* | Corrected spacing. | Joel Sherrill | 1999-11-02 | 1 | -2/+2 |
* | Added message queues and semaphores. | Joel Sherrill | 1999-11-02 | 1 | -0/+11 |
* | Added CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES and | Joel Sherrill | 1999-11-02 | 1 | -0/+24 |
| | | | | CONFIGURE_MAXIMUM_POSIX_SEMAPHORES. | ||||
* | Added comment to make sure Classic API priority to Core priority | Joel Sherrill | 1999-11-02 | 1 | -0/+1 |
| | | | | is added in the future. | ||||
* | Added comments for _RTEMS_tasks_Create_extension, | Joel Sherrill | 1999-11-02 | 1 | -4/+9 |
| | | | | | _RTEMS_tasks_Start_extension, _RTEMS_tasks_Delete_extension, and _RTEMS_tasks_Switch_extension. | ||||
* | Added a case to support the core semaphore error returned when the | Joel Sherrill | 1999-11-02 | 1 | -0/+8 |
| | | | | maximum semaphore count is exceeded. | ||||
* | Added code to utilize the maximum_count attribute of core semaphores | Joel Sherrill | 1999-11-02 | 1 | -0/+7 |
| | | | | | and initialize it to a value that would keep it from every being a problem. | ||||
* | Now much closer to working. | Joel Sherrill | 1999-11-02 | 1 | -7/+61 |
* | Added assert in case _Objects_Get_information fails since this | Joel Sherrill | 1999-11-02 | 1 | -0/+4 |
| | | | | should NEVER occur. | ||||
* | Commented out lines causing warning. | Joel Sherrill | 1999-11-02 | 1 | -0/+2 |
* | Added #define for SEM_FAILED. | Joel Sherrill | 1999-11-02 | 1 | -0/+2 |
* | Added include of <sys/siginfo.h>. | Joel Sherrill | 1999-11-02 | 1 | -0/+2 |
* | Added message queues and semaphores. | Joel Sherrill | 1999-11-02 | 1 | -1/+3 |
* | Enabled configuring mini or full IMFS. | Joel Sherrill | 1999-11-01 | 1 | -0/+29 |
* | Added name to id support routine. | Joel Sherrill | 1999-11-01 | 1 | -0/+15 |
* | Removed routines that had already been separated into their own files. | Joel Sherrill | 1999-11-01 | 1 | -505/+0 |
* | Moved the rmnod callback from the operations table to the handler table. | Jennifer Averett | 1999-10-29 | 6 | -11/+21 |
* | Joel added a table of mount entry requests to be processed during | Jennifer Averett | 1999-10-29 | 1 | -0/+14 |
| | | | | initialization. | ||||
* | Patch rtems-rc-19991011-3.diff from Ralf Corsepius. | Joel Sherrill | 1999-10-28 | 1 | -25/+0 |
* | Added include of <sys/select.h> in attempt to remove compilation warning. | Joel Sherrill | 1999-10-28 | 1 | -0/+4 |
* | Added use of __rtems__ rather than LINUX for RTEMS configuration. | Joel Sherrill | 1999-10-28 | 3 | -7/+7 |
* | Modified to properly descend into the dummy directory. | Joel Sherrill | 1999-10-27 | 1 | -1/+1 |
* | New files from Ralf Corsepius <corsepiu@faw.uni-ulm.de> which | Joel Sherrill | 1999-10-27 | 2 | -0/+59 |
| | | | | | | | | are a dummy for linking programs together when you are primarily concerned with tricking another package into building. This may grow into something which could help link programs on the command line by having a default start sequence. | ||||
* | rxgen960 now compiles -- may not link. | Joel Sherrill | 1999-10-27 | 1 | -3/+3 |
* | The rxgen960 BSP and i960 RPM support was submitted by Mark Bronson | Joel Sherrill | 1999-10-27 | 3 | -43/+245 |
| | | | | <mark@ramix.com> of RAMIX. | ||||
* | Warnings removed. Still don't know what to do about the pragma | Joel Sherrill | 1999-10-27 | 3 | -10/+16 |
| | | | | pack warnings in uemf.h. | ||||
* | Patch from Emmanuel Raguet <raguet@crf.canon.fr> and Eric Valette | Joel Sherrill | 1999-10-27 | 32 | -1/+12126 |
| | | | | | | | | | | <valette@crf.canon.fr> to add a port of the GoAhead web server (httpd) to the RTEMS build tree. They have successfully used this BSP on i386/pc386 and PowerPC/mcp750. Mark and Joel spoke with Nick Berliner <nickb@goahead.com> on 26 Oct 1999 about this port and got verbal approval to include it in RTEMS distributions. | ||||
* | New files created by split of old imfs_handlers.c. | Joel Sherrill | 1999-10-26 | 3 | -0/+111 |
* | Added include of libio.h so this would compile when posix is disabled. | Joel Sherrill | 1999-10-26 | 1 | -0/+1 |
* | Added initial cut at miniIMFS which leaves out memfile and directory | Joel Sherrill | 1999-10-26 | 10 | -252/+227 |
| | | | | | readdir support. The next step is to add a mount table and configure either the miniIMFS or the full IMFS at the application level. | ||||
