,
libmisc/shell/utils-cp.c: Update tro the latest FreeBSD version.
* libcsupport/Makefile.am, libcsupport/src/fchown.c: Add fchown
support.
* score/include/rtems/score/tod.h: Fix typo.
* libmisc/shell/shell.c: Copy the cmd line to a buffer to split
into argv parts. Was using the command line history buffer so the
history was being corrupted.
* libfs/src/nfsclient/src/librtemsNfs.h,
libfs/src/nfsclient/src/nfs.c: Remove CEXP references. CEXP is
external to RTEMS and even if in the cpukit it should not cross
reference in this way.
* libmisc/shell/shell_getchar.c: New. Taken from the monitor.
* libmisc/Makefile.am: Add shell_getchar.c and clean up a little
in the shell area.
* libmisc/shell/shell.c, libmisc/shell/shell.h: Add line editting
support.
* librpc/include/rpc/clnt.h: Added the missing __BEGIN_DECLS as
reported to the mailing list by Pierre Kestener
(pierre.kestener@cea.fr).
* shttpd/log.c: Activate SPLIT_SNPRINTF for gcc <= 4.2.3 and
coldfire.
* libmisc/shell/cmds.c: Directly register the command structure to
avoid unnecessary duplication of static strings. We know best this
time.
* sapi/include/confdefs.h: Do not reserve 2 * minimum stack size
for the ITRON initialization tasks ALL the time.
Do not reserve memory for the object name table since it does not
exist any longer.
* sapi/include/rtems/sptables.h: Fix typo.
