path: root/cpukit (follow)
* libmisc/rtems-fdt: close() file 'bf'Ryan Long2021-12-171-0/+1
| | | | | | | | close() file 'bf' to avoid leaking descriptor. CID 1437645: Resource leak in rtems_fdt_load(). Closes #4297
* dtc: Update VERSIONSebastian Huber2021-12-141-3/+3
* libfdt: overlay: make overlay_get_target() publicVikram Garhwal2021-12-141-0/+18
| | | | | | | | | | | This is done to get the target path for the overlay nodes which is very useful in many cases. For example, Xen hypervisor needs it when applying overlays because Xen needs to do further processing of the overlay nodes, e.g. mapping of resources(IRQs and IOMMUs) to other VMs, creation of SMMU pagetables, etc. Signed-off-by: Vikram Garhwal <fnu.vikram@xilinx.com> Message-Id: <1637204036-382159-2-git-send-email-fnu.vikram@xilinx.com> Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
* libfdt: fix an incorrect integer promotionElvira Khabirova2021-12-141-1/+1
| | | | | | | | | | UINT32_MAX is an integer of type unsigned int. UINT32_MAX + 1 overflows unless explicitly computed as unsigned long long. This led to some invalid addresses being treated as valid. Cast UINT32_MAX to uint64_t explicitly. Signed-off-by: Elvira Khabirova <e.khabirova@omp.ru>
* libfdt: Add ALIGNMENT error stringGeorg Kotheimer2021-12-141-0/+1
| | | | | | | | The ALIGNMENT error was missing a string, leading to <unknown error> being returned. Signed-off-by: Georg Kotheimer <georg.kotheimer@kernkonzept.com> Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
* fdtget: Fix signedness comparisons warningsAndre Przywara2021-12-141-0/+7
| | | | | | | | | | | | | | | | | | | | | With -Wsign-compare, compilers warn about a mismatching signedness in the different legs of the conditional operator, in fdtget.c. In the questionable expression, we are constructing a 16-bit value out of two unsigned 8-bit values, however are relying on the compiler's automatic expansion of the uint8_t to a larger type, to survive the left shift. This larger type happens to be an "int", so this part of the expression becomes signed. Fix this by explicitly blowing up the uint8_t to a larger *unsigned* type, before doing the left shift. And while we are at it, convert the hardly readable conditional operator usage into a sane switch/case expression. This fixes "make fdtget", when compiled with -Wsign-compare. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Message-Id: <20210618172030.9684-3-andre.przywara@arm.com> Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
* Fix CID 1461557David Gibson2021-12-141-5/+8
| | | | | | | | | | | | Coverity gets a bit confused by loading fdt_size_dt_strings() and using it in a memmove(). In fact this is safe because the callers have verified this information (via FDT_RW_PROBE() in fdt_pack() or construction in fdt_open_into()). Passing in strings_size like we already do struct_size seems to get Coverity to follow what's going on here. Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
* libfdt: Add FDT alignment check to fdt_check_header()Rob Herring2021-12-141-0/+4
| | | | | | | | | | | | | Only checking the FDT alignment in fdt_ro_probe_() means that fdt_check_header() can pass, but then subsequent API calls fail on alignment checks. Let's add an alignment check to fdt_check_header() so alignment errors are found up front. Cc: Tom Rini <trini@konsulko.com> Cc: Frank Rowand <frowand.list@gmail.com> Signed-off-by: Rob Herring <robh@kernel.org> Message-Id: <20210406190712.2118098-1-robh@kernel.org> Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
* libfdt: Fix a possible "unchecked return value" warningDavid Gibson2021-12-141-1/+4
| | | | | | | | | | | | | | | | Apparently the unchecked return value of the first fdt_next_tag() call in fdt_add_subnode_namelen() is tripping Coverity Scan in some circumstances, although it appears not to for the scan on our project itself. This fdt_next_tag() should always return FDT_BEGIN_NODE, since otherwise the fdt_subnode_offset_namelen() above would have returned BADOFFSET or BADSTRUCTURE. Still, add a check to shut Coverity up, gated by a can_assume() to avoid bloat in small builds. Reported-by: Ryan Long <ryan.long@oarcorp.com> Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
* Set last_comp_version correctly in new dtb and fix potential version issues ↵Justin Covell2021-12-143-2/+5
| | | | | | | | | | | | | | | in fdt_open_into Changes in v3: - Remove noop version sets - Set version correctly on loaded fdt in fdt_open_into Fixes: f1879e1a50eb ("Add limited read-only support for older (V2 and V3) device tree to libfdt.") Signed-off-by: Justin Covell <jujugoboom@gmail.com> Message-Id: <20201229041749.2187-1-jujugoboom@gmail.com> Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
