* configure.ac: Remove (Merged into ../configure.ac).
* Makefile.am: Reflect having merged configure.ac into
../configure.ac.
PR 417/rtems
* src/coresemsurrender.c: Correct incorrect check for maximum_count
reported by Sergei Organov <osv@topconrd.ru>.
* configure.ac: Remove RTEMS_BSP from RTEMS_CHECK_MULTIPROCESSING.
* aclocal/version.m4: Updated to rtems-ss-20030703.
rtems_termios_bufsize call.
* src/threadloadenv.c: Removed warnings.
* pppd/chat.c: Removed warnings.
* src/objectmp.c: Removed warnings.
* include/rtems/rtems/msgmp.h, include/rtems/rtems/partmp.h,
include/rtems/rtems/regionmp.h, include/rtems/rtems/semmp.h,
src/msgmp.c, src/partmp.c, src/regionmp.c, src/semmp.c: Removed
warnings.
PR 411/filesystem
* src/imfs/imfs_unlink.c: Fix bug where renaming a memfile and
then unlinking it causes a memory leak.
* stackchk/check.c: Removed warnings.
* src/ide_part_table.c: Removed warnings.
* rtems/rtems_syscall.c: Removed warnings.
* pppd/fsm.c: Make peer_mru global again.
PR 409:
* include/stdint.h: Include rtems/stdint.h
PR 409:
* include/rtems/rtems/types.h: Include rtems/stdint.h.
Apply c99-types to typedef rtems_[un]signed[8|16|32|64].
PR 409:
* include/Makefile.am: Add rtems/stdint.h
* include/rtems/stdint.h: New.
PR 321:
* aclocal/env-rtemscpu.m4: Remove support for profile-variant.
* automake/compile.am: Ditto.
* automake/local.am: Ditto.
PR 399/rtems_misc
* src/termios.c: In canonical mode, when input is present in the
input buffer that contains an EOL character and some following
characters, a read call read data behind the EOL character, although
it should stop reading with the EOL character.
* pppd/magic.c: Remove *rand48.
* pppd/chap.c: Remove prototypes of *rand48.
* automake/compile.am: Remove LIBSUFFIX_VA (unused).
* aclocal/env-rtemscpu.m4: Merge-in env-rtemsbsp.m4.
* aclocal/env-rtemsbsp.m4: Remove.
* aclocal/enable-rtemsbsp.m4: Remove.
2003-05-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* aclocal/env-rtemscpu.m4: Remove stray '/' in setting up
project_libdir.
* aclocal/version.m4: Updated to rtems-ss-20030417.
PR 389/rtems
* src/no_posix.c: Correct _kill_r() prototype and make it conditional
on newlib.
PR 385/filesystem
* src/ramdisk.c: The "from" and "to" locations are calculated as
the start of the block within the ram that data is to be transferred
from/to for reads and writes respectively. However, within
the loops, the "from" and "to" locations are never updated. The loop
should have been updated as:
from += rd->block_size;
and
to += rd->block_size;
within the for loops in the ramdisk_read and ramdisk_write routines,
respectively.
PR 388/networking
* kern/kern_sysctl.c: Revert previous patch and use strlcpy() now that
it is available. Also fixed some warnings.
* aclocal/version.m4: Updated to rtems-ss-20030411.
* aclocal/version.m4: Updated to rtems-ss-20020411.
* rtems_webserver/cgi.c, rtems_webserver/sockGen.c,
rtems_webserver/umui.c, rtems_webserver/websSSL.c,
rtems_webserver/websSSL.h, rtems_webserver/websda.c,
rtems_webserver/websda.h: New files. Not included in previous commit.
