* Makefile.am, configure.ac: Remove RTEMS_PROVIDES_STDINT_H,
RTEMS_PROVIDES_INTTYPES_H.
* libcsupport/include/stdint.h, libcsupport/include/inttypes.h:
Remove.
* score/Doxyfile: Remove RTEMS_INLINES.
* rtems/bfin/bf533.h, rtems/bfin/bfin.h: Remove stray whitespaces.
* rtems/score/bfin.h: Use __BFIN__ instead of BFIN.
* configure.ac: Remove redundant AC_CHECK_HEADER([stdint.h]),
AC_CHECK_HEADER([inttypes.h]). Now implicitly checked.
* cpu_asm.S: Re-add HI, LO.
* irq.c: Add missing newline.
* rtems/score/cpu.h: Eliminate hidden backspaces.
* libnetworking/netdb.h, libnetworking/libc/gethostbyht.c,
libnetworking/libc/gethostnamadr.c: This patch adds a functional
gethostbyname_r to RTEMS. We were having problems with multiple
threads calling gethostbyname, so we decided the best way to deal
with it was to do it properly, rather than kludge up our code to make
gethostbyname safe. We have found several slightly different
parameter lists for this function, it does not seem to be standard.
The one we used has the linux interface. In RTEMS there was an
existing gethostbyname_r inside a #ifdef _THREAD_SAFE which was NOT
Threadsafe, as this just called gethostbyname. So we have placed all
of the additional code inside the #ifdef _THREAD_SAFE.
PR 841/rtems
* itron/inline/rtems/itron/semaphore.inl, itron/src/twai_sem.c,
posix/src/semaphorewaitsupp.c, posix/src/semtimedwait.c,
posix/src/semwait.c, rtems/src/semobtain.c,
rtems/src/semtranslatereturncode.c,
score/include/rtems/score/coresem.h, score/src/coresemseize.c: Make
sem_timedwait more conformant to Open Group specification.
* libcsupport/src/termios.c: Change attribute of semaphore. It was
counting interrupts not acting as a condition synchronization mutex.
Since the caller did not always need to obtain the semaphore, it was
not being decremented until there was no data. This could occur after
hours of running a system and thousands of interrupts. The code in
fillBufferQueue would spin until it had consumed all of those
semaphore counts.
* rtems/bfin/bfin.h: Eliminate hi, lo, HI, LO, and MK_BMSK.
* Makefile.am, cpu.c, cpu_asm.S, preinstall.am, rtems/score/bfin.h:
Clean up rtems/score/bfin.h removing parts that are not needed by
RTEMS CPUkit to bfin specific .h files.
* rtems/bfin/bf533.h, rtems/bfin/bfin.h: New files.
* configure.ac, score/cpu/Makefile.am: Add bfin.
* cpu.c, rtems/score/cpu.h: Use the default IDLE thread body.
* .cvsignore, ChangeLog, Makefile.am, cpu.c, cpu_asm.S, irq.c,
preinstall.am, rtems/asm.h, rtems/score/bfin.h, rtems/score/cpu.h,
rtems/score/cpu_asm.h, rtems/score/types.h: New files.
* aclocal/enable-inlines.m4, aclocal/prog-gnat.m4: Remove (Unused).
* score/Makefile.am, score/preinstall.am: Add pieces missed in previous
commit.
* configure.ac, itron/Makefile.am, itron/preinstall.am,
posix/Makefile.am, posix/preinstall.am, rtems/Makefile.am,
rtems/preinstall.am, sapi/Makefile.am, sapi/preinstall.am,
score/Makefile.am, score/preinstall.am, score/include/rtems/system.h,
score/include/rtems/score/chain.h,
score/include/rtems/score/thread.h, score/src/chain.c,
score/src/coremutexseize.c, score/src/threadget.c: Remove all macro
implementations and use only the static inline. Static inline
functions are now well supported so there is no reason for duplicate
maintenance.
