* | * rtems/powerpc/registers.h: Added Freescale Book E Implementation | Thomas Doerfler | 2009-02-27 | 2 | -0/+33 |
| | | | | | Standards (EIS) special purpose register definitions for MMU and L1 cache. | ||||
* | * libmisc/shell/shell.c, libmisc/shell/shell.h: Changed type for | Thomas Doerfler | 2009-02-27 | 4 | -60/+76 |
| | | | | | | | | | boolean values from 'int' to 'bool'. Added option 'login' to enable or disable a login prompt. Changed intialization of global shell environment to static initialization. Changed stack size type to 'size_t' conforming to classic API. * libmisc/shell/shellconfig.h: Fixed some typos. | ||||
* | New. | Ralf Corsepius | 2009-02-20 | 1 | -0/+2 |
* | Regenerate. | Ralf Corsepius | 2009-02-20 | 1 | -0/+4 |
* | 2009-02-20 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-20 | 1 | -0/+5 |
| | | | | | * include/sys/priority.h: New. * Makefile.am: Add include/sys/priority.h | ||||
* | Add include/sys/priority.h. | Ralf Corsepius | 2009-02-20 | 1 | -0/+1 |
* | 2009-02-19 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-19 | 3 | -13/+15 |
| | | | | | * include/rtems/irq-extension.h, include/rtems/irq.h: Spelling errors and spacing. | ||||
* | 2009-02-19 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-19 | 2 | -0/+10 |
| | | | | | | * libnetworking/rtems/rtems_bsdnet_internal.h: Re-add boolean when building BSD code. This is used by at least one of the BSD NIC drivers I am currently porting. I am trying out | ||||
* | 2009-02-19 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-19 | 4 | -6/+59 |
| | | | | | | * libmisc/Makefile.am, libmisc/shell/shellconfig.h: Add halt command to shell which results in the shutting RTEMS down. * libmisc/shell/main_halt.c: New file. | ||||
* | 2009-02-17 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-17 | 2 | -2/+12 |
| | | | | | | * rtems/score/sh.h: SH2E and SH3E have a DSP rather than an FPU. They are not compatible. We currently only support the FPU found on the SH3 and SH4. | ||||
* | 2009-02-17 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-02-17 | 2 | -2/+6 |
| | | | | | | PR 1377/shell * libmisc/shell/main_netstats.c: Remove #if 0 which should not have been there anyway. | ||||
* | 2009-02-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-12 | 4 | -5/+11 |
| | | | | | | * sapi/include/rtems/config.h, score/include/rtems/score/thread.h, score/src/threadidlebody.c: Change prototype of IDLE thread to consistently return void * and take a uintptr_t argument. | ||||
* | 2009-02-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-12 | 30 | -24/+74 |
| | | | | | * cpu.c, rtems/score/cpu.h: Change prototype of IDLE thread to consistently return void * and take a uintptr_t argument. | ||||
* | 2009-02-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-12 | 4 | -3/+13 |
| | | | | | * rtems/score/cpu.h: Change prototype of IDLE thread to consistently return void * and take a uintptr_t argument. | ||||
* | 2009-02-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-12 | 4 | -2/+12 |
| | | | | | * cpu.c: Change prototype of IDLE thread to consistently return void * and take a uintptr_t argument. | ||||
* | 2009-02-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-11 | 2 | -5/+10 |
| | | | | | * sapi/src/exinit.c: Eliminate _CPU_Thread_dispatch_pointer and passing address of _Thread_Dispatch to _CPU_Initialize. Clean up comments. | ||||
* | 2009-02-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-11 | 48 | -443/+149 |
| | | | | | | * cpu.c, rtems/score/cpu.h: Eliminate _CPU_Thread_dispatch_pointer and passing address of _Thread_Dispatch to _CPU_Initialize. Clean up comments. | ||||
* | 2009-02-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-11 | 3 | -15/+7 |
| | | | | | | * rtems/new-exceptions/cpu.h, rtems/score/cpu.h: Eliminate _CPU_Thread_dispatch_pointer and passing address of _Thread_Dispatch to _CPU_Initialize. Clean up comments. | ||||
* | 2009-02-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-11 | 2 | -0/+6 |
| | | | | * rtems/score/cpu.h: Use a 16 bit object id on this target. | ||||
* | 2009-02-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-11 | 2 | -1/+12 |