* rtems_webserver/NOTES, rtems_webserver/asp.c,
rtems_webserver/balloc.c, rtems_webserver/default.c,
rtems_webserver/ej.h, rtems_webserver/ejIntrn.h,
rtems_webserver/ejlex.c, rtems_webserver/ejparse.c,
rtems_webserver/emfdb.c, rtems_webserver/emfdb.h,
rtems_webserver/form.c, rtems_webserver/h.c,
rtems_webserver/handler.c, rtems_webserver/license.txt,
rtems_webserver/md5.h, rtems_webserver/md5c.c,
rtems_webserver/mime.c, rtems_webserver/misc.c,
rtems_webserver/ringq.c, rtems_webserver/rom.c,
rtems_webserver/security.c, rtems_webserver/sock.c,
rtems_webserver/sym.c, rtems_webserver/uemf.c,
rtems_webserver/uemf.h, rtems_webserver/um.c, rtems_webserver/um.h,
rtems_webserver/url.c, rtems_webserver/value.c,
rtems_webserver/wbase64.c, rtems_webserver/webcomp.c,
rtems_webserver/webpage.c, rtems_webserver/webrom.c,
rtems_webserver/webs.c, rtems_webserver/webs.h,
rtems_webserver/websuemf.c, rtems_webserver/wsIntrn.h:
Update to GoAhead Webserver 2.1.4. The following URL is
the release notes from GoAhead.
http://data.goahead.com/Software/Webserver/2.1.4/release.htm
I have only done a minimal amount of testing (i.e. the network
demo program works fine). Please try this out and let me know
if it works. The patch needs to be applied on the
c/src/libnetworking/rtems_webserver directory.
PR 371/pppd
* pppd/auth.c, pppd/chat.c, pppd/demand.c, pppd/fsm.c, pppd/lcp.c,
pppd/options.c, pppd/pppd.h, pppd/rtemsmain.c, pppd/rtemspppd.c:
Change many symbols to static. There are still global symbols in
rtemspppd.h which might need to be changed or converted into member
of a structure which is dereferenced with a pointer that is managed
as a per task variable. But this patch should avoid many conflicts.
PR 381/core
* src/newlibc.c: Switch from using _REENT_INIT to _REEINT_INIT_PTR
to fix strange run-time problem where EIP was corrupted on pc386 BSP.
* ChangeLog, Makefile.am: ATA code depends upon libchip/ide which is
not allowed in the cpukit source code since it must be buildable
independent of any BSP. These files were moved to libchip/ide.
* include/rtems/ata.h, include/rtems/ata_internal.h: Removed.
* kern/kern_sysctl.c: Converted from BSP strlcpy() to strncpy().
* rtems/rtems_bsdnet_malloc_starvation.c: Fixed name of include file.
PR 374/networking
* Makefile.am, rtems/rtems_bsdnet.h, rtems/rtems_glue.c:
The patch sent as part of PR270 got applied to the wrong place.
The effect was that (1) startup was no faster than before and
(2) malloc starvation messages came way too quickly. The attached
patch fixes both these problems and also provides a mechanism for
applications to handle malloc starvation conditions as they see fit.
* rtems/rtems_bsdnet_malloc_starvation.c: New file.
PR 367/filesystem
* Makefile.am, include/rtems/ide_part_table.h, src/ata.c,
src/ide_part_table.c: Some bugs were still present in the DOSFS
implementation:
- FAT12 did not work properly on Big-Endian machines
- Some synchronization and error handling problems were present
- Some legal codings for EOC were not recognized
PR 367/filesystem
* src/dosfs/Makefile.am, src/dosfs/fat.c, src/dosfs/fat.h,
src/dosfs/fat_fat_operations.c, src/dosfs/fat_file.c,
src/dosfs/msdos.h, src/dosfs/msdos_dir.c: Some bugs were still
present in the DOSFS implementation:
PR 356/bsps
* sys/linker_set.h: This patch makes RTEMS/PowerPC eabi compliant.
Declare all linker-script defined addresses as
variables of unknown size and not as short objects
like 'int', 'void*' etc. Since only addresses are used and never those
variable's values, the type used in a declaration is not important.
