* libnetworking/sys/un.h: Partial update from FreeBSD.
Remove non-implemented functions/variables.
* libnetworking/rtems/bsdnet/_types.h: New.
* Makefile.am: Add rtems_bsdnet_HEADERS.
* libnetworking/Makefile.am: Remove rtems_bsdnet_HEADERS.
* preinstall.am, libnetworking/preinstall.am: Regenerate.
* libcsupport/include/sys/cdefs.h: Partial update from FreeBSD.
* libnetworking/arpa/inet.h: Partial update from FreeBSD.
* libnetworking/netinet/in.h: Partial update from FreeBSD.
* libnetworking/sys/socket.h: Partial update from FreeBSD.
* librpc/src/rpc/bindresvport.c: socklen_t.
* libnetworking/sys/mbuf.h: Ansification.
* libnetworking/kern/uipc_mbuf.c: Partial update from FreeBSD.
* libnetworking/libc/inet_addr.c: in_addr_t.
* libnetworking/lib/tftpDriver.c: socklen_t.
* libnetworking/libc/inet_lnaof.c: in_addr_t.
* libnetworking/libc/inet_makeaddr.c: in_addr_t.
* libnetworking/libc/inet_netof.c: in_addr_t.
* libnetworking/libc/inet_network.c: in_addr_t.
* libnetworking/libc/inet_ntop.c: Ansify, socklen_t.
* libnetworking/lib/ftpfs.c: socklen_t, PRIu32.
* libnetworking/arpa/inet.h: Add in_addr_t, in_port_t.
* libnetworking/netinet/in.h: Sync in_port_t with arpa/inet.h.
* libnetworking/sys/socket.h: Include <sys/types.h>.
Remove in_port_t. Misc. updates from FreeBSD.
* libnetworking/pppd/Makefile.am: CPPFLAGS += -D__BSD_VISIBLE.
Remove BYTE_PACK.
Remove BYTE_PACK.
* libnetworking/netinet/ip.h: Add BYTE_PACK.
* libnetworking/netinet/if_ether.c: Cosmetics from FreeBSD.
* libnetworking/libc/inet_addr.c: Cosmetics from FreeBSD.
* libnetworking/netinet/in.h: Cosmetics from FreeBSD.
* libnetworking/sys/socket.h: Cosmetics from FreeBSD.
* libnetworking/sys/un.h: Cosmetical updates from FreeBSD.
* libnetworking/net/if_var.h: More partial updates from FreeBSD.
* libnetworking/rtems/rtems_bsdnet.h: Eliminate rtems_* fixed size
types.
* rtems/score/powerpc.h: Removed warning
* libnetworking/net/if.h: Revert include of sys/mbuf.h in this .h file
since it causes other problems.
* libcsupport/src/termios.c: Removed warnings.
* libnetworking/net/if.h, libnetworking/net/if_ppp.c,
libnetworking/net/ppp_tty.c: Removed warnings.
* libblock/src/blkdev.c, libfs/src/dosfs/fat_file.c,
libfs/src/dosfs/fat_file.h, libfs/src/dosfs/msdos.h,
libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_dir.c,
libfs/src/dosfs/msdos_initsupp.c, libfs/src/dosfs/msdos_misc.c:
Removed warnings.
* include/rtems/pci.h: Name change to support common PCI interface
* rtems/score/m68k.h: Change _ColdFire_VBR to _VBR.
* rtems/score/cpu.h: Change definition of _VBR to a simple pointer.
* rtems/score/m68k.h: Remove use of _Coldfire_VBR.
* cpu.c: Remove warning.
* libcsupport/include/ringbuf.h: Use uint8_t instead of char for raw
data buffer.
* rtems/src/regiongetfreeinfo.c: Return RTEMS_SUCCESSFUL instead of
RTEMS_INVALID_ADDRESS on success path.
* libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_load_tar.c: Use uint8_t
instead of char for raw data buffer.
* rtems.adb: Remove gcc 4.x warnings.
* libfs/src/dosfs/msdos_format.c, librpc/src/xdr/xdr.c: Added
initialization to remove warnings.
PR 782/rtems
* rtems.ads: Remove stray ';'.
* rtems.adb: Stub Task_Variable_Add, Task_Variable_Get,
Task_Variable_Delete.