* | Patch from Gerwin Pfab <pb@schenk.isar.de> to leave dispatching | Joel Sherrill | 1999-10-26 | 1 | -3/+4 |
| | | | | | disabled on exit to ISR Thread dispatching. This allows a context switch to finish under high high interrupt rates. | ||||
* | idir=/opt/tmp/opt/rtems | Joel Sherrill | 1999-10-26 | 1 | -5/+1 |
| | | | | | | | | | | | | rdir=/opt/rtems cd $idir find . -type f | while read file do if [ ! -f ${file} ] ; then echo ${file} missing fi done | ||||
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to move | Joel Sherrill | 1999-10-26 | 2 | -3/+3 |
| | | | | c/src/lib/libmisc to c/src/libmisc. | ||||
* | Patch from Eric Norum <eric@cls.usask.ca> to address the following problem | Joel Sherrill | 1999-10-25 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | report from Philip A. Prindeville <philipp@zembu.com>: I was working on a device driver for a certain ethernet chipset that occassionally wraps in its buffer, and causes a resulting mbuf chain with only a few dozen bytes in the first mbuf of the chain. I wouldn't have thought this would be a problem, until I ran some stress tests that flooded the ethernet receiver with packets and started to get panics here: 250 251 if (m->m_pkthdr.len < sizeof(struct ip)) 252 goto tooshort; 253 254 #ifdef DIAGNOSTIC 255 if (m->m_len < sizeof(struct ip)) 256 panic("ipintr mbuf too short"); 257 #endif 258 259 if (m->m_len < sizeof (struct ip) && 260 (m = m_pullup(m, sizeof (struct ip))) == 0) { 261 ipstat.ips_toosmall++; 262 return; 263 } 264 ip = mtod(m, struct ip *); and the panic was at line 256. But if I #undef'd DIAGNOSTICS, then the m_pullup() at line 260 does the right thing and the packet ends up being processed just fine. So I started wondering, (a) why was the test checking for something that apparently wasn't a fatal condition but rather one that is subsequently recovered from a couple of lines later and (b) why panic as a diagnostic "aid" from a recoverable condition rather than just (say) log a message to the console? All of this seems overly severe for no reason that is readily apparent to me. | ||||
* | Patch from Charles-Antoine Gauthier <charles.gauthier@iit.nrc.ca> | Joel Sherrill | 1999-10-25 | 1 | -0/+8 |
| | | | | | to initialize the pthread cancellation fields. This is a patch to _POSIX_Threads_Create_extension that fixes the problem. | ||||
* | Patch from Eric Valette <valette@crf.canon.fr> and Emmanuel Raguet | Joel Sherrill | 1999-10-25 | 1 | -7/+8 |
| | | | | <raguet@crf.canon.fr> to use a local variable. | ||||
* | Added code to correctly free any allocated space during the evaluation | Jennifer Averett | 1999-10-25 | 2 | -72/+74 |
| | | | | process. | ||||
* | Changed leading spaces to periods to ease comparing test output. | Joel Sherrill | 1999-10-25 | 1 | -1/+1 |
* | Removed warning. | Joel Sherrill | 1999-10-21 | 1 | -0/+2 |
* | Added rtems_semaphore_flush directive. | Joel Sherrill | 1999-10-21 | 2 | -0/+104 |
* | Renamed CONFIGURE_POSIX_INIT_TASK_STACK_SIZE to | Joel Sherrill | 1999-10-21 | 1 | -6/+6 |
| | | | | CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE because in POSIX they are threads. | ||||
* | Fixed core dump caused when output parameter (otimer) was NULL. | Joel Sherrill | 1999-10-21 | 1 | -3/+7 |
* | Added Semaphore_Flush. | Joel Sherrill | 1999-10-21 | 2 | -0/+18 |
* | Added prototype for rtems_task_is_suspended at request of | Joel Sherrill | 1999-10-20 | 1 | -1/+12 |
| | | | | Eric Norum. | ||||
* | Spacing. | Joel Sherrill | 1999-10-12 | 1 | -0/+1 |
* | Split null handlers table to own file and renamed. | Joel Sherrill | 1999-10-12 | 7 | -75/+16 |
| | | | | Renamed IMFS handler tables to include IMFS prefix. | ||||
* | Added rtems_filesystem_freenode() macro and added calls at appropriate | Joel Sherrill | 1999-10-12 | 17 | -92/+69 |
| | | | | | places to make sure memory allocated for filesystem specifif nodes gets freed. | ||||
* | Fixed spacing. | Joel Sherrill | 1999-10-12 | 1 | -1/+1 |
* | Corrected mistakes in the IMFS file handlers table and added the missing | Joel Sherrill | 1999-10-12 | 3 | -0/+127 |
| | | | | routine imfs_fcntl.c | ||||
* | Added call to freenod to let each filesystem free its own internal | Joel Sherrill | 1999-10-12 | 15 | -68/+227 |
| | | | | node used to manage file access. |
