path: root/cpukit (follow)
* Now accounts for region used by RTEMS malloc and extension usedJoel Sherrill1998-04-141-4/+16
| | | | by newlib.
* Increased stack space of the monitor task.Joel Sherrill1998-04-061-1/+1
* More stuff removed as a result of using newlib's isatty() implementation.Joel Sherrill1998-04-061-11/+0
| | | | These were noticed by Eric Norum.
* Removed isatty() since we are now using newlib's implementation asJoel Sherrill1998-04-031-1/+0
| | | | a result of enabling the newlib POSIX directory.
* Made these have real constants.Joel Sherrill1998-04-031-6/+6
* Added "sigemptyset()" call to insure that the memcmp() would work.Joel Sherrill1998-03-311-0/+4
| | | | | It appears that the new glibc does not clear all the bits of the signal set with a sigprocmask.
* Changed int to unsigned32 to match cpu.h.Joel Sherrill1998-03-271-1/+1
* Should have included <rtems.h> before checking for ifdef RTEMS_UNIX.Joel Sherrill1998-03-271-2/+2
| | | | Bug report from Olivier Hainque <hainque@inf.enst.fr> on SPARC Solaris 2.6.
* m68k software interrupt stack support from Chris Johns and Eric Norum.Joel Sherrill1998-03-251-4/+0
* Added _XOPEN_SOURCE definition to allow use of UNIX IPC.Joel Sherrill1998-03-241-0/+1
* Real definition for the beginning of the data section per Eric Norum'sJoel Sherrill1998-03-242-4/+4
| | | | suggestion.
* Rename hppa1_1 to hppa1.1 and switched to using __XXX__ macros forJoel Sherrill1998-03-241-4/+4
| | | | the CPU family name constants.
* SH port submitted from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill1998-03-203-0/+506
* Modified to make it possible for an ISR to return a mutex which didJoel Sherrill1998-02-201-2/+20
| | | | not use priority ceiling or priority inheritance protocols.
* Added misisng line continuation.Joel Sherrill1998-02-201-1/+1
* Accounted for fixed system overhead.Joel Sherrill1998-02-191-2/+10
* Ralf Corsepius noted that there was a dead path in _Thread_Initialize.Joel Sherrill1998-02-181-6/+2
* updated copyright to 1998Joel Sherrill1998-02-17246-247/+247
* Patch from Eric Norum <eric@skatter.usask.ca>:Joel Sherrill1998-02-171-2/+5
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | I've gone through and cleaned up the TFTP driver so that it fits into the libio system. Here's the comment from the new driver: /* * Usage: * * To open `/bootfiles/image' on `hostname' for reading: * fd = open ("/TFTP/hostname/bootfiles/image", O_RDONLY); * * The `hostname' can be a symbolic name or four * dot-separated decimal values. * * To open a file on the host which supplied the BOOTP * information just leave the `hostname' part empty: * fd = open ("/TFTP//bootfiles/image", O_RDONLY); * */ You can `fopen' TFTP files the same way: fp = fopen (fullname, "r"); nread = fread (cbuf, sizeof cbuf[0], sizeof cbuf, fp); The diff's are included below. I've also modified the TFTP demo program and the bootstrap PROM example. They should be on my ftp site `soon'. The one thing I don't like is the way I had to do an end-run on the libio routines to get errno passed back from my driver to the application (since there are some errno codes that don't map to RTEMS status codes). My approach was to set errno in the driver and have the driver routine return an RTEMS status code that I `know' isn't in the errno_assoc[] in libio.c. Perhaps there should be an RTEMS_TRANPARENT_ERRNO status code (or something similar) which driver routines could return to indicate that the driver routine has set errno and that the libio routines shouldn't attempt to map the returned status code to errno. Actually, I think the entire I/O system needs looking at -- as you've already mentioned. The hacks I've dropped in to syscalls.c to make fstat work, for example, are *not* shining examples of good code......
* Patch from Ralf Corsepius to reduce the amount of memory consumed byJoel Sherrill1998-02-041-2/+6
| | | | the workspace by default.
* Ralf Corsepius noticed that generally was spelled incorrectly.Joel Sherrill1998-02-041-1/+1
* Added call to libc_wrapup() in _exit. This fixes a problem whereJoel Sherrill1998-02-031-0/+1
| | | | | the atexit routines on the global reentrancy structure were not invoked. But it does not seem like a 100% correct solution.
* Corrected Linux port for glibc2Joel Sherrill1998-01-303-2/+5
* Change to remove warning on glibc2 systems per Ralf Corsepius'sJoel Sherrill1998-01-281-1/+6
| | | | suggestion.
