path: root/cpukit (follow)
* Incorrect error status returned. Noted by Andrew KlossnerJoel Sherrill2000-02-041-1/+1
| | | | <andrew@pogo.wv.tek.com>.
* Changed behavior to match that expected by EPICS test code. Reported byJoel Sherrill2000-02-031-2/+1
| | | | Eric Norum <eric@cls.usask.ca>.
* Patches rtems-rc-20000118-7.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-0317-79/+479
| | | | | | | | | | | | | | | | | that contains the automake files for libnetworking plus a couple of minor fixes. [Now only one unused/unsupported Makefile.in remains (./c/src/lib/libbsp/hppa1.1/pxfl/Makefile.in).] To apply: patch -p1 < rtems-rc-20000118-7.diff /bin/sh rtems-rc-20000118-7.rm /bin/sh rtems-rc-20000118-7.add ./bootstrap Notes: * I have tested this one by building all BSPs for m68k, powerpc, sh and unix with toolchains built since last weekend. * I did not touch libnetworking's directory layout.
* Fixed spelling errors.Joel Sherrill2000-02-031-2/+2
* Patches rtems-rc-20000118-3.diff and rtems-rc-20000118-4.diff fromJoel Sherrill2000-01-3117-249/+192
| | | | | | | | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de> that contain: * Modifications, (minor) corrections, cleanups to most existing Makefile.ams * Adds automake support to all remaining BSPs which have not yet been converted to automake. * Makefile.am for all remaining wrapup/Makefile.ams
* Added after report from Quality Quorum <qqi@world.std.com> thatJoel Sherrill2000-01-271-0/+5
| | | | pc686.cfg was not present.
* Directive rtems_task_variable_get() added by Eric Norum.Joel Sherrill2000-01-233-1/+86
* Patch from Eric Norum <eric@cls.usask.ca> at the request of JakeJoel Sherrill2000-01-211-33/+56
| | | | | | | Janovetz <janovetz@tempest.ece.uiuc.edu> to return a status from network initialization rather than panic'ing. It changes a bunch of rtems_panics to printfs and returns a status from rtems_bsdnet_initialize_network().
* Patch from Eric Norum <eric@cls.usask.ca> to implement this:Joel Sherrill2000-01-215-7/+13
| | | | | | | | | | | | | | | | | | | | I'd like to propose a change to RTEMS task variables that I think would make them more useful. I think that it is early enough in their existence to still make changes to their API. 1) Change type from `int' to `void *'. 2) Add extra argument to task_variable_add -- if non-NULL, a pointer to a `destructor' function to be called when the task exits. This function would be called with that task's value of the task variable as its argument. In many cases, the `dtor' function could be `free'. rtems_status_code rtems_task_variable_add ( rtems_id tid, void **ptr, void (*dtor)(void *)); rtems_status_code rtems_task_variable_delete (rtems_id tid, void **ptr); This would be all we'd need to cleanly and efficiently support C++ per-thread exception information without dragging in all that POSIX API stuff.
* Patch from Eric Norum <eric@cls.usask.ca> to remove warnings.Joel Sherrill2000-01-211-4/+3
* Removed unused variable warning.Joel Sherrill2000-01-142-2/+0
* Removed no prototype of kill() warning.Joel Sherrill2000-01-141-0/+2
* Removed warning.Joel Sherrill2000-01-142-2/+4
* POSIX message queues now include complete functionality includingJoel Sherrill2000-01-1313-140/+204
| | | | | | | | | | | | | | | | blocking sends when the queue is full. The SuperCore was enhanced to support blocking on send. The existing POSIX API was debugged and numerous test cases were added to psxmsgq01 by Jennifer Averett. SuperCore enhancements and resulting modifications to other APIs were done by Joel. There is one significant point of interpretation for the POSIX API. What happens to threads already blocked on a message queue when the mode of that same message queue is changed from blocking to non-blocking? We decided to unblock all waiting tasks with an EAGAIN error just as if a non-blocking version of the same operation had returned unsatisfied. This case is not discussed in the POSIX standard and other implementations may have chosen differently.
