path: root/cpukit (follow)
* Added rest of opendir family and made it compile.Joel Sherrill1998-10-131-1/+16
* New files.Joel Sherrill1998-10-135-0/+328
* New files.Joel Sherrill1998-10-122-0/+164
* Added header files per request from Chris Johns to avoid problemsJoel Sherrill1998-10-121-0/+4
| | | | in include file order.
* Patch from Ian Lance Taylor <ian@airs.com>:Joel Sherrill1998-10-011-5/+8
| | | | | | | | The reentrant versions of the malloc functions in c/src/lib/libc/malloc.c do not match the definitions in newlib. These will be used if you use newlib routines such as fdopen. I believe this patch to malloc.c is needed to provide the correct versions.
* Patch from Eric Norum <eric@skatter.usask.ca>:Joel Sherrill1998-09-291-3/+2
| | | | | | | | | | | | | | Remember the test to see if a socket could be read and written at the same time by two different tasks? I discovered that if both tasks attempt to close the socket a panic can occur from inside the BSD code. Closing the same socket twice from two different threads is certainly an error, but a panic is not the greatest error reporting method :-) The following small change to the socket close routine should reduce the chances of the panic.
* New files.Joel Sherrill1998-09-272-0/+34
* Now compiles.Joel Sherrill1998-09-252-0/+2
* Added ENOSYS stubs for a number of process routines.Joel Sherrill1998-09-258-0/+132
* IDLE task stack size now specified as a field in the CPU Table for allJoel Sherrill1998-09-232-10/+7
| | | | ports.
* Modifed to zero out the C heap if the CPU Table indicates that theJoel Sherrill1998-09-231-0/+15
| | | | RTEMS workspace is to be zeroed out.
* Patch from Aleksey (Quality Quorum <qqi@world.std.com>):Joel Sherrill1998-09-232-4/+10
| | | | | | | | | | | 1. Finally fixes raw interrupts for pc386 2. Makes some minor cleanup in console and startup 3. Makes rtems_termios_dequeue_characters() to return count of outstanding chars - it allows to simplify console isrs a little bit. 4. pc386 uart modified to be friendlier to termios parameter changes, to have minor performance improvement and to take advantage of of above termios modification.
* Patch from Eric Norum <eric@skatter.usask.ca>:Joel Sherrill1998-09-211-29/+101
| | | | | | | Here's a patch to make the rtems_showroute routine a little more useful. For `host' route table entries the link-level address is now displayed. This is equivalent to the old `show arp table' information displayed by the KA9Q code.
* Patch from Eric Norum and David Fiddes to put ColdFire support inJoel Sherrill1998-09-212-16/+18
| | | | the inet checksum routine.
* Patch from Eric Norum:Joel Sherrill1998-09-211-7/+2
| | | | | | | | I fixed the problems noted by Victor Vengerov. 1) Fix typo in cfsetispeed(). 2) In rtems_termios_open, ensure that args->iop->data1 is set before calling device-specific open routine.
* Corrected spelling error.Joel Sherrill1998-09-111-10/+10
* Patch from "David J. Fiddes" <D.J@fiddes.surfaid.org>:Joel Sherrill1998-09-112-252/+74
| | | | | | | | | | | I've fixed a few minor probs with the optimised version that Eric put together for me the other day and sent the fixes back to him. Provided he doesn't have a problem with it we've got a pretty solid in_cksum for the ColdFire as well as straight m68k. I've enclosed my updated in_cksum_m68k.c At the moment my own bottlenecks are elsewhere...as my driver is pulling 16bit data chunks through a libchip-esq access routine from the chip which for a polled I/O device is never going to be quick.
* Patch from David Fiddes <D.J.Fiddes@hw.ac.uk> to make this compileJoel Sherrill1998-09-102-2/+2
| | | | for the ColdFire.
* Patch from Eric Norum <eric@skatter.usask.ca> to fix a cryptic errorJoel Sherrill1998-09-101-1/+3
| | | | message after comments from Eric Valette <valette@crf.canon.fr>.
* Fixed spacing. More comments from Eric Norum need to be addressed.Joel Sherrill1998-08-311-7/+7
* Patch from Emmanuel Raguet <raguet@crf.canon.fr>:Joel Sherrill1998-08-312-3/+9
| | | | | I have reworked the ethernet driver for the BSP pc386 and here is the patch to apply.
