* | libfs: Doxygen Enhancement Task #2 | Alex Ivanov | 2012-12-18 | 23 | -152/+257 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/8032207 | ||||
* | posix: Doxygen Enhancement Task #11 | Ayush Awasthi | 2012-12-18 | 20 | -0/+140 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/7987221 | ||||
* | posix: Doxygen Enhancement Task #12 | Ayush Awasthi | 2012-12-18 | 4 | -0/+28 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/8003214 | ||||
* | PR2083 Wrong return value in _RBTree_Has_only_one_node | Andreas Heinig | 2012-12-18 | 1 | -1/+1 |
| | | | | | | The function _RBTree_Has_only_one_node shall return a boolean value, but returns NULL. NULL, however, is defined as: (void *)0. Hence it does not match the scalar bool type. Return false instead. | ||||
* | libnetworking: Make functions public | Sebastian Huber | 2012-12-18 | 2 | -2/+4 |
| | | | | | Make functions rtems_bsdnet_semaphore_obtain_recursive() and rtems_bsdnet_semaphore_release_recursive() public. | ||||
* | shell: Remove interface down warning in ifconfig | Sebastian Huber | 2012-12-18 | 1 | -4/+0 |
| | | | | | Whether an interface down is supported or not depends on the interface driver. | ||||
* | posix: Doxygen Enhancement Task #7 | Mathew Kallada | 2012-12-16 | 22 | -30/+148 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/7958218 | ||||
* | posix: Doxygen Enhancement Task #2 | Alex Ivanov | 2012-12-15 | 25 | -159/+225 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/7988213 | ||||
* | posix: Doxygen Enhancement Task #8 | Mathew Kallada | 2012-12-15 | 23 | -57/+182 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/8003213 | ||||
* | posix: Doxygen Enhancement Task #5 | Alex Ivanov | 2012-12-15 | 27 | -136/+229 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/7959229 | ||||
* | libcsupport: Update file header for termios.h to remove link, add description. | Gedare Bloom | 2012-12-15 | 1 | -1/+3 |
* | posix: Doxygen Enhancement Task #1 | Alex Ivanov | 2012-12-15 | 26 | -144/+256 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/7987220 | ||||
* | libcsupport: Doxygen Enhancement Task #8 | Alex Ivanov | 2012-12-15 | 25 | -101/+210 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/7996208 | ||||
* | dosfs: Avoid error caused by bdbuf configuration | Sebastian Huber | 2012-12-14 | 1 | -10/+5 |
| | | | | | | The success of a block size change depends on the bdbuf configuration. Do not treat a failed block size change as a hard error. This is only a missed performance optimization. | ||||
* | Fix spelling | Sebastian Huber | 2012-12-14 | 5 | -36/+36 |
* | Filesystem: Revert documentation changes | Sebastian Huber | 2012-12-14 | 2 | -39/+39 |
* | posix: Doxygen enhancement task #4 | Mathew Kallada | 2012-12-13 | 27 | -33/+216 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/7955219 | ||||
* | libcsupport: Doxygen enhancement task #9 | Alex Ivanov | 2012-12-13 | 17 | -74/+160 |
* | termios: Fix output flush | Sebastian Huber | 2012-12-13 | 1 | -0/+1 |
* | libcsupport: Revert termios Doxygen. Add file header. | Gedare Bloom | 2012-12-13 | 1 | -32/+3 |
* | dosfs: Add sync_device option for msdos_format() | Sebastian Huber | 2012-12-13 | 2 | -0/+10 |
* | dosfs: Fix error status handling | Sebastian Huber | 2012-12-13 | 1 | -16/+18 |
* | dosfs: Bugfix for disks of for example 100MB size | Ralf Kirchner | 2012-12-13 | 1 | -49/+101 |
* | dosfs: Whitespace change | Ralf Kirchner | 2012-12-13 | 1 | -1/+0 |
* | dosfs: Fix request evaluation | Ralf Kirchner | 2012-12-13 | 1 | -4/+0 |
| | | | | | Return the ability to set a cluster size other than one sector for unaligned volumes. | ||||