* + Added commentsJennifer Averett2000-01-133-8/+46
* + Added and yellow line tested _CORE_message_queue_Flush_waiting_threadsJennifer Averett2000-01-133-1/+174
| | | | | and _CORE_message_queue_Insert_message for posix message queues. + Yellow line tested new source
* Added comment.Jennifer Averett2000-01-131-0/+1
* + Comment cleanupJennifer Averett2000-01-134-15/+12
* Removed referance to rtems error.Jennifer Averett2000-01-131-1/+2
| | | | Added correct include file.
* Added comment to indicate this path does not occur.Jennifer Averett2000-01-131-1/+2
* + Added code for waiting sendJennifer Averett2000-01-121-4/+39
| | | | + Yellow lined tested routine with Posix message queue test (01)
* Debugged and yellow line tested routines.Jennifer Averett2000-01-123-41/+71
* + Modified return codesJennifer Averett2000-01-121-16/+27
| | | | | + Added messsage size check + Debugged and yellowed out routine
* + Added signal processing.Jennifer Averett2000-01-121-1/+3
| | | | + Yellow line tested source.
* + Modified to correct return codes.Jennifer Averett2000-01-121-2/+5
| | | | | + Removed extra flag attribute from message queue structure. + Yellow-lined all posix message queue routines.
* + Changed call from core flush to core close routine. This flushes waitingJennifer Averett2000-01-121-2/+4
| | | | queues as well as the messages.
* + Removed name validation code (this was already done in nametoid.Jennifer Averett2000-01-121-41/+6
* Fixed spacing.Joel Sherrill2000-01-111-1/+1
* This code did not return properly when a process oriented signalJoel Sherrill2000-01-111-6/+5
| | | | was pending. Reported by Wayne Bullaughey <wayneb@cacdsp.com>.
* Removed definition of USHRT_MAX to remove lots of redefinition warnings.Joel Sherrill2000-01-101-2/+0
* Don't look at the object information structure for threads/tasksJoel Sherrill2000-01-102-17/+28
| | | | | for APIs that are not configured. This resulted in weird behavior when ITRON was disabled on some targets.
* Corrected spacing.Joel Sherrill2000-01-061-3/+2
* Added support for simple binary semaphores in addition to the highJoel Sherrill2000-01-0516-111/+174
| | | | | | | | | | | | power binary/mutex style semaphores already supported by RTEMS. This was done at the request of Eric Norum <eric@cls.usask.ca> in support of his effort to port EPICS to RTEMS. This change consisted of changing the nesting_allowed boolean into a lock_nesting_behavior enumerated value as well as allowing the core mutex object to optionally support ensuring that the holder of a binary semaphore released it. Finally, a more subtle enhancement was to allow the non-holder to release a priority inheritance/ceiling mutex and still allow the holding task to return to its original priority.
* Added message priority parameter returned by core support routine.Joel Sherrill2000-01-051-1/+3
* Added new message priority parameter as returned by core support routine.Joel Sherrill2000-01-051-5/+7
* Spacing corrected.Joel Sherrill2000-01-051-1/+1
* Fixed recursive release for mutexes with nesting allowed.Joel Sherrill2000-01-051-1/+4
* + Added return priority from message seize.Jennifer Averett2000-01-051-10/+11
| | | | + Changed priority to be based off of min and max int.
* Added the recording of the submit type.Jennifer Averett2000-01-051-0/+1
* + Added return of the message priority.Jennifer Averett2000-01-051-6/+8
* Added priority conversion between POSIX and core.Jennifer Averett2000-01-051-2/+17
* Added priority conversion between POSIX and core priorities.Jennifer Averett2000-01-051-2/+29
* + Changed priority to the POSIX priority type.Jennifer Averett2000-01-051-9/+46
| | | | | | | + Added priority validation + Changed to call correct core routine. + Added priority conversion + Resolved return type problems.
* + Added check for reading from a write only queue.Jennifer Averett2000-01-051-1/+12
| | | | + Added ability to return message priority from the core.
* + Added check for name greater than PATH_MAX.Jennifer Averett2000-01-051-0/+3
* + Changed to resonable default values for maxmsg and msgsize.Jennifer Averett2000-01-051-3/+11
| | | | + Added oflag tracking.
* Added mqueuetranslatereturncode.c.Jennifer Averett2000-01-051-1/+1
* Added routines to translate to and from the core message queue return codes.Jennifer Averett2000-01-051-0/+68
* Added this file to contain an example program.Joel Sherrill2000-01-041-0/+27
