path: root/cpukit (follow)
* libdebugger: Fix the mode on task create. Clean up warnings.Chris Johns2017-04-191-14/+21
| | | | Closes #2976.
* libmisc/monitor: Correctly print unlimited configuration table entries.Chris Johns2017-04-191-12/+22
| | | | Closes #2997.
* Merge tmacros.h PRIxxx constants from testsuites/ into <rtems/inttypes.h>Joel Sherrill2017-04-182-20/+76
| | | | | | | This completes the initial creation of rtems/inttypes.h based on all existing PRIxxx definitions contained in RTEMS Project owned code. closes #2983.
* rtems/inttypes.h: New file. Uses contents from cpukitJoel Sherrill2017-04-189-59/+90
| | | | | | | | Provide extentions to <inttpes.h> PRIxxx constants for more POSIX types. Start with existing definitions found in RTEMS Project owned code in cpukit/. updates #2983.
* libdebugger: Work around assert when using _Thread_Executing.Chris Johns2017-04-152-2/+8
| | | | | | | Using _Thread_Executing with RTEMS_DEBUG results in an `assert` if the server accesses invalid memory. Updates #2993.
* cpukit/../i386/cpu.c: Use inttypes.h to fix 1 warning.Cillian O'Donnell2017-04-141-1/+2
* Updating default termios initialization for dedicated input/output baud ratesKevin Kirspel2017-04-101-1/+4
| | | | updates #2897.
* libdl/rtl-obj-cache.c: Using inttypes macros fixes 4 format warningsCillian O'Donnell2017-04-071-9/+12
* xz_config.h: Define XZ_USE_CRC64Joel Sherrill2017-04-061-1/+1
| | | | close #2909.
* SMP: Simplify SMP multicast actionsSebastian Huber2017-04-054-63/+85
* sys/event.h: Update to FreeBSD head 2017-02-13Sebastian Huber2017-04-041-7/+9
* bsps: Fix baud settingsSebastian Huber2017-04-032-5/+3
| | | | Update #2897.
* configure: Remove defunct configure stuffSebastian Huber2017-04-031-2/+0
* libdl: Support link ordered loading of ELF sections.Chris Johns2017-03-315-36/+166
| | | | | | | | | | | | | The ARM C++ exception ABI uses an address ordered index table to locate the correct frame data and this requires the EXIDX sections are loaded in the order the order the matching text is loaded. The EXIDX sections set the SHF_LINK_ORDER flag and link field. This patch adds support to load those flagged sections in the linked-to section order. Updates #2955. Closes #2959
* arm: Optimize context switchSebastian Huber2017-03-283-78/+55
| | | | | | | | | Set CPU_ENABLE_ROBUST_THREAD_DISPATCH to TRUE. In this case the interrupts are always enabled during a context switch even after interrupt processing (see #2751). Remove the CPSR from the context control since it contains only volatile bits. Close #2954.
* posix: Fix pthread_detach() internal lock acquireSebastian Huber2017-03-281-1/+1
* rtems: Fix error return pathSebastian Huber2017-03-281-0/+1
* cpukit: Fix Makefile.am and update preinstall.amSebastian Huber2017-03-272-18/+20
| | | | Update #2897.
* termios: Avoid invalid memory accessSebastian Huber2017-03-271-1/+3
| | | | Update #2897.
* termios: Synchronize with latest FreeBSD headersKevin Kirspel2017-03-2226-293/+658
| | | | | | | | | | | Adding modified FreeBSD headers to synchronize RTEMS termios with FreeBSD. Modify termios to support dedicated input and output baud for termios structure. Updated BSPs to use dedicated input and output baud in termios structure. Updated tools to use dedicated input and output baud in termios structure. Updated termios testsuites to use dedicated input and output baud in termios structure. Close #2897.
* dosfs: Fix file name searchSebastian Huber2017-03-161-17/+7
| | | | | | | Do not use our long file name entry count to optimize the file name search. The Unicode comparison must be taken into account. Update #2939.
* dosfs: Fix race condition msdos_dir_read()Sebastian Huber2017-03-161-5/+5
| | | | | | Obtain file system instance lock before member access. Update #2937.
* dosfs: Rename fat_entries to lfn_entriesSebastian Huber2017-03-161-20/+20
| | | | | The name "fat_entries" for long file name directory entries is quite misleading.