* | termios: Implement tcflush() | Sebastian Huber | 2012-12-13 | 3 | -30/+46 |
| | | | | New IO control RTEMS_IO_TCFLUSH. | ||||
* | termios: Fix tcflow() error status | Sebastian Huber | 2012-12-13 | 1 | -0/+1 |
* | libcsupport: Revert documentation changes | Sebastian Huber | 2012-12-13 | 2 | -10/+10 |
* | misc: Header File Doxygen Enhancement Task #3 | Mathew Kallada | 2012-12-12 | 20 | -109/+169 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/8006220 | ||||
* | cpukit/rtems: Header File Doxygen Enhancement GCI Task #8 | Mathew Kallada | 2012-12-12 | 15 | -18/+48 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/7948217 | ||||
* | libfs: Doxygen Enhancement GCI Task #7 | Mathew Kallada | 2012-12-11 | 9 | -3/+75 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/8006219 | ||||
* | libcsupport: Doxygen enhancement GCI task #6 | Alex Ivanov | 2012-12-11 | 22 | -58/+182 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/7992212 | ||||
* | libcsupport: Doxygen enhancement GCI task #4 | Alex Ivanov | 2012-12-11 | 26 | -116/+274 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/8009205 | ||||
* | libcsupport: GCI Doxygen Task #7 | Alex Ivanov | 2012-12-11 | 25 | -62/+198 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/7975223 | ||||
* | libcsupport: Doxygen enhancement task #5 | Alex Ivanov | 2012-12-10 | 25 | -54/+203 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/7992211 | ||||
* | libcsupport: Doxygen enhancement task #2 | Alex Ivanov | 2012-12-09 | 24 | -58/+209 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/8017203 | ||||
* | libcsupport: Fix documentation | Sebastian Huber | 2012-12-09 | 1 | -9/+11 |
* | Filesystem: Revert documentation change | Sebastian Huber | 2012-12-09 | 1 | -1/+0 |
* | rtems: Revert documentation change | Sebastian Huber | 2012-12-09 | 1 | -3/+0 |
* | sapi: Fix previous commit | Sebastian Huber | 2012-12-09 | 1 | -23/+1 |
* | sapi: Revert documentation change | Sebastian Huber | 2012-12-09 | 1 | -4/+8 |
* | libcsupport: Doxygen Enhancement Task #3 | Mathew Kallada | 2012-12-08 | 25 | -39/+225 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/7992210 | ||||
* | misc rtems: Clean up Doxygen GCI Task #8 | Mathew Kallada | 2012-12-08 | 30 | -129/+251 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/8024203 | ||||
* | score misc: Clean up Doxygen GCI Task #12 | Alex Ivanov | 2012-12-07 | 20 | -123/+120 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/7983217 | ||||
* | sapi misc: Clean up Doxygen GCI task #1 | Christopher Kerl | 2012-12-07 | 26 | -220/+271 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/8011204 | ||||
* | score: rtems_initialize_start_multitasking() | Sebastian Huber | 2012-12-07 | 2 | -9/+18 |
| | | | | | | | | | Do not return from rtems_initialize_start_multitasking() and call rtems_fatal() instead with a fatal source of RTEMS_FATAL_SOURCE_EXIT and a fatal code with the exit status. Remove all bsp_cleanup() functions. The boot_card() is now a no return function. | ||||
* | rtems misc: doxygen minor fixes | Gedare Bloom | 2012-12-06 | 1 | -3/+3 |
* | rtems misc: Clean up Doxygen GCI Task #5 | Mathew Kallada | 2012-12-05 | 30 | -96/+219 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/8015207 | ||||
* | rtems misc: Clean up Doxygen GCI Task #7 | Alex Ivanov | 2012-12-05 | 29 | -303/+247 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/7950206 | ||||
* | rtems misc: Clean up Doxygen GCI Task #6 | Alex Ivanov | 2012-12-05 | 27 | -325/+252 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/8019205 |
