1999-03-16 | Added ftpd server from Jake Janovetz <janovetz@tempest.ece.uiuc.edu>. | Joel Sherrill | 2 | -0/+1093 | |
1999-03-16 | Use proper include for libio.h. | Joel Sherrill | 6 | -12/+6 | |
1999-03-08 | Corrected bug where pointer to doubly linked blocks was being incorrectly | Joel Sherrill | 1 | -2/+34 | |
calculated. | |||||
1999-03-08 | Added code to translate internal libio flags to POSIX style flags. | Joel Sherrill | 1 | -3/+20 | |
1999-03-08 | Added support for F_GETFL and F_SETFL. | Joel Sherrill | 1 | -2/+3 | |
1999-03-06 | Added F_GETFL support so the fdopen() implementation in newlib 1.8.1 | Joel Sherrill | 4 | -2/+43 | |
would work. At the same time, the initial implementation of F_SETFL was added. A support routine was added to convert internal libio flags back to the POSIX style. Eventually the internal representation should be eliminated in the interest of simplicity and code reduction. This problem was reported by Jake Janovetz <janovetz@tempest.ece.uiuc.edu>. | |||||
1999-03-01 | Patch from Eric Norum <eric@skatter.usask.ca> to eliminate external | Joel Sherrill | 21 | -276/+61 | |
IO handlers scheme that was implemented originally just to support sockets. The file system IO switch is more general and works fine. | |||||
1999-03-01 | Part of the automake VI patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 2 | -19/+19 | |
> 5) rtems-rc-19990202-1.diff/reorg-install.sh > > reorg-install.sh fixes a Makefile variable name clash of RTEMS > configuration files and automake/autoconf standards. > Until now, RTEMS used $(INSTALL) for install-if-change. Automake and > autoconf use $(INSTALL) for a bsd-compatible install. As > install-if-change and bsd-install are not compatible, I renamed all > references to install-if-changed to $(INSTALL_CHANGED) and used > $(INSTALL) for bsd-install (==automake/autoconf standard). When > automake will be introduced install-if-change will probably be replaced > by $(INSTALL) and therefore will slowly vanish. For the moment, this > patch fixes a very nasty problem which prevents adding any automake file > until now (There are still more). | |||||
1999-02-24 | Changed IMFS to use IMFS_NAME_MAX as the maximum length of a basename | Joel Sherrill | 8 | -24/+34 | |
rather then NAME_MAX. NAME_MAX is 255 and that lets IMFS chew up memory too fast. Perhaps in the future, the places in IMFS that put a maximum length name string on the stack and the jnode structure does not include a maximu length name string can be fixed so this is not a problem. | |||||
1999-02-24 | Corrected name of constant so this would compile. | Joel Sherrill | 1 | -1/+1 | |
1999-02-19 | Moved back up in tree. | Joel Sherrill | 8 | -0/+4202 | |
1999-02-19 | Moved asm.h back up in tree. | Joel Sherrill | 14 | -0/+1728 | |
1999-02-19 | Moved to proper rtems/score | Joel Sherrill | 27 | -6045/+289 | |
1999-02-18 | Part of the automake VI patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 34 | -0/+13100 | |
> 4) rtems-rc-19990202-0.diff /reorg-score-cpu.sh > > reorg-score-cpu.sh reorganizes the cpu/<cpu>/* subdirectories in a > similar manner than previous reorg scripts did. rtems-rc-19990202-0.diff > contains the diffs after reorg-score-cpu.sh has been run on a > rtems-19981215 snapshot + my patches up to rtems-rc-19990131-2.diff. > > This patch is rather nasty and may break something. However, I've tested > it for about 10 different target/bsp pairs and believe to have shaken > out most bugs. I wonder about the following .h files that were not moved: a29k/asm.h a29k/cpu_asm.h i386/asm.h i960/asm.h m68k/asm.h m68k/m68302.h m68k/m68360.h m68k/qsm.h m68k/sim.h mips64orion/asm.h mips64orion/cpu_asm.h mips64orion/mips64orion.h no_cpu/asm.h no_cpu/cpu_asm.h powerpc/asm.h powerpc/mpc860.h sh/asm.h sparc/asm.h sparc/erc32.h | |||||
1999-02-18 | Yet another part of automake VI from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 7 | -2466/+0 | |
1999-02-18 | Patch from Emmanuel Raguet <raguet@crf.canon.fr>: | Joel Sherrill | 1 | -1/+9 | |
You will find enclosed a patch which contains, for Intel PC386 target : - an Ethernet driver for DEC21140 device based boards. - a simple cache management with paging mechanism. | |||||
1999-02-18 | GLobal reentrancy structure is now dynamically initialized. | Joel Sherrill | 1 | -1/+2 | |
1999-02-15 | Patch from Eric Valette <valette@crf.canon.fr> to undo the patch | Joel Sherrill | 1 | -2/+0 | |