* dosfs: Fix long file name paddingSebastian Huber2017-03-161-3/+3
| | | | Update #2934.
* dosfs: msdos_filename_utf8_to_short_name_for_saveSebastian Huber2017-03-161-15/+10
| | | | Simplify.
* dosfs: Fix msdos_add_file()Sebastian Huber2017-03-161-245/+155
| | | | | | Make sure that long file names work accross cluster boundaries. Update #2929.
* dosfs: Simplify msdos_add_file()Sebastian Huber2017-03-161-4/+2
| | | | Update #2929.
* dosfs: Add and use msdos_lfn_checksum()Sebastian Huber2017-03-163-22/+25
| | | | Update #2929.
* dosfs: Simplify fat_file_open()Sebastian Huber2017-03-161-3/+1
| | | | Update #2929.
* dosfs: Simplify msdos_creat_node()Sebastian Huber2017-03-161-21/+14
| | | | Update #2929.
* dosfs: Fix fat_file_write()Sebastian Huber2017-03-163-30/+11
| | | | | | | | Remove forced overwrite which leads to file data corruption. The logic to determine a forced overwrite was fundamentally broken. For simplity, disable this feature. Update #2622.
* dosfs: Fix msdos_utf8_normalize_and_fold()Sebastian Huber2017-03-161-2/+2
| | | | | | | | It is all right in case the result uses the full destination buffer. Without this fix the handling of a maximum 8.3 short file name is broken. Update #2928.
* libio: Fix deadlock in location managementSebastian Huber2017-03-167-13/+17
| | | | | | | | Perform a context-dependent deferred location release to avoid a deadlock on the file system instance locks, for example during a chdir(). Update #2936.
* arm: Fix CPU context validation for Cortex-R4Sebastian Huber2017-03-092-7/+3
| | | | Do not touch the FPSCR[QC] bit since this is DNM/RAZ on Cortex-R4.
* arm: Remove legacy execption supportSebastian Huber2017-03-084-301/+0
* monitor: Do not zero sema id and nameSebastian Huber2017-03-071-1/+5
* score: Fix scheduler yield in SMP configurationsSebastian Huber2017-03-074-20/+46
| | | | | | | | | Check that no ask help request is registered during unblock and yield scheduler operations. There is no need to ask for help if a scheduled thread yields, since this is already covered by the pre-emption detection. Update #2556.
* powerpc: Fix PPC_CONTEXT_VOLATILE_SIZESebastian Huber2017-03-061-1/+1
* libdrvmgr: remove bracesDaniel Cederman2017-03-061-1/+1
* libdrvmgr: added default BSP init level hookDaniel Hellstrom2017-03-061-0/+9
* libpci: code cleanupDaniel Hellstrom2017-03-061-3/+1
* posix_devctl: Fix for pre C99Sebastian Huber2017-03-021-5/+5
| | | | | Use __restrict just like in <devctl.h> to avoid compiler errors with older GCC, e.g. 4.8 or 4.9.
* dosfs: Fix FAT32 formatterSebastian Huber2017-02-281-2/+2
| | | | | | | | | The second FAT entry contains a bit to indicate if the FAT32 filesystem is not dirty and a bit to indicate if there was no IO error. Set both bits for a fresh filesystem. This prevents a warning if mounted on Windows. Close #2913.
* dosfs: Directories should have a file size of 0Sebastian Huber2017-02-281-1/+6
| | | | Close #2755.
* termios: Simplify some calculationsSebastian Huber2017-02-281-4/+3
| | | | Use the modular arithmetic addition rule.
* termios: Implement non-blocking writeSebastian Huber2017-02-281-4/+6
* termios: Make write POSIX compatibleSebastian Huber2017-02-281-34/+81
| | | | | | | | Currently only blocking read/write operations are implemented. A blocking write must transfer at least one character. It should not wait for the device for the second character and so on. Close #2917.
* termios: Introduce doTransmit()Sebastian Huber2017-02-281-10/+15
* termios: Simplify oproc()Sebastian Huber2017-02-281-19/+36
| | | | Call rtems_termios_puts() only once. Adjust column in one place.
* termios: Fix infinite loop in receive pathSebastian Huber2017-02-281-5/+9
| | | | | | | In canonical mode, the raw input buffer or the canonical buffer may overflow without an end of line. Avoid an infinite loop in this case. Close #2915.