* Solaris port updates from Chris JohnsJoel Sherrill1998-01-234-22/+14
* Removed warning per Chris Johns' suggestion.Joel Sherrill1998-01-202-2/+2
* Added _times_r.Joel Sherrill1998-01-191-0/+7
* Patch from Eric Norum:Joel Sherrill1998-01-191-0/+1
| | | | | With this in place, it is possible to fdopen a TCP stream socket and getc/fprintf/etc. on the STDIO stream!
* Ralf Corsepius reported a number of missing CVS Id's:Joel Sherrill1998-01-163-3/+3
| | | | | | | | | | > RTEMS is under CVS control and has been since rtems 3.1.16 which was > around May 1995. So I just to add the $Id$. If you notice other files > with missing $Id$'s let me know. I try to keep w\up with it. Now that you have asked -- I'll attach a list of files lacking an RCS-Id to this mail. This list has been generated by a little sh-script I'll also enclose.
* Jennifer found some uninitialized variables:Joel Sherrill1998-01-161-1/+7
| | | | | | + major and minor number elements in rtems_termios_open. + arg->ioctl_return in rtems_termios_ioctl routine.
* Error reported by Duncan Smith <dds@flavors.com>:Joel Sherrill1998-01-151-1/+1
| | | | | | | | | | | | | | | | | | | | | | >> >>There is a 30 day error in _TOD_Days_since_last_leap_year[2..3] >> > >> >Thanks. >> >What's the condition to hit this error? >> >Every year 4n+2 and 4n+3 ? >> >(i.e. 1998, 1999, 2002, 2003, ...) >> > >> OK: 96 97 00 01 04 05 ... >> Bad: 98 99 02 03 06 07 ... There is also a problem in newlib 1.7.x reported at the same time: >> I found another, that would strike only on 2/29/2000, or other leapyears. >> Only a problem on 1 day. >> >> Joel: FYI, there is a bug in Newlib localtime.c, localtime or (_tm_time). >> Ours is modified for dst and timezones, but the bug was in original source. >> I have not looked at the latest public source (nor do I know where to find >> it).
* Changed initial settings of first time.Joel Sherrill1998-01-061-3/+5
* Fixed spacing.Joel Sherrill1998-01-061-2/+2
* Added CONFIGURE_GNAT_KEYS to correct the number of keys configuredJoel Sherrill1997-12-231-12/+11
| | | | | | | | | for GNAT. It was the number of Ada tasks when in fact the run-time only required a single key. Also added the CONFIGURE_MAXIMUM_FAKE_ADA_TASKS constant to account for resources allocated for each non-Ada task/thread which invokes the Ada run-time implicitly through an Ada call.
* Corrected prototypes for all termios console write driver entries toJoel Sherrill1997-12-222-3/+4
| | | | properly reflect the const on the buffer pointer being passed in.
* Fixed indexing bug reported by Phil Wilshire.Joel Sherrill1997-12-071-1/+1
* Moved include of rtems/score/cpu.h to make sure TRUE and FALSE were defined.Joel Sherrill1997-12-061-2/+2
| | | | | This simple error resulted in the wrong FP context structure being used for hardware contexts on the m68k. This was a difficult problem to find.
* Inclusion of PC386 BSP submitted by Pedro Miguel Da Cruz Neto RomanoJoel Sherrill1997-12-011-0/+2
| | | | | <pmcnr@camoes.rnl.ist.utl.pt> and Jose Rufino <ruf@asterix.ist.utl.pt> of NavIST (http://pandora.ist.utl.pt/).
* Removed warnings.Joel Sherrill1997-11-292-1/+6
* Removed warning under linux port.Joel Sherrill1997-11-181-0/+5
* Added CONFIGURE_MEMORY_USER_OVERHEAD constant per Chris Johns request.Joel Sherrill1997-11-181-1/+6
* interrupt driven change from Eric NorumJoel Sherrill1997-11-152-83/+191
* Fixed prototypeJoel Sherrill1997-11-101-1/+1
* Set return code to avoid spurious errors.Joel Sherrill1997-11-101-0/+1
* added katsutoshi ShibuyaJoel Sherrill1997-10-241-1/+8
* Changed prototype of read routine.Joel Sherrill1997-10-232-14/+7
* Added prototype for console_reserve_resources.Joel Sherrill1997-10-231-0/+4
* fixed commentJoel Sherrill1997-10-231-2/+1
* New termios.c from Eric Norum.Joel Sherrill1997-10-232-601/+646
| | | | Added new entry point to add in per physical port resource requirements.
* Fixed a number of warnings regarding comparisons between signed andJoel Sherrill1997-10-214-9/+9
| | | | unsigned numbers.
