brains GmbH.
Coverity #1530126
Coverity #1530125
Use of this method was likely eliminated during the rework to use
FreeBSD bintime/sbintime.
Close #4905.
The updated files were extracted from:
https://www.zlib.net/zlib-1.2.13.tar.xz
The archive had an SHA-256 hash value of:
d14c38e313afc35a9a8760dadf26042f51ea0f5d154b0630a31da0540107fb98
Close #4902.
AMD64 requires SSE support which operates on 128bit data values.
Close #4863.
There was a cyclic dependency: For RTEMS_STATIC_ANALYSIS we needed
basedefs.h in assert.h. For RTEMS_UNREACHABLE() we needed _Assert() from
assert.h in basedefs.h.
Fix this by introducing _Debug_Unreachable() in basedefs.h.
Add RTEMS_FUNCTION_NAME to basedefs.h and use it in basedefs.h and
assert.h.
Close #4900.
Resolve warnings about mismatched pointer and integer sizes in AArch64
libdl when building with the ILP32 ABI.
This was added with the writebuffer work and should have been protected
by the error check.
Due to API change, the patch also fixes affected BSPs and uses
value provided by MPU CTRL spec option there.
Sponsored-By: Precidata
This adds write buffer and bad block support required for JFFS2
operation on NAND devices. This also adds the minor modifications
necessary for RTEMS support in the Linux header stubs and in wbuf.c.
Memory and NOR backed applications should experience no difference in
operation since they do not expose the callbacks required for write
buffer support.
This pulls in wbuf.c from the upstream Linux repository at the state
specified in VERSION.
Mutexes must be locked before they can be unlocked. JFFS2 doesn't
currently see this as an issue because all mutex operations are no-ops.
The kernel space parts of standard system header files were protected
against misuse by a preprocessor error directive. This approach does
not work well with tools such as Doxygen. Provide the kernel space
items only if the required defines are present.
The comment above bintime2timespec() says:
When converting between timestamps on parallel timescales of differing
resolutions it is historical and scientific practice to round down.
However, the delta_nsec value is a time difference and not a timestamp. Also
the rounding errors accumulate in the frequency accumulator, see hardpps().
So, rounding to the closest integer is probably slightly better.
Reviewed by: imp
Pull Request: https://github.com/freebsd/freebsd-src/pull/604
Let A be the current calculation of the frequency accumulator (pps_fcount)
update in pps_event()
scale = (uint64_t)1 << 63;
scale /= captc->tc_frequency;
scale *= 2;
bt.sec = 0;
bt.frac = 0;
bintime_addx(&bt, scale * tcount);
bintime2timespec(&bt, &ts);
hardpps(tsp, ts.tv_nsec + 1000000000 * ts.tv_sec);
and hardpps(..., delta_nsec):
u_nsec = delta_nsec;
if (u_nsec > (NANOSECOND >> 1))
u_nsec -= NANOSECOND;
else if (u_nsec < -(NANOSECOND >> 1))
u_nsec += NANOSECOND;
pps_fcount += u_nsec;
This change introduces a new calculation which is slightly simpler and more
straight forward. Name it B.
Consider the following sample values with a tcount of 2000000100 and a
tc_frequency of 2000000000 (2GHz).
For A, the scale is 9223372036. Then scale * tcount is 18446744994337203600
which is larger than UINT64_MAX (= 18446744073709551615). The result is
920627651984 == 18446744994337203600 % UINT64_MAX. Since all operands are
unsigned the result is well defined through modulo arithmetic. The result of
bintime2timespec(&bt, &ts) is 49. This is equal to the correct result
1000000049 % NANOSECOND.
In hardpps(), both conditional statements are not executed and pps_fcount is
incremented by 49.
For the new calculation B, we have 1000000000 * tcount is 2000000100000000000
which is less than UINT64_MAX. This yields after the division with tc_frequency
the correct result of 1000000050 for delta_nsec.
In hardpps(), the first conditional statement is executed and pps_fcount is
incremented by 50.
This shows that both methods yield roughly the same results. However, method B
is easier to understand and requires fewer conditional statements.
Reviewed by: imp
Reviewed by: imp
Move the pseq increment. This makes it possible to reuse registers earlier.
Reviewed by: imp
Use local variables for the captured timehand and timecounter in pps_event().
This fixes a potential issue in the nsec preparation for hardpps(). Here the
timecounter was accessed through the captured timehand after the generation was
checked.
Make a snapshot of the relevent timehand values early in pps_event(). Check
the timehand generation only once during the capture and event processing. Use
atomic_thread_fence_acq() similar to the other readers.
Reviewed by: imp
This ensures that the timecounter and the tc_get_timecount handler belong
together.
Reviewed by: imp
Sponsored by: Rubicon Communications, LLC ("Netgate")
Since 32c203577a5e by phk in 1999 (Make even more of the PPSAPI
implementations generic), the "nsec" parameter of hardpps() is a time
difference and no longer a time point. Change the name to "delta_nsec"
and adjust the comment.
Remove comment about a clock tick adjustment which is no longer in the code.
Pull Request: https://github.com/freebsd/freebsd-src/pull/640
Reviewed by: imp
The third argument to this function indicates whether the supplied
ticker is fixed or variable, i.e. requiring calibration. Give this
argument a type and name that better conveys this purpose.
Reviewed by: kib, markj
MFC after: 1 week
Sponsored by: The FreeBSD Foundation
Differential Revision: https://reviews.freebsd.org/D35459
(which is used to calculate cputime from cpu ticks) has some imprecision and,
worse, huge timestep (about 20 minutes on 4GHz CPU) near 53.4 days of elapsed
time.
kern_time.c/cputick2timespec() (it is used for clock_gettime() for
querying process or thread consumed cpu time) Uses cputick2usec()
and then needlessly converting usec to nsec, obviously losing
precision even with fixed cputick2usec().
kern_time.c/kern_clock_getres() uses some weird (anyway wrong)
formula for getting cputick resolution.
PR: 262215
Reviewed by: gnn
Differential Revision: https://reviews.freebsd.org/D34558
Update #3707.
Closes #4557
The application configuration options are documented in
"cpukit/doxygen/appl-config.h". Since the application configuration
option defines are also present in multiple test program sources, the
"#OPTION" references cannot be mapped to a unique definition. Add an
anchor for each option and reference it to avoid the issues with the
multiple definitions.
Update #3994.
Rename the constaints section of application configuration options from
"Value Constraints" in "Constraints. Adjust the constraint wording
accordingly. This is in line with the RTEMS Classic API Guide.
Update #3994.
Each BSP may optionally provide default values for some application
configuration options. Remove the documentation of these items, since
the BSP provided defines are not application configuration options, they
are optional default values. Clarify CONFIGURE_DISABLE_BSP_SETTINGS
accordingly and move it into the "General System Configuration" group.
Update #3994.