* libfdt: Tweak description of assume-aligned load helpersDavid Gibson2021-12-141-7/+7
| | | | | | | | There's a small inaccuracy in the comment describing these new helpers. This corrects it, and reformats while we're there. Fixes: f98f28ab ("libfdt: Internally perform potentially unaligned loads") Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
* libfdt: Internally perform potentially unaligned loadsTom Rini2021-12-143-15/+32
| | | | | | | | | | | | | | | | | | | | | Commits 6dcb8ba4 "libfdt: Add helpers for accessing unaligned words" introduced changes to support unaligned reads for ARM platforms and 11738cf01f15 "libfdt: Don't use memcpy to handle unaligned reads on ARM" improved the performance of these helpers. On further discussion, while there are potential cases where we could be used on platforms that do not fixup unaligned reads for us, making this choice the default is very expensive in terms of binary size and access time. To address this, introduce and use new fdt{32,64}_ld_ functions that call fdt{32,64}_to_cpu() as was done prior to the above mentioned commits. Leave the existing load functions as unaligned-safe and include comments in both cases. Reviewed-by: Rob Herring <robh@kernel.org> Signed-off-by: Tom Rini <trini@konsulko.com> Message-Id: <20201211022736.31657-1-trini@konsulko.com> Tested-by: John Paul Adrian Glaubitz <glaubitz@physik.fu-berlin.de> Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
* libfdt: Check for 8-byte address alignment in fdt_ro_probe_()Tom Rini2021-12-142-1/+9
| | | | | | | | | | The device tree must be loaded in to memory at an 8-byte aligned address. Add a check for this condition in fdt_ro_probe_() and a new error code to return if we are not. Signed-off-by: Tom Rini <trini@konsulko.com> Message-Id: <20201104130605.28874-1-trini@konsulko.com> Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
* libfdt: Fix kernel-doc commentsAndre Przywara2021-12-141-36/+75
| | | | | | | | | | | | | | | | | | The API documentation in libfdt.h seems to follow the Linux kernel's kernel-doc format[1]. Running "scripts/kernel-doc -v -none" on the file reports some problems, mostly missing return values and missing parameter descriptions. Fix those up by providing the missing bits, and fixing the other small issues reported by the script. Signed-off-by: Andre Przywara <andre.przywara@arm.com> [1] https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/Documentation/doc-guide/kernel-doc.rst Message-Id: <20201012165331.25016-1-andre.przywara@arm.com> Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
* libfdt: fdt_strerror(): Fix comparison warningAndre Przywara2021-12-141-2/+2
| | | | | | | | | | | | | With -Wsign-compare, compilers warn about a mismatching signedness in a comparison in fdt_strerror(). Force FDT_ERRTABSIZE to be signed (it's surely small enough to fit), so that the types match. Also move the minus sign to errval, as this is actually what we use in the next line. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Message-Id: <20201001164630.4980-7-andre.przywara@arm.com> Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
* libfdt: fdt_get_string(): Fix sequential write comparison warningsAndre Przywara2021-12-141-4/+6
| | | | | | | | | | | | | With -Wsign-compare, compilers warn about a mismatching signedness in comparisons in fdt_get_string(). Introduce a new usigned variable, which holds the actual (negated) stroffset value, so we avoid negating all the other variables and have proper types everywhere. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Message-Id: <20201001164630.4980-6-andre.przywara@arm.com> Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
* libfdt: libfdt_wip: Fix comparison warningAndre Przywara2021-12-141-1/+1
| | | | | | | | | | | | | With -Wsign-compare, compilers warn about a mismatching signedness in a comparison in fdt_setprop_inplace_namelen_partial(). fdt_getprop_namelen() will only return negative error values in "proplen" if the return value is NULL. So we can rely on "proplen" being positive in our case and can safely cast it to an unsigned type. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Message-Id: <20201001164630.4980-5-andre.przywara@arm.com> Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
* libfdt: fdt_create_with_flags(): Fix comparison warningAndre Przywara2021-12-141-2/+2
