The IO library used a POSIX key to store an optional POSIX user
environment pointer. This pulled in the POSIX keys support in every
application configuration. Add a user environment pointer to the thread
control block (TCB) instead. Applications which do not need the POSIX
user environment will just get an overhead of one pointer per thread.
Close #3882.
Move the is SMP enabled configuration constant out of the
configuration table.
Since this was the last configuration constant in
rtems_configuration_table, remove this type.
Update #3875.
Move the processor maximum configuration constant out of the
Update #3875.
Move the unified workspace configuration constant out of the
Provide a default definition of the unified workspace constant.
Update #3875.
Move the workspace size configuration constant out of the configuration
table.
Update #3875.
Move the idle thread body configuration constant out of the
Provide a default definition of the idle thread body constant.
Update #3875.
Move the idle thread stack size configuration constant out of the
Add THREAD_IDLE_STACK_SIZE_DEFAULT and use it to provide a default
definition of the idle thread stack size constant.
Update #3875.
Move the ticks per timeslice configuration constant out of the
Add WATCHDOG_TICKS_PER_TIMESLICE_DEFAULT and use it to provide a default
definition of the watchdog ticks per timeslice constant.
Update #3875.
Move the microseconds per tick configuration constant out of the
Add WATCHDOG_MICROSECONDS_PER_TICK_DEFAULT and use it to provide a
default definition of the watchdog ticks constants.
Update #3875.
The CONFIGURE_HAS_OWN_INIT_TASK_TABLE and
CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE are the last *_HAS_OWN_*
configuration options. These two options are probably unused, see also:
* https://lists.rtems.org/pipermail/users/2019-April/033129.html
* https://lists.rtems.org/pipermail/users/2019-April/033130.html
Removing them simplifies the configuration. If there is a real user need
which shows up after the removal, we can resurrect them on demand.
Using CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE would have required the
use of the undocumented CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME and
CONFIGURE_POSIX_INIT_THREAD_TABLE_SIZE configuration options.
Update #3874.
This improves API backward compatibility of RTEMS 5.1 to previous
versions.
Due to the system initialization order, the _Thread_Global_constructor
must be 0 in this function.
With the removal of the CONFIGURE_HAS_OWN_INIT_TASK_TABLE configuration
option at most one Classic API user initialization task can be
configured.
Provide an RTEMS API configuration table for backward compatibility.
Update #3873.
Using CONFIGURE_HAS_OWN_INIT_TASK_TABLE would have required the use of
the undocumented CONFIGURE_INIT_TASK_TABLE and
CONFIGURE_INIT_TASK_TABLE_SIZE configuration options.
Update #3873.
Update #3875.
This file contained duplicate prototypes for standard POSIX functions
declared in <time.h>.
The corresponding data structure not longer exists. This function was
not tested and documented.
Close #3871.
Remove DEBUG_WORKSPACE support. There are better ways to trace the
application. See Tracing chapter in the RTEMS User Manual.
Remove superfluous includes. Change format.
Without this change, rtems-libbsd does not compile. A macro turns
free into bsd_free.
Also the use of a standard library element as a program identifier
is a violation of a MISRA rule. Turns out that was a good rule. :)
Allocate new thread queue heads during objects information extend. This
removes an error case and the last dependency on the workspace in
_Thread_Initialize().
Update #3835.
Update #3835.
Update #3835.
Update #3835.
Update #3835.
Update #3835.
Return block index in _Objects_Extend_information(). This allows to
customize the objects information extend.
Update #3835.
This function is simple enough to be inlined.
Update #3835.
Split up the different objects free methods into separate functions.
This helps to avoid a dependency on the workspace in case no objects or
a static set of objects is configured.
Update #3835.
Split up the different objects allocation methods into separate
functions. This helps to avoid a dependency on the workspace in case no
objects or a static set of objects is configured.
Change license to BSD-2-Clause according to file histories.
Update #3053.
Update #3835.
This is a preparation to allow a customization of the objects
information extend.
Update #3835.
Place idle and MPCI stacks into extra linker sections. This can be
optionally used by applications to control the placement of the stacks.
Update #3835.
Move thread stack allocation to caller side of _Thread_Initialize().
Update #3835.
Update #3835.
Add the Thread_Configuration structure to reduce the parameter count of
_Thread_Initialize(). This makes it easier to add more parameters in
the future. It simplifies the code generation since most architectures
do not have that many registers available for function parameters.
Update #3835.
This allows the linker garbage collection to perform its work.
Update #3835.
Use the stack area to allocate the TLS area.
Update #3835.
Use the stack area to allocate the FP context. This considerably
simplifies the application configuration since the task count no longer
influences the configured work space size. With this change the stack
space size is overestimated since an FP context for each thread is
accounted. Memory constraint applications can use the stack size for
fine tuning.
Update #3835.
This call is superfluous since _Thread_Initialize() will do this also.
Update #3835.
Update #3835.
Remove superfluous Thread_Control::Start::stack member.
Update #3835.
Update #3835.
Canonical input processing was broken by
667501a314ba75f80f1c13c6b43dd35d0a00efd1 as shown by test case
termios09.
Update #3800.
Replace the BSP_DIRTY_MEMORY BSP option with a CONFIGURE_DIRTY_MEMORY
configuration option.
Update #3843.
Use a dedicate system initialization step to zero the memory used for
the workspace and C program heap.
This avoids dead code in case CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY is
not configured.
Canonicalize CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY and use
defined/undefined instead of TRUE/FALSE.
Close #3862.
Update #3863.
Update #3865.