* itron/macros/rtems/itron/eventflags.inl,
itron/macros/rtems/itron/fmempool.inl,
itron/macros/rtems/itron/intr.inl, itron/macros/rtems/itron/mbox.inl,
itron/macros/rtems/itron/msgbuffer.inl,
itron/macros/rtems/itron/network.inl,
itron/macros/rtems/itron/port.inl,
itron/macros/rtems/itron/semaphore.inl,
itron/macros/rtems/itron/sysmgmt.inl,
itron/macros/rtems/itron/task.inl, itron/macros/rtems/itron/time.inl,
itron/macros/rtems/itron/vmempool.inl,
posix/macros/rtems/posix/cond.inl, posix/macros/rtems/posix/key.inl,
posix/macros/rtems/posix/mqueue.inl,
posix/macros/rtems/posix/mutex.inl,
posix/macros/rtems/posix/priority.inl,
posix/macros/rtems/posix/pthread.inl,
posix/macros/rtems/posix/semaphore.inl,
posix/macros/rtems/posix/timer.inl, rtems/macros/rtems/rtems/asr.inl,
rtems/macros/rtems/rtems/attr.inl,
rtems/macros/rtems/rtems/barrier.inl,
rtems/macros/rtems/rtems/dpmem.inl,
rtems/macros/rtems/rtems/event.inl,
rtems/macros/rtems/rtems/eventset.inl,
rtems/macros/rtems/rtems/message.inl,
rtems/macros/rtems/rtems/modes.inl,
rtems/macros/rtems/rtems/options.inl,
rtems/macros/rtems/rtems/part.inl,
rtems/macros/rtems/rtems/ratemon.inl,
rtems/macros/rtems/rtems/region.inl,
rtems/macros/rtems/rtems/sem.inl,
rtems/macros/rtems/rtems/status.inl,
rtems/macros/rtems/rtems/support.inl,
rtems/macros/rtems/rtems/tasks.inl,
rtems/macros/rtems/rtems/timer.inl, sapi/macros/rtems/extension.inl,
score/macros/README, score/macros/rtems/score/address.inl,
score/macros/rtems/score/chain.inl,
score/macros/rtems/score/corebarrier.inl,
score/macros/rtems/score/coremsg.inl,
score/macros/rtems/score/coremutex.inl,
score/macros/rtems/score/corerwlock.inl,
score/macros/rtems/score/coresem.inl,
score/macros/rtems/score/corespinlock.inl,
score/macros/rtems/score/heap.inl, score/macros/rtems/score/isr.inl,
score/macros/rtems/score/mppkt.inl,
score/macros/rtems/score/object.inl,
score/macros/rtems/score/objectmp.inl,
score/macros/rtems/score/priority.inl,
score/macros/rtems/score/stack.inl,
score/macros/rtems/score/states.inl,
score/macros/rtems/score/sysstate.inl,
score/macros/rtems/score/thread.inl,
score/macros/rtems/score/threadmp.inl,
score/macros/rtems/score/tod.inl,
score/macros/rtems/score/tqdata.inl,
score/macros/rtems/score/userext.inl,
score/macros/rtems/score/watchdog.inl,
score/macros/rtems/score/wkspace.inl: Removed.
* sapi/include/confdefs.h:
s/STACK_CHECKER_EXTENSION/RTEMS_STACK_CHECKER_EXTENSION/
(Reflect 2006-09-13's changes to libmisc/stackchk).
* aclocal/rtems-top.m4: Remove RTEMS_API.
* aclocal/version.m4: Add RTEMS_API. Bump RTEMS_API to 4.8.
* aclocal/rtems-top.m4: Bump RTEMS_API to 4.8.
* libmisc/capture/capture-cli.c: Use size_t instead of int.
* aclocal/version.m4: Bump version to 4.7.99.0.
* configure.ac, aclocal/multi.m4, aclocal/prog-cc.m4, aclocal/prog-ccas.m4
automake/compile.am: Adaptations to automake-1.10.
which included commits to RCS files with non-trunk default branches.
* libmisc/monitor/mon-command.c: Flush stdout after updating the
command line.
* libnetworking/net/route.c, librpc/src/rpc/auth_none.c,
librpc/src/rpc/auth_unix.c, librpc/src/rpc/authunix_prot.c,
librpc/src/rpc/rpc_callmsg.c, librpc/src/rpc/rpc_prot.c,
librpc/src/rpc/rtems_portmapper.c: Removed warnings.
* sapi/include/confdefs.h, sapi/src/posixapi.c, sapi/src/rtemsapi.c:
Add Classic API Barriers and commented out hooks to initialize .
* rtems/Makefile.am, rtems/preinstall.am, rtems/include/rtems.h,
rtems/include/rtems/rtems/attr.h, rtems/include/rtems/rtems/config.h,
rtems/inline/rtems/rtems/attr.inl, rtems/macros/rtems/rtems/attr.inl:
Add Classic API Barriers.
* rtems/include/rtems/rtems/barrier.h,
rtems/include/rtems/rtems/barriermp.h,
rtems/inline/rtems/rtems/barrier.inl,
rtems/macros/rtems/rtems/barrier.inl, rtems/src/barrier.c,
rtems/src/barriercreate.c, rtems/src/barrierdelete.c,
rtems/src/barrierident.c, rtems/src/barrierrelease.c,
rtems/src/barriertranslatereturncode.c, rtems/src/barrierwait.c:
New files.
score/include/rtems/score/states.h,
score/inline/rtems/score/coresem.inl: Add SuperCore Barriers,
SpinLocks and a partial implementation of RWLocks.
* score/include/rtems/score/corebarrier.h,
score/include/rtems/score/corerwlock.h,
score/include/rtems/score/corespinlock.h,
score/inline/rtems/score/corebarrier.inl,
score/inline/rtems/score/corerwlock.inl,
score/inline/rtems/score/corespinlock.inl,
score/macros/rtems/score/corespinlock.inl, score/src/corebarrier.c,
score/src/corebarrierrelease.c, score/src/corebarrierwait.c,
score/src/corespinlock.c, score/src/corespinlockrelease.c,
score/src/corespinlockwait.c: New files.
* libmisc/cpuuse/cpuuse.c, libmisc/cpuuse/cpuuse.h: Promote CPU Usage
to first class citizen. Rename to start with rtems_ and include
documentation in user guide.
* libnetworking/rtems/rtems_malloc_mbuf.c: Removed warning by adding
prototype of malloc.
* libmisc/stackchk/check.c, libmisc/stackchk/internal.h,
libmisc/stackchk/stackchk.h: Move stack to first class citizen
status. Include it in User Manual and rename to start with rtems_.