| | | | | | | | | | | | With -Wsign-compare, compilers warn about a mismatching signedness in a comparison in fdt_create_with_flags(). By making hdrsize a signed integer (we are sure it's a very small number), we avoid all the casts and have matching types. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Message-Id: <20201001164630.4980-4-andre.przywara@arm.com> Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
* libfdt: fdt_move(): Fix comparison warningsAndre Przywara2021-12-141-1/+4
| | | | | | | | | | | | | | | With -Wsign-compare, compilers warn about a mismatching signedness in comparisons in fdt_move(). This stems from "bufsize" being passed in as a signed integer, even though we would expect a buffer size to be positive. Short of changing the prototype, check that bufsize is not negative, and cast it to an unsigned type in the comparison. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Message-Id: <20201001164630.4980-3-andre.przywara@arm.com> Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
* libfdt: fdt_add_string_(): Fix comparison warningAndre Przywara2021-12-141-7/+7
| | | | | | | | | | | | With -Wsign-compare, compilers warn about a mismatching signedness in a comparison in fdt_add_string_(). Make all variables unsigned, and express the negative offset trick via subtractions in the code. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Message-Id: <20201001164630.4980-2-andre.przywara@arm.com> Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
* libfdt: fdt_node_offset_by_phandle(): Fix comparison warningAndre Przywara2021-12-141-1/+1
| | | | | | | | | | | | With -Wsign-compare, compilers warn about a mismatching signedness in a comparison in fdt_node_offset_by_phandle(). Uses a better suited bitwise NOT operator to denote the special value of -1, which automatically results in an unsigned type. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Message-Id: <20200921165303.9115-14-andre.przywara@arm.com> Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
* libfdt: fdt_resize(): Fix comparison warningAndre Przywara2021-12-141-1/+4
| | | | | | | | | | | | | | With -Wsign-compare, compilers warn about a mismatching signedness in a comparison in fdt_resize(). A negative buffer size will surely do us no good, so let's rule this case out first. In the actual comparison we then know that a cast to an unsigned type is safe. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Message-Id: <20200921165303.9115-10-andre.przywara@arm.com> Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
* libfdt: fdt_splice_(): Fix comparison warningAndre Przywara2021-12-141-1/+1
| | | | | | | | | | | | With -Wsign-compare, compilers warn about a mismatching signedness in a comparison in fdt_splice_(). Since we just established that oldlen is not negative, we can safely cast it to an unsigned type. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Message-Id: <20200921165303.9115-8-andre.przywara@arm.com> Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
* libfdt: fdt_get_string(): Fix comparison warningsSimon Glass2021-12-141-2/+2
| | | | | | | | | | | | | With -Wsign-compare, compilers warn about a mismatching signedness in comparisons in fdt_get_string(). In the first two cases, we have just established that the signed values are not negative, so it's safe to cast the values to an unsigned type. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Andre Przywara <andre.przywara@arm.com> Message-Id: <20200921165303.9115-7-andre.przywara@arm.com> Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
* libfdt: fdt_grab_space_(): Fix comparison warningAndre Przywara2021-12-141-2/+2
| | | | | | | | | | | | With -Wsign-compare, compilers warn about a mismatching signedness in a comparison in fdt_grab_space_(). All the involved values cannot be negative, so let's switch the types of the local variables to unsigned to make the compiler happy. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Message-Id: <20200921165303.9115-4-andre.przywara@arm.com> Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
* libfdt: fdt_mem_rsv(): Fix comparison warningsAndre Przywara2021-12-141-2/+2
| | | | | | | | | | | | With -Wsign-compare, compilers warn about a mismatching signedness in comparisons in fdt_mem_rsv(). Since all involved values must be positive, change the used types to be unsigned. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Message-Id: <20200921165303.9115-3-andre.przywara@arm.com> Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
* libfdt: fdt_offset_ptr(): Fix comparison warningsAndre Przywara2021-12-141-3/+7
