* | minor changes to insure the few posix-ish routines needed in non-posix | Joel Sherrill | 1996-06-18 | 1 | -6/+25 |
| | | | | mode have stubs. | ||||
* | initial modifications to support sigtimedwait. | Joel Sherrill | 1996-06-15 | 1 | -9/+30 |
* | fields for init threads stuff said tasks. | Joel Sherrill | 1996-06-14 | 2 | -6/+6 |
* | sigtimedwait passes initial test cases of timeout and simple satisfaction. | Mark Johannes | 1996-06-13 | 1 | -1/+5 |
* | added maximum_queued_signals to _POSIX_Default_configuration | Mark Johannes | 1996-06-13 | 1 | -0/+1 |
* | added posix configuration parameter maximum_queued_signals. | Joel Sherrill | 1996-06-13 | 1 | -0/+5 |
* | now passing maximum_queued_signals to posix signals manager initialization | Joel Sherrill | 1996-06-13 | 1 | -1/+3 |
* | added queued signals and cleaned up setting of process wide signals so | Joel Sherrill | 1996-06-13 | 1 | -68/+148 |
| | | | | it occurs in only one place. | ||||
* | config.h: added maximum_queued_signals. | Joel Sherrill | 1996-06-13 | 2 | -1/+4 |
| | | | | psignal.h: fixed typo. | ||||
* | Added code so post context switch extensions can be run on every context | Joel Sherrill | 1996-06-13 | 2 | -2/+12 |
| | | | | switch. This was needed to support process wide signals. | ||||
* | Added include so _POSIX_signals_Manager_initialization is prototyped. | Joel Sherrill | 1996-06-13 | 1 | -0/+1 |
* | basic test cases for kill() and alarm(). | Joel Sherrill | 1996-06-13 | 2 | -11/+63 |
| | | | | | kill() in particular needs more test cases for full coverage. The search for a thread interested in this signal has a lot of paths. | ||||
* | added prototype for manager initialization routine. | Joel Sherrill | 1996-06-13 | 1 | -0/+2 |
* | use exit() from newlib by default. | Joel Sherrill | 1996-06-12 | 1 | -8/+8 |
* | added initialization of posix signal manager. | Joel Sherrill | 1996-06-12 | 1 | -0/+2 |
* | basic kill() which send a signal to pthread_self() appears to work. | Joel Sherrill | 1996-06-12 | 1 | -7/+18 |
* | added waiting for signal state. | Joel Sherrill | 1996-06-12 | 1 | -19/+21 |
* | initial implementation of blocking signal routines -- sigwait, sigwaitinfo, | Joel Sherrill | 1996-06-12 | 1 | -34/+227 |
| | | | | sigtimedwait, sigsuspend, and pause. | ||||
* | added comment to make sure we add unblock of thread | Joel Sherrill | 1996-06-11 | 1 | -0/+2 |
* | first attempt at adding algorithm to select the thread which will | Joel Sherrill | 1996-06-11 | 2 | -23/+255 |
| | | | | receive a process-directed signal. | ||||
* | deleted field for signals_global_pending. | Joel Sherrill | 1996-06-11 | 1 | -1/+0 |
* | tested blocking a signal, sending it to self, then unblocking it. | Joel Sherrill | 1996-06-11 | 2 | -32/+61 |
| | | | | | make minimum stack size for posix threads double that of the cpu's minimum requirement. | ||||
* | Interruptible by signals state was added to the STATES_BLOCKED set. It | Joel Sherrill | 1996-06-11 | 1 | -2/+3 |
| | | | | | can not be part of the locally blocked set since it by itself does not indicate that the thread is blocked. | ||||
* | Basic signal functionality appears to work. pthread_kill() can successfully | Joel Sherrill | 1996-06-11 | 3 | -9/+31 |
| | | | | | | | send signals to the current thread or to another blocked thread. nanosleep() can be interrupted by a signal and return the time remaining. Post switch extension added to dispatch posix signal handlers. | ||||
* | new file. | Joel Sherrill | 1996-06-11 | 1 | -1/+1 |
* | added psignal.h | Joel Sherrill | 1996-06-10 | 1 | -0/+13 |
