for details.
The per file descriptor semaphore (field of rtems_libio_t) is unused in
RTEMS. There is a considerable memory overhead due to that. A
semaphore needs roughly 124 bytes which is huge compared to the
approximately 72 bytes for the file descriptor structure itself. Device
drivers can create their own synchronization primitives in the open
handler on demand.
Many files had an extra blank line in the license text
found in the file header. This patch removes that line.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.com/license/LICENSE.
The script that did this also turned off execute permission
when it was turned on incorrectly.
Update the assert macro to the new IMFS_jnode_t.
The increase of the stack size by CPU_STACK_ALIGNMENT in
_Thread_Stack_Allocate() is disadvantageous. This may lead to a huge
over allocation for specialized stack allocators. The
CPU_STACK_ALIGNMENT is at most 16 on all current RTEMS CPU ports. The
mimimum stack size ensured by _Stack_Ensure_minimum() must be
considerable larger than this value, otherwise stack overflows will
likely occur. Thus the _Stack_Adjust_size() is also superfluous.
Use UID and GID of the NFS handle for node and symbolic link creation.
According to POSIX the read() call should return the maximum number of
bytes available for regular files.
Check the availablity of a recycle destination segment only when it is
necessary to avoid missing resycle source segment erasures.
Do not use the unavailable block count as the erased blocks starvation
threshold. Use instead the block count of the largest segment. This
improves the starvation resolution gain of available blocks.
Add the lipqos and sptest.
Since the CBS scheduler is inspired by AQuoSA project for Linux, additional API
(qreslib) compliant with Linux has been created.
Sptest for qreslib included.
The new function rtems_bdbuf_set_block_size() must be used to set the
block size of a disk device. It will check if the block size is valid
and set the new fields block_to_media_block_shift and bds_per_group of
the rtems_disk_device structure. This helps to avoid complex arithmetic
operations in the block device buffer get and read path.
Calling the bdbuf API functions in the not configured state is now a
fatal error.
The transfer chain is accessed by at most one thread at a time.
The chains are protected by the bdbuf cache lock.
New macros
o _Objects_Maximum_per_allocation(),
o rtems_resource_is_unlimited(), and
o rtems_resource_maximum_per_allocation().
New function
o _Objects_Is_unlimited().
Add
o _Nios2_MPU_Get_region_descriptor(), and
o _Nios2_MPU_Set_region_registers().
In the Red-Black Tree Heap the administration data structures are not
contained in the managed memory area. This can be used for example in a
task stack allocator which protects the task stacks from access by other
tasks.
New functions
o _RBTree_Next_unprotected(),
o _RBTree_Next(),
o _RBTree_Successor_unprotected(),
o _RBTree_Predecessor_unprotected(),
o rtems_rbtree_successor_unprotected(), and
o rtems_rbtree_predecessor_unprotected().
Change prototype of
o _RBTree_Successor(),
o _RBTree_Predecessor(),
o rtems_rbtree_successor(), and
o rtems_rbtree_predecessor().
Add and use function _ARMV7M_Set_exception_priority_and_handler(). Use
ARMV7M_EXCEPTION_PRIORITY_LOWEST define.
o Move rtems_bsdnet_fdToSocket() and rtems_bsdnet_makeFdForSocket() to
"cpukit/libnetworking/rtems/rtems_syscall.c".
o The rtems_bsdnet_makeFdForSocket() function is now static.
o Check in rtems_bsdnet_fdToSocket() function that the file descriptor
uses the socket handlers, otherwise an error status will be returned
and errno set to ENOTSOCK.
o New test libtests/syscall01.
Change the ioctl_return type of rtems_libio_ioctl_args_t to match the
ioctl() return value type.
This commit covers at least PR2020, 2022, and 2023. This
patch adds all of the code for both BSPs, modifications
to libcpu/powerpc for the ppc440, and some updates to the
BSPs from follow up review and testing.
These BSPs should be good baselines for future development.
The configurations used by Ric are custom and have a non-standard
NIC. They also do not have a UART. Thus the current console
driver just prints to a RAM buffer.
The NIC and UART support are left for future work. When the UART
support is added, moving the existing "to RAM" console driver to
a shared location is likely desirable because boards with no debug
UART port are commonly deployed. This would let printk() go to RAM.
This fix is critical. The previous implementation leads to system
corruption.
Change the meaning of the compare result to simplify comparison of
integer keys.
Adds to confdefs a way to specify rtems_resource_unlimited for classic and
posix objects using a new macro CONFIGURE_OBJECTS_UNLIMITED.
Use CONFIGURE_OBJECTS_ALLOCATION_SIZE to declare the allocation size for
extending the set of objects at runtime. Updates the unlimited sample
to demonstrate how to use the new macros. Also adds new documentation in
the C User's Manual regarding configuring with unlimited objects.