| | | | | | * rtems/score/cpu.h: Do not unroll any code on this target and use a 16-bit object id. | ||||
* | 2009-02-11 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-02-11 | 2 | -1/+6 |
| | | | | | PR 1374/misc * libmisc/stackchk/check.c: Fix printk formatting string. | ||||
* | 2009-02-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-11 | 2 | -3/+8 |
| | | | | | * sapi/src/exinit.c: Interrupts are guaranteed to be disabled by boot_card(), do not do it here as well. | ||||
* | Partial update from FreeBSD. | Ralf Corsepius | 2009-02-11 | 2 | -9/+11 |
* | 2009-02-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-11 | 1 | -0/+2 |
| | | | | | * libnetworking/sys/kernel.h: Remove PSEUDO_* (Unused, not in FreeBSD). | ||||
* | Remove PSEUDO_* (Unused, not in FreeBSD). | Ralf Corsepius | 2009-02-11 | 1 | -28/+0 |
* | 2009-02-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-11 | 1 | -0/+1 |
| | | | | * libnetworking/sys/kernel.h: Remove struct linker_set (Unused). | ||||
* | Remove struct linker_set (Unused). | Ralf Corsepius | 2009-02-11 | 1 | -6/+0 |
| | | | | * libnetworking/net/if_loop.c: Remove PSEUDO_SET (Unused). | ||||
* | Remove PSEUDO_SET (Unused). | Ralf Corsepius | 2009-02-11 | 1 | -2/+1 |
| | | | | * libnetworking/kern/uipc_domain.c: Remove domain_set (Unused). | ||||
* | Remove domain_set (Unused). | Ralf Corsepius | 2009-02-11 | 1 | -2/+0 |
* | 2009-02-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-11 | 2 | -41/+12 |
| | | | | | | | * libnetworking/sys/kernel.h: Remove execsw_set, si_elem_t (Unused, not in FreeBSD). #include <sys/linker_set.h>. Add #ifdef _KERNEL guards (From FreeBSD). | ||||
* | 2009-02-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-11 | 2 | -5/+5 |
| | | | | | * libnetworking/sys/kernel.h: Remove hostnamelen, domainnamelen, lbolt, tickdelta, timedelta (Unused, not in FreeBSD). | ||||
* | 2009-02-10 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-10 | 1 | -0/+1 |
| | | | | * libnetworking/vm/vm.h: Cosmetics from FreeBSD. | ||||
* | Cosmetics from FreeBSD. | Ralf Corsepius | 2009-02-10 | 1 | -6/+32 |
* | 2009-02-10 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-10 | 1 | -0/+2 |
| | | | | | * libnetworking/rtems/rtems_bsdnet_internal.h: Remove struct vm_page, vm_page_t, boolean_t (Unused). | ||||
* | Remove struct vm_page, vm_page_t, boolean_t (Unused). | Ralf Corsepius | 2009-02-10 | 1 | -5/+0 |
* | 2009-02-10 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-10 | 1 | -0/+8 |
| | | | | | | | | * libnetworking/nfs/bootp_subr.c, libnetworking/nfsclient/nfsdiskless.h: Cosmetics from FreeBSD. * libnetworking/rtems/rtems_bsdnet_internal.h: Remove struct file (Unused). | ||||
* | Cosmetics from FreeBSD. | Ralf Corsepius | 2009-02-10 | 2 | -47/+29 |
* | Remove struct file (Unused). | Ralf Corsepius | 2009-02-10 | 1 | -1/+0 |
* | 2009-02-09 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-09 | 1 | -1/+5 |
| | | | | | * libnetworking/sys/socketvar.h: Remove struct file, soo_ioctl, soo_select, soo_stat, getsock (Unused). | ||||
* | Remove struct file, soo_ioctl, soo_select, soo_stat, getsock (Unused). | Ralf Corsepius | 2009-02-09 | 1 | -10/+0 |
* | Regenerate. | Ralf Corsepius | 2009-02-06 | 1 | -4/+0 |
* | 2009-02-06 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-06 | 1 | -0/+5 |
| | | | | | * posix/include/sched.h, posix/src/sched_getparam.c: Make sched_getparam() POSIX compliant. | ||||
* | Make sched_getparam() POSIX compliant. | Ralf Corsepius | 2009-02-06 | 2 | -2/+2 |
* | 2009-02-06 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-06 | 1 | -0/+4 |
| | | | | * Makefile.am: Don't install libcsupport/include/tar.h. | ||||
* | Remove tar.h. | Ralf Corsepius | 2009-02-06 | 1 | -2/+0 |
| | | | | | * aclocal/canonical-target-name.m4, aclocal/enable-posix.m4: Remove comment referring to HPUX. | ||||
* | Remove comment referring to HPUX. | Ralf Corsepius | 2009-02-06 | 2 | -2/+0 |
* | 2009-02-05 Sebastian Huber <sebastian.huber@embedded-brains.de> | Ralf Corsepius | 2009-02-05 | 2 | -2/+7 |
| | | | | | * libnetworking/lib/ftpfs.c: Enable write and mount filesystem with read-write access. |