that added ifdef on the pc386. | |||||
1999-02-10 | POSIX timer support. | Joel Sherrill | 1 | -1/+1 | |
1999-02-10 | Set the read/write offset to 0 when the file is opened. The ACVC had a test | Joel Sherrill | 1 | -0/+1 | |
that performed the sequence open/write/close/open/read/close on a file. It did not get the correct result since the file descriptor was reused. | |||||
1999-02-10 | Corrected multiple places the file size was not being properly updated. | Joel Sherrill | 1 | -2/+8 | |
1999-02-10 | Added getcwd(). | Joel Sherrill | 1 | -0/+280 | |
1999-02-10 | POSIX timer support modifications. | Joel Sherrill | 3 | -4/+16 | |
1999-02-10 | Comments fixed after problem report from Ian Lance Taylor <ian@airs.com>. | Joel Sherrill | 1 | -19/+10 | |
1999-02-05 | Patch from Eric Norum to correct bug induced by select() patch. | Joel Sherrill | 2 | -5/+11 | |
1999-02-05 | Corrected spacing and added some new error checks that were needed | Joel Sherrill | 3 | -24/+34 | |
to avoid dereferencing NULLs. | |||||
1999-02-04 | Added printf()'s that can be uncommented to trace MBUF operations. This | Joel Sherrill | 1 | -0/+3 | |
is very useful when debugging a device driver. | |||||
1999-02-04 | Modifed to reflect transition from device driver to file system. | Joel Sherrill | 1 | -41/+4 | |
1999-02-04 | Added debug printf()'s that are commented out. Uncommenting these | Joel Sherrill | 1 | -0/+3 | |
allows one to trace the enqueueing and dequeueing of messages. This can be used to insure that packets are getting to the boundary between the network stack and the device driver. | |||||
1999-02-04 | Added PowerPC specific header checksum code. | Joel Sherrill | 2 | -68/+10 | |
1999-02-04 | Added PowerPC specific header checksum code. | Joel Sherrill | 1 | -4/+61 | |
Added volatile to i386 assembly statements in header checksum code. | |||||
1999-02-04 | Debugged and now works except for handling of minor number. | Joel Sherrill | 1 | -313/+429 | |
1999-02-04 | Modified to include comments on how to get TCPDEBUG turned on and | Joel Sherrill | 2 | -1/+11 | |
printing messages. | |||||
1999-02-03 | POSIX Timers submitted by Juan Zamorano Flores | Joel Sherrill | 5 | -8/+1011 | |
<jzamora@avellano.datsi.fi.upm.es>. | |||||
1999-02-02 | Added debug #define and commented it out. | Joel Sherrill | 1 | -0/+1 | |
1999-02-02 | Added PowerPC specific in_cksum file. | Joel Sherrill | 1 | -0/+4 | |
1999-02-02 | New file. Based on the i386 version. | Joel Sherrill | 2 | -0/+404 | |
1999-01-31 | Prepended macro variables with "_" to avoid name conflicts in expansions. | Joel Sherrill | 1 | -78/+78 | |
1999-01-31 | Split psignal.c into many more files. This reduced the amount of | Joel Sherrill | 21 | -918/+1341 | |
object code that has to be loaded just for initializing the signal manager. | |||||
1999-01-31 | New files added to ease debugging. | Joel Sherrill | 2 | -0/+96 | |
1999-01-28 | Patch from Eric Norum <eric@skatter.usask.ca> to avoid dereferencing a | Joel Sherrill | 1 | -1/+4 | |
NULL pointer. | |||||
1999-01-28 | Patch from Eric Norum <eric@skatter.usask.ca> to set more flags in | Joel Sherrill | 1 | -2/+2 | |
rtems_bsdnet_makeFdForSocket(). | |||||
1999-01-26 | Added include of <rtems/posix/priority.h> so a macro would expand | Joel Sherrill | 1 | -0/+1 | |
and eliminate a link error. | |||||
1999-01-26 | Changed prototype of rtems_bsdnet_makeFdForSocket to (void *) pointer | Joel Sherrill | 1 | -1/+1 | |
so that the libc code did not have to know about (struct socket). | |||||
1999-01-26 | Switched from printf() to puts(). | Joel Sherrill | 1 | -1/+1 | |
1999-01-26 | Added libio_sockets.c to hold support routines for networking code. | Joel Sherrill | 1 | -0/+58 | |
1999-01-25 | Split most of POSIX Threads Manager into multiple files. | Joel Sherrill | 30 | -957/+1347 | |
1999-01-25 | Added enough prototypes to allow most of POSIX Threads Manager to be | Joel Sherrill | 1 | -0/+26 | |
split into multiple files. | |||||
1999-01-21 | Made to compile after hacking tftp driver into beginnings of a mini-filesystem. | Joel Sherrill | 5 | -39/+299 | |
1999-01-20 | Patch from Eric Norum <eric@skatter.usask.ca> to make m68360.h usable | Joel Sherrill | 2 | -714/+732 | |
outside RTEMS. Comment: I found a couple of places other than RTEMS where I'd like to use the declarations supplied in m68360.h. To make this easier to do, I've redone the declarations in m68360.h to use standard C types. |