* Patch from Eric Valette <valette@crf.canon.fr>:Joel Sherrill1998-08-311-6/+17
| | | | | | | | | | | | | | | | | | | Eric> NB : there is still a bug on PC386 serial line : exit does not Eric> flush the remaining output queue. As this is not a bug in the Eric> driver itself but somewhere in PC386 initialization/termios Eric> relationship it will be part of another patch. Eric> NB2 : As Emmanuel excerced the exception hanlder code, while Eric> porting the SMC driver to the new BSD stack, we found a bug Eric> in the exception handler : it shall not delete the current Eric> thread in case we are running at interrupt level. This will Eric> be part of another patch... So here is the patch. This patch fixes the two problems mentionned above + it use vpath mechanism intead of copying the irq related files in the right directory. This avoid to compile them each time and is more homogenous with other Makefiles.
* Patch from Eric Norum <eric@skatter.usask.ca>:Joel Sherrill1998-08-311-4/+2
| | | | | | | | | | | | | | I think I figured out why rtems_panic was locking up instead of shutting down the executive and returning to the code that called boot_card(). Later on there is code to print some messages on the standard error stream, a recursive call back to rtems_verror (through rtems_error) and finally a call to _exit(). I think that the _Thread_Disable_dispatch() is preventing the final context switch back to the boot_card() code. Does this sound right to you?
* Added __RTEMS_INSIDE__ macro to insure that ".inl" files are ALWAYS includedJoel Sherrill1998-08-241-1/+1
| | | | when building the executive source.
* Added i386 specific version of in_cksum.c and restructured the mainJoel Sherrill1998-08-215-151/+1024
| | | | file to switch out to CPU specific implementations.
* Another missing piece. Thanks Eric.Joel Sherrill1998-08-211-0/+3
* Added system task attribute to allow one to create a task with "0" priorityJoel Sherrill1998-08-214-9/+40
| | | | via the user api.
* Patch from Eric Valette <valette@crf.canon.fr>:Joel Sherrill1998-08-211-0/+90
| | | | | | | | | | Here is a patch that enables to catch exception and get message before crashing RTEMS :) It should be generic to any Intel port although enabled only for pc386 BSP... [Joel] I fixed the bug I introduced in irq_asm.s...
* Spacing changesJoel Sherrill1998-08-211-1/+0
* Fix from Eric Norum <eric@skatter.usask.ca>:Joel Sherrill1998-08-211-14/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | "Thomas Doerfler" <td@imd.m.isar.de> wrote: > > While implementing/testing the console/termios support for > PPC403 in RTEMS-4.0.0-beta3, I am stuck at a certain location in > termios.c: > > During "rtems_termios_initialize", the main control data structure > "*tty" is allocated using malloc(). (Note, that malloc does not > clear the allocated memory and my BSP does not clear memory during > startup). Furtheron, a lot of fields of that structure are > initialized, but the field "rawOutBufState" is not, and therefore > keeps an arbitrary contents. > > When "osend()" is called the first time(with the serial device > driver working in interrupt mode), termios gets stuck and will not > call the device drivers output function. > > My questions now are: > > - anybody already experienced this bug? > - is it a bug at all or did I do anything fundamentally wrong? > - is there already a common bugfix for that? > > I don't like poking around in other people code, as long as I am > not absolutely sure, what I do... Yes, there's a bug there. I thought that Joel had patched this already, but here's a patch to fix this. This patch also addresses a concern that many others have raised regarding enabling and disabling of transmitter interrupts. First, here's the example I've been using of a simple UART-style interrupt-driven driver: =============================================================== void device_write_routine (int minor, char *buf, int count) { UART->control_register &= ~UART_TRANSMITTER_READY; UART->output_register = *buf; UART->control_register |= UART_TRANSMIT_INTERRUPT_ENABLE; } void device_transmit_interrupt_routine (int vector) { UART->control_register &= ~UART_TRANSMIT_INTERRUPT_ENABLE; rtems_termios_dequeue_characters (device_ttyp, 1); } ============================================================== Several people have expressed their concern about the disable/enable of transmitter interrupts for every character. On some machines this disable/enable is an expensive operation. With the attached patch applied you can write the two routines as: ============================================================== void device_write_routine (int minor, char *buf, int count) { code_to_clear_transmitter_ready_status (); if (device_ttyp->rawOutBufState == rob_idle) code_to_enable_transmitter_interrupts (); code_to_send_one_character_to_transmitter (*buf); } void device_transmit_interrupt_routine (int vector) { rtems_termios_dequeue_characters (device_ttyp, 1); if (device_ttyp->rawOutBufState == rob_idle) code_to_disable_transmitter_interrupts (); } ===============================================================
* All warnings removed.Joel Sherrill1998-08-217-6/+25
* Added initialization of missing termios structure entries.Joel Sherrill1998-08-211-2/+3
* Fixed warning about pointer/integer conversion which turned out to beJoel Sherrill1998-08-211-1/+1
| | | | a missed "&" on a write.