* | added code to _Thread_Clear_state to check if the state was not currently set. | Joel Sherrill | 1996-06-10 | 1 | -13/+19 |
* | first attempt at the routine which vectors signals. | Joel Sherrill | 1996-06-10 | 2 | -12/+328 |
* | *** empty log message *** | Joel Sherrill | 1996-06-10 | 1 | -1/+1 |
* | added states for "join at exit" and "interruptible by signal" | Joel Sherrill | 1996-06-07 | 1 | -3/+6 |
* | changed code which set errno and then returned -1 to use the macro | Joel Sherrill | 1996-06-07 | 5 | -56/+32 |
| | | | | set_errno_and_return_minus_one. | ||||
* | key destructor is now run at correct point in pthread_exit() sequence and | Joel Sherrill | 1996-06-07 | 3 | -104/+173 |
| | | | | | | | | should be correct for other apis as well. missing page numbers added on some references. initial attempt at sig_procmask() and pthread_sigmask(). | ||||
* | in newlib now | Joel Sherrill | 1996-06-06 | 1 | -0/+4 |
* | Removed assert's from routines which return the error ENOSYS. | Joel Sherrill | 1996-06-06 | 1 | -12/+0 |
* | patch from Tony Bennett on the ifdef for O_NDELAY | Joel Sherrill | 1996-06-06 | 1 | -7/+8 |
* | process oriented scheduler routines now return ENOSYS | Joel Sherrill | 1996-06-06 | 1 | -4/+8 |
* | removed timer_getoverrun() since it was also in ptimer.c | Joel Sherrill | 1996-06-06 | 1 | -11/+0 |
* | Made the implementation of pthread_equal conditional on RTEMS_DEBUG. If | Joel Sherrill | 1996-06-06 | 1 | -0/+10 |
| | | | | | RTEMS is built for debug, then every possible effort is made to validate the two ids. Otherwise, a simple comparison is performed. | ||||
* | completed pthread_setschedparam. | Joel Sherrill | 1996-06-06 | 1 | -73/+130 |
* | Added Sporadic Server support to posix threads which required changes | Joel Sherrill | 1996-06-06 | 3 | -31/+67 |
| | | | | | in the core to support multiple algorithms to handle cpu time budgetting which resulted in a change to the calling sequence of _Thread_Initialize. | ||||
* | Added Sporadic Server support to posix threads which required changes | Joel Sherrill | 1996-06-06 | 2 | -35/+65 |
| | | | | | | | in the core to support multiple algorithms to handle cpu time budgetting which resulted in a change to the calling sequence of _Thread_Initialize. Makde _Context_Switch_necessary volatile. | ||||
* | added Sporadic Server support | Joel Sherrill | 1996-06-06 | 1 | -27/+109 |
* | added Sporadic_timer field to support sporadic server | Joel Sherrill | 1996-06-06 | 1 | -0/+1 |
* | added cpu_time_budget field to Thread_Control and removed the global variable | Joel Sherrill | 1996-06-05 | 2 | -6/+5 |
| | | | | _Thread_Ticks_remaining_in_timeslice. | ||||
* | fixed spacing | Joel Sherrill | 1996-06-05 | 1 | -1/+1 |
* | added support for the api providing the thread stack area | Joel Sherrill | 1996-06-05 | 1 | -23/+33 |
* | added boolean to indicate whether or not the stack area was provided | Joel Sherrill | 1996-06-05 | 1 | -0/+1 |
| | | | | by the api. | ||||
* | renamed Schedule to schedparam in the posix api control information. | Joel Sherrill | 1996-06-05 | 1 | -11/+22 |
| | | | | reviewed the interpretation of most of the thread attributes. | ||||
* | added comments to to document the definition of posix priority | Joel Sherrill | 1996-06-05 | 1 | -0/+8 |
| | | | | and how it corresponds to rtems core priority. | ||||
* | added comments to priority.h to document the definition of posix priority | Joel Sherrill | 1996-06-05 | 2 | -2/+6 |
| | | | | | | and how it corresponds to rtems core priority. Schedule was renamed schedparam |