| | | | | | | | | | | | | | | With -Wsign-compare, compilers warn about mismatching signedness in comparisons in fdt_offset_ptr(). This mostly stems from "offset" being passed in as a signed integer, even though the function would not really tolerate negative values. Short of changing the prototype, check that offset is not negative, and use an unsigned type internally. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Message-Id: <20200921165303.9115-2-andre.przywara@arm.com> Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
* libfdt: fix fdt_check_node_offset_ w/ VALID_INPUTFrank Mehnert2021-12-141-6/+10
| | | | | | | | | | | | | fdt_check_node_offset_() checks for a valid offset but also changes the offset by calling fdt_next_tag(). Hence, do not skip this function if ASSUME_VALID_INPUT is set but only omit the initial offset check in that case. As this function works very similar to fdt_check_prop_offset_(), do the offset check there as well depending on ASSUME_VALID_INPUT. Message-Id: <1913141.TlUzK5foHS@noys4> Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
* libfdt: add extern "C" for C++Patrick Oppenlander2021-12-141-0/+8
| | | | | | Signed-off-by: Patrick Oppenlander <patrick.oppenlander@gmail.com> Message-Id: <20200616011217.15253-1-patrick.oppenlander@gmail.com> Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
* libfdt: trivial typo fixPatrick Oppenlander2021-12-141-1/+1
| | | | | | Signed-off-by: Patrick Oppenlander <patrick.oppenlander@gmail.com> Message-Id: <20200618042117.131731-1-patrick.oppenlander@gmail.com> Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
* libfdt: Correct condition for reordering blocksSimon Glass2021-12-141-1/+1
| | | | | | | | | This condition uses bitwise OR but should be logical OR. Fix it. Signed-off-by: Simon Glass <sjg@chromium.org> Reported-by: kernel test robot <lkp@intel.com> Message-Id: <20200615160033.87328-1-sjg@chromium.org> Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
* libfdt: fix undefined behaviour in fdt_splice_()Jan Beulich2021-12-141-6/+7
| | | | | | | | | | | | | | libfdt: fix undefined behaviour in fdt_splice_() Along the lines of commit d0b3ab0a0f46 ("libfdt: Fix undefined behaviour in fdt_offset_ptr()"), fdt_splice_() similarly may not use pointer arithmetic to do overflow checks. (The left side of the checks added by d4c7c25c9ed1 ["libfdt: check for potential overrun in _fdt_splice()"] doesn't really lend itself to similar replacement though.) Signed-off-by: Jan Beulich <jbeulich@suse.com> Message-Id: <f2d09e81-7cb8-c5cc-9699-1ac05b0626ff@suse.com> Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
* libfdt: Use VALID_INPUT for FDT_ERR_BADSTATE checksSimon Glass2021-12-142-4/+5
| | | | | | | | | | This error indicates a logic bug in the code calling libfdt, so VALID_DTB is not really the right check. Update it to use VALID_INPUT instead. Signed-off-by: Simon Glass <sjg@chromium.org> Suggested-by: David Gibson <david@gibson.dropbear.id.au> Message-Id: <20200302190255.51426-4-sjg@chromium.org> Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
* libfdt: Add support for disabling internal checksSimon Glass2021-12-142-2/+11
| | | | | | | | | | | If libfdt returns -FDT_ERR_INTERNAL that generally indicates a bug in the library. Add a new assumption for these cases since it should be save to disable these checks regardless of the input. Signed-off-by: Simon Glass <sjg@chromium.org> Suggested-by: David Gibson <david@gibson.dropbear.id.au> Message-Id: <20200302190255.51426-3-sjg@chromium.org> Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
* libfdt: Improve comments in some of the assumptionsSimon Glass2021-12-141-3/+12
| | | | | | | | | Add a little more detail in a few of these comments. Signed-off-by: Simon Glass <sjg@chromium.org> Suggested-by: David Gibson <david@gibson.dropbear.id.au> Message-Id: <20200302190255.51426-2-sjg@chromium.org> Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
* libfdt: Fix a few typosSimon Glass2021-12-141-3/+3
| | | | | | | | | | Fix 'saftey' and 'additional' typos noticed in the assumption series. Reword the ASSUME_NO_ROLLBACK slightly to improve clarity. Signed-off-by: Simon Glass <sjg@chromium.org> Suggested-by: David Gibson <david@gibson.dropbear.id.au> Message-Id: <20200302190255.51426-1-sjg@chromium.org> Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
* rtems: Improve ordering in <rtems/rtems/intr.h>Sebastian Huber2021-12-131-284/+284
| | | | | Move the data structure definitions closer to the directives which use them.