* Patches from Eric NorumJoel Sherrill1998-08-202-3/+19
* Added CVS IdsJoel Sherrill1998-08-2064-0/+201
* Fixed many warnings.Joel Sherrill1998-08-2034-82/+160
* FreeBSD stack compiles for the first time (except libc/strsep.c).Joel Sherrill1998-08-209-0/+298
* Base filesJoel Sherrill1998-08-19212-0/+59532
* Patch from Eric Valette <valette@crf.canon.fr>:Joel Sherrill1998-08-191-1/+8
| | | | | | | - Use the "hlt" instruction for the Idle thread, - Optimise interrupt PATH leadding to thread wakeup, - Preparation for Intel exception management that should come before the end of the week...
* Automatic CPU type detection code from Eric Valette <valette@crf.canon.fr>.Joel Sherrill1998-08-052-0/+2
| | | | Enabled on the pc386.
* Merged patch from David Fiddes <D.J.Fiddes@hw.ac.uk> to add ColdFireJoel Sherrill1998-08-012-2/+18
| | | | specific register macros and correct code in rtems.s.
* Closed window thanks to patch from Eric Norum.Joel Sherrill1998-07-281-5/+3
* Patch from Eric VALETTE <valette@crf.canon.fr>:Joel Sherrill1998-07-231-99/+0
| | | | | | | | | | | | | Here is a enhanced version of my previous patch. This patch enables to potentially share the new interrupt management code for all Intel targets (pc386, go32 and force386) bsp. Note : this patch is complete only for pc386. It still needs to be completed for go32 and force386. I carrefully checked that anything needed is in for force386 (only some function name changes for IDT manipulation and GDT segment manipulation). But anyway I will not be able to test any of theses targets...
* Initialized tty->refcount to 0. When (for whatever reason) malloc()Joel Sherrill1998-07-171-0/+3
| | | | | | | | | | | | | | returned a buffer which was not zero-filled, the reference count was not correct. When the application exitted, the "lastClose" handler was not being called to flush the output. This problem had manifested itself on a variety of platforms. The function rtems_termios_dequeue_characters() incorrectly incremented the buffer pointers when it was invoked and there were no characters in the ring buffer. This problem had also manifested itself on a variety of platforms. The symptom was a strange repeating of the data in the transmitter buffer when the transmitter serial device was supposed to go idle.
* Patch from Dario Alcocer <alcocer@connectnet.com>. His comments:Joel Sherrill1998-07-171-0/+2
| | | | | | | | | Haven't had a chance to do an extensive shake-out of 980710, but it builds just fine on FreeBSD 2.2.5 (after termios is fixed using the attached patch), and the tests run fine. FYI: FreeBSD doesn't support System V IPC out of the box, but one only needs to add three options to the kernel build configuration file, recompile the kernel, and you're ready.
* New file to satisfy readdir() family.Joel Sherrill1998-07-061-0/+14
* Fixed typo.Joel Sherrill1998-07-011-1/+1
* All task delete API level services were incorrectly assuming that theJoel Sherrill1998-06-182-2/+15
| | | | | | | | | | | task to be deleted was created via the same API (i.e. were of the object class created by this API). For example, a POSIX thread calling the rtems_task_delete(SELF) directive would incorrectly update the RTEMS object local pointer table. Jennifer discovered this when moving tests implemented in C using the Classic RTEMS API into a tree of Ada tests. The Ada tests were implicitly using POSIX services. This lead to some unexpected behavior.
* Modified _Objects_Is_class_valid() to correctly report that 0 wasJoel Sherrill1998-06-182-2/+2
| | | | | not a valid object class. This was discovered while looking for a bug reported by Jennifer.
* Added freebsd support from Dario Alcocer <alcocer@connectnet.com>.Joel Sherrill1998-06-182-2/+21
