PR 1948/filesystem
* libfs/src/rfs/rtems-rfs-file-system.c,
libfs/src/rfs/rtems-rfs-file-system.h,
libfs/src/rfs/rtems-rfs-format.c, libfs/src/rfs/rtems-rfs-rtems.c:
Add support for mount passing an ASCIIZ string containing
configuration options. Remove the hardcoded dir string and
size. Fix comments.
* libblock/src/bdbuf.c: Fix state labels in trace output.
PR 1948/filesystem
size. Fix comments.
* libcsupport/src/newlibc_exit.c: Don't undef __USE_INIT_FINI__.
* libmisc/monitor/mon-monitor.c (rtems_monitor_wakeup):
Remove unused var "status" (Avoid warning).
* ftpd/ftpd.h, ftpd/ftpd.c: Moved buffer and stack size constants into
header file.
* ftpd/ftpd.c: Increased data buffer size to 4096 bytes. Use
RTEMS_MINIMUM_STACK_SIZE plus the data buffer size for worker thread
stack size.
* libfs/src/imfs/imfs.h: Add IMFS_memfile_maximum_size.
* rtems/Makefile.am: Add src/status.c.
* rtems/include/rtems/rtems/status.h: Make
_Status_Object_name_errors_to_status an external variable.
* rtems/src/status.c: New (split out from
rtems/include/rtems/rtems/status.h).
* rtems/Makefile.am: Reformat.
* configure.ac: Check for decls of utime and utimes.
PR 1942/cpukit:
* score/src/schedulercbsdetachthread.c: Move initialization of var
"sched_info" down (Avoid it being used uninitialized).
* libcsupport/src/utimes.c (utimes): Remove casts to time_t.
* nios2-mpu-configuration.c, nios2-mpu-descriptor.c,
nios2-mpu-disable-protected.c, nios2-mpu-reset.c: New files.
* rtems/score/nios2-utility.h, nios2-context-initialize.c: Added
support for the memory protection unit (MPU).
* automake/compile.am: Remove -Werror=...
* libnetworking/net/if_ethersubr.c (ether_output):
Remove unused vars "hlen", "off".
* score/include/rtems/score/rbtree.h (_RBTree_Container_of):
Use offsetof. Don't cast to size_t. Include <stddef.h>.
* libnetworking/libc/res_mkupdate.c (res_mkupdate):
Remove unused var "sp1".
* libfs/src/dosfs/msdos_file.c (msdos_file_datasync):
Remove unused var "rc".
* include/rtems/btimer.h: Introduce benchmark_timer_t.
Let benchmark_timer_read return benchmark_timer_t.
PR 1939/cpukit
* rtems/src/ratemonperiod.c: Fixed type mismatch.
* libcsupport/include/rtems/libio.h, libcsupport/src/termios.c:
Use size_t for sizes.
* libfs/src/pipe/fifo.c: Conditionally use var "sc".
* libmisc/shell/fts.c: Conditionally use var "nostat".
* pppd/options.c: Remove unused var "ok".
* libnetworking/rtems/rtems_dhcp.c: Remove unused var
"disconnected".
PR 1935/cpukit
* score/include/rtems/score/smplock.h, score/src/smplock.c: SMP nested
count variable was being overritten when nested lock was taken more
than once.
PR 1938/cpukit
* score/include/rtems/score/thread.h: Removed obsolete suspend_count
field from Thread_Control.
* libfs/src/rfs/rtems-rfs-file-system.c (rtems_rfs_fs_open):
Comment out unused vars "group", "group_base".
* libmisc/monitor/mon-editor.c (rtems_monitor_task):
Comment out unused vars "debugee", "rp", "fp".
* posix/src/alarm.c: Make _POSIX_signals_Alarm_TSR static.
Remove unused var "status".
* libmisc/shell/main_ls.c: Comment out unused var kflag.
* posix/src/ualarm.c: Make _POSIX_signals_Ualarm_TSR static.
* libmisc/mouse/serial_mouse.c (serial_mouse_initialize):
Remove unused var "status" (Avoid warnings).
* libcsupport/src/termios.c,
libcsupport/include/rtems/termiostypes.h (rtems_termios_puts):
Use size_t for buffer size.
* libfs/src/devfs/devfs_mknod.c: Remove const cast.
* libfs/src/imfs/ioman.c: Remove const cast.
* libfs/src/devfs/devfs.h: Make device_name a const char*.
* sapi/include/rtems/io.h: Make device_name a const char*.
* libcsupport/src/termios.c: Remove meaningless typecast.
* libmisc/serdbg/serdbg.h (putDebugChar, getDebugChar):
Remove duplicate decls.
PR 1932/cpukit
* cpu_asm.S: At some point the interrupt trap handler causes a
window-overflow and the window overflow trap handler crashes when
writing to 0. I found that this is because the WIM was bad, to the
window overflow handler uses a uninitialized stack pointer in a
window never used.
* g3=CWP, not WIM
* CWP is incremented by done_flushing no need doing that here also
* I see no reason to create an additional stack frame (save)
* Must turn off traps when updating WIM (maybe already done by caller?)
PR 1931/cpukit
* score/src/percpu.c: The stack must be aligned to CPU alignment
requirement.
* score/src/threadhandler.c: Don't undefine __USE_INIT_FINI__ for
the avr.
* libfs/src/imfs/memfile.c (memfile_ioctl): Remove unused var
"the_jnode".
PR 1918/cpukit
* cpu.c: Initialize context with cleared g4 register.
PR 1922
* score/include/rtems/score/schedulercbs.h, score/src/schedulercbs.c:
EDF and CBS scheduler: extern declarations fix.
* score/src/scheduleredfupdate.c: Remove unused var "the_node".
* libmisc/uuid/gen_uuid.c: Introduce PRIutime_t, SCNutime_t and
"utime_t" for 64bit-time_t support.
* libmisc/shell/main_time.c: Introduce PRIutime_t, SCNutime_t and
* libmisc/shell/main_time.c: Introduce PRIdtime_t.
* libnetworking/libc/res_comp.c: Eliminate unused var "ppch".
* configure.ac: Check for size of time_t.