* Avoid ISR_LOCK_MEMBER() since it confuses DoxygenSebastian Huber2021-12-096-7/+17
| | | | | If RTEMS_SMP is not defined, then Doxygen adds the comments intended for conditional the lock member to the next member.
* untar: Make behavior similar to GNU or BSD tarChristian Mauderer2021-12-091-20/+37
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | RTEMS untar implementation had problems with overwriting or integrating archives into existing directory structures. This patch adapts the behavior to mimic that of a GNU tar or BSD tar and extends the tar01 test to check for the behavior. That is: * If a directory structure exists, the files from the archive will be integrated. Existing files are overwritten. * If a file exists and the archive contains a directory with the same name, the file is removed and a directory is created. In the above example: if l1/l2 is a file it will be overwritten with a new directory. * If a directory exists and the archive contains a file with the same name, the directory will be replaced if it is empty. If it contains files, the result is an error. * An archive also can contain only a file without the parent directories. If in that case one of the parent directories exists as a file extracting the archive results in an error. In the example: if l1/l2 is a file and the archive doesn't contain the directories but only the file l1/l2/x.txt that would be an error. * In case of an error, it is possible that the archive has been partially extracted. Closes #4568
* score: Fix _Workspace_Initialize_for_one_area()Sebastian Huber2021-12-071-14/+20
| | | | | | | In _Workspace_Initialize_for_one_area(), properly check if there is enough free memory available for the configured workspace size. The bug was introduced by commit 3d0620b607ff6459fec9d30efc1e0589bbd010f9.
* libtest: Fix sample reportingSebastian Huber2021-12-071-11/+14
| | | | The sample reporting wronly added values to the wrong bin in some cases.
* libtest: Fix overlap in measurement contextSebastian Huber2021-12-071-2/+2
* score: Fix atomic stores for C++Sebastian Huber2021-12-071-3/+3
| | | | Close #4566.
* rtems: Move all Interrupt Manager stuff to intr.hSebastian Huber2021-12-022-2274/+2272
| | | | | | Since the previous Interrupt Manager Extension API moved to the Interrupt Manager, we can move the interfaces to <rtems/rtems/intr.h> so that they are available via #include <rtems.h>.
* rtems: Move scheduler directives to own headerSebastian Huber2021-12-0216-501/+584
| | | | | | Move all rtems_scheduler_* directives to the new header file <rtems/rtems/scheduler.h>. Add a Scheduler Manager API and implementation group.
* libc: Optimize malloc() initializationSebastian Huber2021-11-305-87/+192
| | | | | | | | | | | | | | | | The BSPs provide memory for the separate C Program Heap initialization via _Memory_Get(). Most BSPs provide exactly one memory area. Only two BSPs provide more than one memory area (arm/altera-cyclone-v and bsps/powerpc/mpc55xxevb). Only if more than one memory area is provided, there is a need to use _Heap_Extend(). Provide two implementations to initialize the separate C Program Heap and let the BSP select one of the implementations based on the number of provided memory areas. This gets rid of a dependency on _Heap_Extend(). It also avoids dead code sections for most BSPs. Change licence to BSD-2-Clause according to file history. Update #3053.
* score: Optimize Workspace Handler initializationSebastian Huber2021-11-304-91/+248
| | | | | | | | | | | | The BSPs provide memory for the workspace initialization via _Memory_Get(). Most BSPs provide exactly one memory area. Only two BSPs provide more than one memory area (arm/altera-cyclone-v and bsps/powerpc/mpc55xxevb). Only if more than one memory area is provided, there is a need to use _Heap_Extend(). Provide two implementations to initialize the workspace handler and let the BSP select one of the implementations based on the number of provided memory areas. This gets rid of a dependency on _Heap_Extend(). It also avoids dead code sections for most BSPs.
* score: Split wkspace.cSebastian Huber2021-11-303-15/+98
| | | | Splitting the file avoids unnecessary link-time dependencies.
* wkspace.c: Change license to BSD-2-ClauseSebastian Huber2021-11-301-5/+24
| | | | | | Change licence according to file history. Update #3053.
* arm: Add AARCH32_PMSA_DATA_READ_WRITE_DEFAULTSebastian Huber2021-11-301-8/+28
| | | | | | | Add default memory attributes for read-write data. The actual attributes depend on the RTEMS_SMP build option. Update #4202.
